Question about Rockford Fosgate Punch 800a2 Car Audio Amplifier
The amp wont go out of protect mode
I have a fosgate amp and somehow i arced its case and it will power on but the protect light remains on.
    Novelist:
  • 77 Answers
Sounds like you may have shorted a power mosfet or more than one. I'm pretty sure that is what is going on. I've done it myself. I repair car amps and install car audio systems for a living. You need to test the transistors with a digital volt meter set to diode check. Let me know if you know how to do this, if not I can help you. If you need it repaired and don't know how to do it I'll be happy to repair it for you if interested. I am the cheapest you will find anywhere. People send me their amps from all over the U.S and Canada. Good luck and hope to hear from ya!
Posted on Aug 02, 2009
Hey I have a rockford fosgate t2500bdcp-1 when ever the bass is about to hit the amp goes to protect mode and comes back on
If you can tell that it is about to hit and the amp goes into protect mode, the amp is being over driven on the input.
Feb 06, 2017 | Rockford Fosgate Car Audio & Video
I have a Rockford fosgate 501bd why the protect come on?
i say somehow you have damaged the amp, it needs repair or tip. useually output transistor or fets are faulty, if you cut the faulty ones out of circuit the other remaining channels may work
Oct 16, 2014 | Car Audio & Video
It is stuck in protect and wont come out
bro...i had problem like that before and i found out that the load(speakers) was high thats why the fuse always blow...or...check the wire to the speakers if they are sorted or touched.gud luck
Oct 26, 2012 | Rockford Fosgate T1000-1bd - 1000W...
As soon as I hook the amp up it goes into protection mode. But in about 10 seconds it flashes off protection mode but them goes right back into protection mode. And it keeps doing this as long as the amp...
If you disconnect your speakers and input and the problems remain it means you've blown your end-stage and the amp needs repair.
if the problem disappears when disconnecting the speakers you may want to check if the impedance of your speakers is within tolerance of the amp.
Dec 23, 2010 | Rockford Fosgate Punch P5002 Car Audio...
Audio cutting in and out protect light turning on Rockford fosgate p4004
Disconnect all speaker connections and rca cables. Leave power, ground and remote wires intact. Try turning on again. If you still have a protection light your amp is faulty. Hopefully you have warranty. Your amp is clipping. Try adding a capa A thumbs up would be greatly appreciated if this answer is helpful to you. audio-cutting-in-out-protect-light-peeu4x5nsxvd53n2rwetiqa4-3-0.jpg
Jun 20, 2010 | Rockford Fosgate Punch P4004 Car Audio...
Rockford Fosgate punch protection light
power it off, then on...check you're fuses. unplug the car battery and try again. good luck.
Sep 05, 2009 | Rockford Fosgate Punch 800a2 Car Audio...
Rockfordfosgate P6002 amp protect light goes on
are u sure u have them running at the right ohms, for not only the subs but the amp too...if you go lower than your amp is rated you can fry stuff...via protect mode......hopefully this helps
Mar 17, 2009 | Rockford Fosgate p-450.4 Car Audio...
401s Rockford Fosgate Amp. Not turning on. No power light. Pos+ and GR- are solid. Thought it may be remote, so tried running a wire from the POS+ to REM to test it, no luck
Amp Failure:
There are many different ways that an amp can fail but the two most common failures are shorted output transistors and blown power supply transistors (< those are not blown). There are several types of protection circuits in amplifiers. The most common are over-current and thermal. The over-current protection is supposed to protect the output transistors. Sometimes it doesn't work well enough to prevent the failure of the output transistors but it will work well enough to shut the supply down before the power supply FETs are destroyed. If the amp remains in protect mode, goes into protect mode or blows the fuse as soon as the remote voltage is applied, shorted output transistors are almost certainly the cause. If the fuse protecting the amp is too large, if the protection circuit doesn't respond quickly enough or if the power supply is poorly designed, the power supply transistors may fail. If you see a lot of black soot on the power supply transistors (near the power transformer), the power supply transistors have failed. Soot on the board doesn't necessarily mean the transistors have failed. Sometimes, technicians don't clean up the mess from a previous failure. Transistor Failure/Checking Transistors:
In general, when a transistor fails, it will either short (common for output AND power supply transistors) or open (common for power supply transistors). Transistors act like valves. They control the current flowing through a circuit. A shorted transistor acts like a valve that's stuck open (passing too much current). In the case of an output transistor, the shorted transistors tries to deliver the full rail voltage to the speaker output terminal. If you've ever seen a damaged amp that pushed or pulled the speaker cone to its limits when the amp powered up (common on some Rockford amplifiers), that was almost certainly due to a shorted output transistor. When checking transistors, you most commonly look for shorted connections inside the transistor. You do this by using a multimeter to look for low resistance connections between the transistor's terminals. Note:
I used the terms short and open on the previous paragraph. A short (short circuit) is a path through which current flows that should not be there. An open (open circuit) is a break in the circuit.
These repairs are best left to a repair tech familiar with car audio amplifiers. Check with your local shop to get a reccomendation. If the light isnt even coming on, chances are your input or power supply has been taken out.
Jan 01, 2009 | Rockford Fosgate Punch 401S Car Audio...
I have a fosgate 301x with power to the amp but none coming out
Note:
There are no internal fuses on any car audio Amplifier. Servicing will be required.
Dec 30, 2008 | Rockford Fosgate Punch 301X Car Audio...
Car Audio & Video Logo
513 people viewed this question
Top Rockford Fosgate Car Audio & Video Experts
Tygh Duval
Tygh Duval
Professor_V
Professor_V
Robert Rankin
Are you a Rockford Fosgate Car Audio and Video Expert? Answer questions, earn points and help others
