Question about Kenmore 51262 / 51264 / 51269 Side by Side Refrigerator
The litttle three tooth transmission "gear" the goes on the bottom of the ice bucket is missing...it seems to hold the entire bucket dispensing assmbly in place...is there a way to buy another??? it connects to the ice crusher motor drive , without this gear it will not dispense ice
This was simpler than I expected. I Just went to the sears "parts direct" site, and after some diligent searching, i found the exploded view of this assembly, got the part # and ordered it from same site...placed order on monday...part got here today (friday) part goes in tomorrow...even got the proper screw to go in the end of the shaft...Thnx for the help.
Posted on Aug 08, 2009
Out loading auger problems
if by this your saying that the ice dispenser auger has a problem ?
a few things to look at on a ice dispenser
1st remove ice bucket with auger completely out of fridge
look at back of fridge is there a build up of ice there ? if so you may have a leaking water valve for ice maker
carefully inspect the back of ice bucket to see that drive catch is not broken or missing parts
2nd verify that the door to side that contains the dispenser is all the way shut , sometimes ice build up keeps door from closing all the way to allow door switch to say ( door closed safe to dispense ice) this switch is not allways at top or bottom of door but maybe in the middle too
and last but not least , make sure all switches and childlock outs are set correct to working positions and that glass sensors detect the glass in its place
Nov 14, 2015 | Refrigerators
My ice in the ice maker seems to be melting together and they are fusing into big ice cubes that cannot dispense/
This tends to happen when ice has sat in the ice bucket for a couple days of non use. The warmer your kitchen the worst this tends to happen. What's usually happening is the ice bucket is sitting on the door where the ice dispenser sends it to your glass. Since the cavity in the door is exposed to the warm air in your kitchen it can work its way to the ice bucket area via the chute in the door and when the moist warm kitchen air reaches the ice cubes in the bucket it turns everything into melting ice cubes which eventually freezes at some point and clogs up the ice bucket with large globs of ice pieces that the ice crusher can't handle. About the only thing to do is remove the ice globs from the bucket and make new ice. This is not all that abnormal, just a pain though. Try putting something in the chute (small Rag?) to see if this stops it. If it does then there's not a whole lot you can do about it but use the ice machine more often so it doesn't all sit there melting together.
Sep 25, 2014 | Samsung RFG237AARS Bottom Freezer French...
Will not dispense ice
commonly what you will find on that model is the main control board on the back of the unit is the source of your issue, it begins like a computer virus where the unit will render the water in the door feature useless, next goes the ice delivery sys, then the unit does not defrost properly causing cooling issues. But before running out and getting a new control board go by this check list first: 1) make sure your ice bucket is properly seeded, 2) make sure the ice in the bottom of the bucket is not melted together if so empty good ice in seperate container and put back in freezer quickly to avoid melting then run hot water in ice bucket to melt remaining bad ice afterwards completely dry ice bucket and put good ice back in and see if it works properly, 3) make sure the auger mtr is not seized due to door being left open and humidity freezing in mtr gear.
Apr 16, 2012 | GE Refrigerators
Door icemaker will not dispense ice. Motor starts
At the very least you have worn out coupler components. Determine what the motor issue is and replace it if necessary also.
Eric
Oct 16, 2009 | Whirlpool GS6NBEXR Side by Side...
My ice maker makes plenty of ice, no problem with the water either. My problem is that the auger will not turn to dispense the ice out of the bin. The motor kicks on when you push in the buttom, however it...
Pull the ice bucket out, then hold in on the door light switches and while you push a glass into the button for ice (may require two people). Ice dispenser and auger will only work, when you push for ice, when the freezer door is closed, so by holding the light switch(s) in the off position with door open you can simulate door being closed. If you can push the button and see the auger drive turn (with ice bucket out) then check to see if you have some ice stuck between the blades on the bucket, if the auger motor doesn't turn, it may be "ice frozen". Common problem. Remove motor, let sit on counter for about three hours and then reinstall, if it then works then check for water dripping from the fill tube, where the water comes into freezer for the ice maker, and see if it is dripping onto auger motor.
If you put auger motor back in and it still won't turn then more and likely you need an auger motor.
Let me know.
Oct 09, 2009 | GE Profile PSW26P Stainless Steel Side by...
GE GSS25LGM Ice maker not dispensing ice
You have one of three things wrong. The auger motor is frozen up, the ice bucket is broken or you need to dump out any ice, run warm water through the entire ice bucket, dry it out and try again with fresh cubes. My guess is the auger motor is frozen. You can buy a vinyl boot that covers the auger motor to prevent moisture buildup and freezing from GE Parts at 1-800-626-2002
Nov 21, 2008 | GE GSS25LGM Side by Side Refrigerator
Whirlpool Side by Side Refrigerator Wont dispense ice
if you lift out the ice bucket you will see the "gear" that turns the auger. The gear is metal but the part on the bucket is plastic and this can become stripped out. Also check that there is not ice frozen around the bottom of the bucket where an ice cube may have lodged the chute door partially open and melted some of the ice in the bottom creating a blockage.
Nov 06, 2008 | Whirlpool GC5SHEXNS Side by Side...
Kenmore Refrigerator stopped dispensing water
Look up through the ice despencer on the front door of the freezer. Is the flapper door open? If so it needs to be fixed. If its not then try leaving the freezer door open for 3+ hours to defrost the frozen line in the door. If that doesnt work, the water valve must be changed.(located behind fridge, take off back cord board panel at bottom, the valve is blue)... GOODLUCK!
Dec 31, 2007 | Refrigerators
Kenmore 51262 / 51264 / 51269 Side by Side Refrigerator Logo
73 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
dweatherby
paulcarew
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
