Question about Samsung SpinPoint P80 SP0802N 80 GB Hard Drive
HDD enclosure does not work
My HDD enclosure is Rocketfish RF-HD35. When I plugged it in my computer, the hardware detects USB DEVICE SAMSUNG SP0802N. However, when I clicked the icon, it shows location:0 Do not detect driver.
Also, I clicked computer mangagement, and did not see my USB drive.
Thank you
    President:
  • 1,383 Answers
For that you need to uninstall all usb driver from device manager.
Right click on my computer icon then you see system property then go to hardware -> device manager then uninstall usb drivers 1 by 1 .
Then restart computer then all usb drivers are automatically installed.
Then connect your harddrive if still face same problem then connect your harddrive to another computer then check.
If another computer cant see your harddisk then your harddisk has hardware issue.
It need repairing .
If it is in warrenty take it to service shop they replaced it.
Posted on Aug 01, 2009
External HDD usb 3.0 Rocketfish 2.5
install the driver for it ..if it has a CD with drivers..and try again ..It may also not be read cause it is on a usb 3.0 and you may need to change the usb port ..If you do not have a 3.0 port ..it may work on a 2.0 ..but be sure you have the drivers for this kinda port ..Also try ti in a different computer cause its drivers may not be compatible with your operation system ..If it is made to work in newish windows 7 and you run an older OS ..this may be a problem ..
Dec 29, 2011 | Rocketfish 25 SATA Enclosure Hard Drive
The external drive does not show up on my desk top and it is plugged in.
Follow the steps given below to refresh USB ports.
1. Right-click My Computer icon on the desktop, and then select Properties.
2. Click the Hardware tab.
3. Click the Device Manager button.
4. Click the plus (+) sign to the left of Universal Serial Bus controllers.
5. Right-click the device listed under Universal Serial Bus controller and select Uninstall.
6. Click OK to confirm the removal of the device.
Please note, repeat Steps 5 and 6 until all the devices under Universal Serial Bus Controller are removed.
7. Shut down the computer.
CAUTION: Ensure that the Shut Down option is selected, instead of the Restart option.
8. Wait for 5 seconds and then restart the computer. When the computer restarts, a "Windows has detected new or added hardware" message window will open.
The above steps will refresh the USB ports.
Now connect the USB devices like mouse, video camera, your external usb hard disk...usb hubs...whatever you like and the drivers should install automatically.
Tip: It is always recommended to connect the main usb devices at the rear end usb port, as they require more power to initiate.
May 31, 2011 | Western Digital imicro IM35ST320SI 3.5 IDE...
Computer not recognizing hard drive. Seems to be a problem with usb connection. Can I put the drive into another enclosure?
Definitely you can try with different enclosure, and it will work in any enclosure... But before buying a new enclosure it would be better if you try to connect the hard drive in a different computer to isolate where the issue is...
Jan 02, 2011 | SimpleTech SimpleDrive Pininfarina 320GB...
Alright so my girlfriend hands me this external hard drive (rocketfish 3.5 USB2.0, model # RF-HD35)since i seem to know my way around computers somewhat and asks me to see if i can get some of the saved...
The drive may not be marked as active so try this
Click start/control panel/admin tools/computer management/.
On R/H side select disc management. (or it could be removable storage)
All drives should be shown. If the drive is shown right click on it and mark as active.
Aug 23, 2010 | Computers & Internet
External hard drive is not detected
Check Following Instructions:
1. Check your USB cable properly connected to the computer.
2. Go to My computer - right click on property - Hardware - Devices Manager - in below - USB Mass storage device - right click on this - and Uninstall - then again right click - click on Scan - it should be reload your USB drivers
your External Hard Drive will be detected
Apr 25, 2010 | Seagate USB 2.0 External Enclosure + 400GB...
Samsung sp0802n HDD enclosure. I installed everything. The safe remove program detect the massage storage, but the hard drive icon does not show.
Has the hard drive been formated?
To format the drive, plug the external drive into the USB port - go to the Control Panel - Administrative Tools - Computer Management - Storage - Disk Management. The External drive should be listed as USB drive. On the lower panel, right click on the USB Drive and click on Format, and format it in NTFS.
After formating you will be able to use it as a normal hard drive.
Aug 01, 2009 | Samsung SpinPoint P80 SP0802N 80 GB Hard...
Samsung Pleomax SAM MD-205 driver?
It took me a lot of digging to try and find a driver download. You can try the UHD25-80GB driver (this is for Windows 98, but you can try to see if it fixes the problem): http://www.samsungpleomax.com/sup_03_01.asp?page=2&fcate=Driver+download&scate=Storage+Media&tcate=HDD&scateg=Storage%20Media&tcateg=HDD. Direct link to zip file: http://www.samsungpleomax.com/sup/cs/HDD-driver-2500-80GB%20DRIVER.zip
Also, specs indicate that you need USB 2.0 or 1.1. I had problems connecting via a 4-port hub (that was supposed to support USB 2.0) so ended up connecting directly via my computer USB ("Enhanced" = 2.0) slot, which seemed to work fine.
Apr 04, 2009 | Samsung Zirex Pleomax 80GB Portable Hard...
Usb connection on my attache maxfile broke. I still have the harddrive and need a new clamshell with usb plug.
You should be able to buy a USB enclosure from any well stocked independant computer store or online store, i.e. NewEgg or TigerDirect, to put that HDD in. I believe they are available for any standard or laptop IDE/SATA HDD. The enclosure should come with the cabling/connections to install the drive. If the drive is still functional, it should be "plug and play" once you put it into a new enclosure.
Dec 17, 2008 | PNY P-HD12GU20-RF MaxFile USB 2.0 Micro...
Samsung SP0802N External Case?
Hi, try this. This will work with your HD. 2.5"/3.5" EN391-S2HC USB 2.0/eSATA SATA HDD Dock w/Card Reader & Hub
Dec 12, 2008 | Samsung SpinPoint P80 SP0802N 80 GB Hard...
Accessing
if you can get another hard drive and place it in the enclosure plug usb cable in then turn on the enclosure and see if this works if doesnt place it on another unit or pc and see if it accepts if it does then the usb drivers need to be re-installed goto my computer device manager and find usb it looks like a trident hilight this and click uninstall from menu list in properties then on the top of manager there will be a computer with a spyglass click on this and windows will find new devices let it continue then reboot then re-try enclosure if all goes well it will come up found new device. retry other hdd you first placed in enclosure if it dosen't feel hdd is turning the platters then get rid of hdd. hope this goes well
Apr 20, 2007 | Vantec 1 Bay NexStar 3 USB 2.0 External...
Samsung SpinPoint P80 SP0802N 80 GB Hard Drive Logo
567 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
