SOURCE: Ice maker sotp making ice / red light blinking
J, As you open the freezer door the LED on the right should flash 2X with a pause repeatedly. When you hold the left side emmiter down the light should stay on steady. If you have this, you know the optics are good unless the ejector blades are not home. First thing to check is where the ejector blades on the ice maker are parked. They should be resting in the 2:00 position. If they are not, you could have a broken module. If they are in the 2:00 positon the next thing to check would be the fill tube. You want to make sure it is not frozen over. You can disconnect it from the back and see if you can blow through the line or visually inspect it. If all of the above mentioned check out, jump start the ice-maker. Remove the quarter inch screw holding the harness cover on the right side. Remove the harness cover. Pull the ice-maker straight out but be carefull not to smash the emmitter flap on the left side. Leave the harness connected. Get a jumper wire with the ends stripped apout a 1/4 inch. Unplug the refer and place the jumper in test holes T&H. Leave the jumper in and place the ice maker on the shelf where you can close the door. Close the door and plug the refer back in. Wait 30 seconds and open the door. The ice maker should be cycleing. Pull the jumper and place the module cover back on. Put the ice maker back in the rails. It should fill at approx the 12:00 position. Let me know how you make out. Catriver.
SOURCE: Ice maker quit working
good sign its flashing , woth door open depress the left side flap oppiste the blinkin light. does the light then go solid red??? i fso its an indication that the electricl eye is operating ok .
theres a screw 1/4 in. along the right side underneath the icemaker itself, youll need to removeit and the cover its holding down. you can then slide the ice maker assy foward and out of machine,There will be another litle tab along loeft side uder ice maker youll need to depress to ppulll unit out. pry off the white cover from front of the ice maker assy itself and have a look at the main gear 2 in. round, is it broken off, or on its way top breaking( sometimes the tabs that hold it on to the ice maker module itself break preventing operation, if this is the case youll need to repalce the ice maker assy.
SOURCE: kitchen aid ref, ice maker quit making ice
hi my name is mark, do you have a water filter on this unit. shut off water to ice maker. remove water line from ice maker, hold water line in a bucket slowly turn on water. if you get water. then the fill solinoid has failed. if you do not get water trace water line back to water shut off. if it is the solinoid valve. you will need model and serial number to order part
SOURCE: ICE MAKER QUIT MAKING ICE ON MY WHIRLPOOL FRIDGE
I had a Whirlpool Model GD5SHAXNS in which the icemaker quit working about the same time (3 years old). I had water out the dispenser, I found that it was the icemaker itself failed not calling for water to fill it. I replaced it with a icemaker on-line for about $100 and problem fixed. I have been told his is a common problem with the icemaker in this model ref.
SOURCE: red light blinking on ice maker
the red blinking light is normal . it sounds like you have a whrilpool,kitchenaid or kenmore made by whirlpool. if your ice-mkr fingers are not resting in the 2 o'clock position, then your
I/M motor/module is broken. use part#8201515
