There is water leaking from underneath the machine and also from the inlet pipe. I think its a block somewhere but not sure how to find out
If you take the top off. Screws should be inback. You may notice that the hose going to the drum is torn. This is just one main problem leak with most Haier machines. Part are fairly easy to change out yourself with somebasic tools. You can get a lot of info on their website. haier.com
(800)313-8495 customer service
(800)461-8890 tech support
I hope this helps
Posted on Aug 01, 2009
My kenmore wash machine 80 series model 110.29812890 leaks only on the rinse cycle
i think it mat be somehting to do with filler ,in the filler tray their is more than one compartment and three or four water inlets all with electric solonoids and one of these or a pipe is leaking ,take the top off and see what you can see this is a physical thing somewhere along the line
Nov 20, 2011 | Washing Machines
Hoover optima washing machine is leaking very badly . I have stripped the machine down and cannot find the leak . Inlet pipes clear. Cleaned soap drawer and two feeder rubber pipes don't seem to be a...
Hi,maybe the draw dispencer is damaged,I wouldnt think it is the drum seal,what I would do is tilt the washing machine so that the top of the machine is leaning against the wall so that the front of the machine is of the ground,then while you get underneath the front on the floor with a torch get someone to put water in the dispencer and see if you can see where the water is leaking from,I hope this was some help,all the best.
Mar 21, 2017 | Washing Machines
No water is comming out of the water spout, the pump is trying but eventually stops and steam escapes from somewhere under the machine. The water spout is not blocked, as when removed you can blow through...
Hi sounds like a blocked boiler. Remove the water inlet line going into the boiler and use a 3mm drill bit and drill the inlet pipe out. Could also be a faulty hot water solenoid. Dazza REPAIRER
Sep 23, 2011 | DeLonghi EAM3500 Espresso Machine/Coffee...
Saeco Vienna machine...after brewing a couple of cups of coffee, water leaks from somewhere and comes out underneath the front grilled tray and onto the counter. Can I do the repair with the proper parts?
Depending on your ability to do some technical and minutious manual work, unmounting and remounting the machine is feasable.
Concerning the leaking, what I've seen most is a leak from the seal under the water tank. Any leaks coming form there would occur even though no coffee would be dispensed. (i.e: Idle mode)
If leak is ONLY occurring when brewing cofee, I would check the following:
1- Check if the water inlet on the back of the brew unit is filled with residue (the inlet looks like the end of a smoke pipe)
2-Open the machine, take out the interior, and verify the water tubes coming in and out of the boiler. They both should be sealed with 2 small o-rings. After time, o-ring tend to expand under heat and may start to leak.
Hope this helps
Feb 27, 2011 | Saeco Vienna De Luxe Espresso Machine
IWater Leak from LG12225FD Washing machine
may be pump...hose seal... in outer tub...cracked inlet valve cracked hose inlet to tub
Aug 17, 2009 | Washing Machines
Leaking from machine - not door or outlet / inlet pipes
  • Hi,
  • Try these
  • Inspect the water supply connections
  • Inspect the drain hose
  • Inspect the water pump
  • Inspect outer tub for cracks or corrosion
  • Inspect the tub seal
  • Inspect the tub bearing
please rate my suggestion
Apr 14, 2009 | Washing Machines
Haier XQB55-10 : water leakage from inlet hose jointer
You must examine your machine hose to see if it is blocked. Clean out the fine nets in the hose as well as at the machine entry (inlet water entry). Clean well with a tooth brush, refit carefully. Water should be in good pressure for machine operation.
Feb 23, 2009 | Haier HWD1000
Water leaking from bottom of washer
you need to fill it up a little then switch it off. tilt it backwards and if it hasnt got a base you should be able to see where the water is coming out of. check the bottom hose and around the element location.
Jun 23, 2007 | LG WM-2277HW Front Load Washer
Hoover washing machine top load, model 550m.5.5kg
water leak from cold hose nothing to do with other problem. tighten hose connection and fit a new hose washer overfilling probably because air chamber blocked. remove lid. you will see a pressurestat somewhere at the top - usually round with anything from 3 to 7 wires and a small tube underneath. follow hose down and it connects to the air chamber. make sure this is free of gung and check hose for splits and has no blockage. to check the pressure stat itself, attach your own hose to the stat and while machine in fill mode, blow down this hose and you should hear a click and water intake will stop
May 04, 2007 | Hoover HTC243 Top Load Washer
Washing Machines Logo
85 people viewed this question
Top Washing Machines Experts
