Hi Matt, for what you say the internal power supply of the Combo Sansui, 110 volts a12v, is not working
Indicate model of Combo Sansui, which you are commenting on, in order to find the best possible solution
I wait your answer
Regards Franco Dosil
Hola Matt, por lo que comentas no esta funcionando la fuente de alimentacion interna del Combo Sansui, de 110 volts a12v
Indica modelo del Combo Sansui, del que estas comentando, para poder encontrar la mejor soluci?n posible
Espero tu respuesta
Saludos Franco Dosil
You could use windows media creation tool https://www.microsoft.com/en-gb/software-download/windows10 and press on download creation tool, use it to boot a windows 10 on a 8gb+ usb stick, it's pretty easy to use, first download the tool, insert a usb stick into your laptop, or use a friend laptop to create a bootable usb sitck with windows, and then open the tool, and follow the instructions, wait until the windows downloads directly onto your usb stick and then you can just insert it into your broken laptop, turn it on, and install the windows, if you don't know how to install it, google for steps, i am sure you will find something (mention: the above windows is free version) How To Easily Create Windows 10 Bootable USB Drive
0024,0020.
Try these codes. If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common codes to check devices with different brand TVs are given, in the order of the device's brand name list in alphabetical order. Pull up older posts. http://remotesearch.blogspot.com/ http://electrohelponline.blogspot.com/
