Question about Cell Phones
I68+ sim card problem
I add the same problem with my t mobile sim card i put it in card slot 1 didn't work so i check it again and i realize i had put the sim card in the wrong way round!!! so if you have sim not working check that first!!
good luck!
    Brigadier General:
  • 7,752 Answers
Ok will do
Posted on Aug 01, 2009
Sim card slot stuck
1) taken apart and rebuilt cellphones and 2) dealt with hundreds of malfunctioning phones that didn't read SIM's, I'll give you some ACTUAL help.
1) remove the SIM and check for any missing pins in the slot. You can only see the first row of pins on the N1, but that's all you can see without taking the thing apart again. You should see 4 pins, but the one closest to the notched corner of the SIM doesn't really do anything.
2) If everything looks okay, reinsert the SIM, along with a couple pieces of paper. The idea is to press the SIM into the contacts in case the fit isn't as tight as before.
If you either see damaged pins in step 1 or step 2 didn't work, take it back to the repair guy. He broke it, he's obligated to fix it.
Auto Accessories
May 24, 2012 | HTC TyTN II Smartphone
I have an SciPhone i68 4G. It is a dual sim phone. I tried putting my T-Mobile sim card in with a Vectone sim card and I found that I was having trouble with the battery. It would turn off even when I was...
TO SEXYBABE008 -I HAD THE SAME PROBLEM YOU ARE HAVING. THERE ARE TWO SLOTS FOR THE SIMS CARD- THEY ARE ON TOP OF EACH OTHER- IF YOU ARE ONLY USING ONE SIMS CARD- PUT IT ON THE TOP SPOT WHEN INSERTING IT- THIS WORKED FOR ME- THE BATTERY HAD NIOTHING TO DO WITH.
Mar 01, 2011 | Cell Phones
I68 sciphone is not picking up an att at&t signal
I have my boyfriends ATT sim card in the phone plus my T-mobile. Both work fine. Go under settings and Dual Sim Settings and make sure whatever slot you have the card in is turned on. If you have more than one sim card in it should be on Dual SIM Open. If not pick which slot it's in and turn it on :P If that's not it then sorry I dont know. Just a thought.
Aug 24, 2009 | Cell Phones
My sciphone i68 says emergency calls only when i try to use it
We had the same problem on both of our new sciphones. After long hours of research we finally found an easy solution to it so hope this helps.
1) Shut down your phone completely (you will know because a red sign will come up on your phone and you have to confirm that you are shutting it down).
2) Take our your battery and then your sim card
3) Make sure that your sim card is in the right way. (It has to be on the highest slot, not the one closest to the bottomof the phone, and the metal plates have to be facing down, or towards the phone).
4) Reinsert your battery and then start your phone up again
5) Go to restore factory settings and plug in the code 1122 when it asks for one. NOTE: Your phone will reboot, and when it turns on it should be okay.
We tried everything and this is the only thing that worked. We had t-mobile sim cards for both phones and it worked fine. Good luck!
-twins-
Jun 20, 2009 | AT&T CECT Unlocked i68+ Quadband GSM FM...
My sciphone i68 + doesn't read my sim card
flip the sim card over and cutoff the other sim slot example"if chip is face down make it face up" if that doesnt work switch to other sim slot and repeat the steps above if that doesnt work you can go to this link for more help
http://www.freewebs.com/sciphone/index.htm
Jun 10, 2009 | AT&T CECT Unlocked i68+ Quadband GSM FM...
Cant get my sciphone to work
okay turn your phone off take the back off ,battery and take the sim card out now put the battery back in with out sim card .. turn on. now go open sim and close sim 2... turn off...remove back and battery put sim card in slot 1 make sure its in all the way put battery and back on ... turn the phone on... give it a few minutes it should work....
Jun 06, 2009 | Dual Electronics CECT P168 Cellular Phone
Sim card problem
make sure the sim card is inserted properly. sim card slot 2 is the one away from where battery cover (against the phone) the gold chip will face up towards you. sim card slot 1 is the one slightly elevated gold chip will face down. if you are sure you have it inserted correctly, follow the steps below that came off the help disc i have offered. Works for I9 and I68.
Emergency calls only, then try these steps;
1.) Shut down the phone, remove the SIMS, and replace them back in the slots in the
correct manner again. It may just be that the SIMS aren't in correctly, not pushed far enough
into the slot, or their metal grid isn't making good contact with the SIM's slot pins. Try to
wedge a tiny piece of paper, placed against the side of the SIM without the metal contacts, between the phone and the SIM so it makes the SIM's metal contact points fit up against the phone's SIM slot contacts a little more snugly.
For full help topics I have a cd available for 10 us dollars. Has 100's of mp3 ring tones wallpapers, and java games and opera java browser. Guaranteed help on every question ever asked on these phones. And all settings for all cellular services. I have answered 100 questions with this CD. If interested contact prestorose@aol.com Pay Pal only, will send out First CLASS Mail in padded envelope. If interested I will send Pay-Pal invoice that can be filled out and returned with instructions. Guaranteed safe transaction.
May 04, 2009 | AT&T CECT Unlocked i68+ Quadband GSM FM...
I just get sciphone i68, and i inserted the sim card [virgin mobile precisely] and the network bar shows 5 bar, which suppose to indicate that the network is ok, but if i try to call, it always indicated...
i have a i68 8g sciphone i put my sim card in the phone and it won't let me dial any numbers i mean i can dial but all it says is fail and it won't let me choose a network i have service but when i look at my main screen it says sims card 2 closed because i closed it but in slot one it says emergency how can i fix the problem please help!
Apr 10, 2009 | Dual Electronics CECT P168 Cellular Phone
Just got new cect i68 phone off ebay
You need to call T Mobile because you bought the phone off Ebay. It has to be re registered in there system and set up under their network regardless of any other factor. They have to put their numbers in the Nam1 and Nam2 parts of the phone with the EIM and CDM. That may mean nothing to you but it makes your phone run!! Give T Mobile a call from a LANDLINE phone
Mar 17, 2009 | AT&T CECT Unlocked i68+ Quadband GSM FM...
I just bought a sciphone i68 & my sim card from my old phone won't work in it. Do I have to get another sim card?
Slide the sim card back and forth slowly in the correct slot oriented correctly make sure you're in the correct slot, there are two. Mine did the same thing and it fixed it.
Oct 21, 2008 | Cell Phones
Cell Phones Logo
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
