Question about HP Office Equipment & Supplies
Same probleme for me with HP PSC1510,resetting worked not
My HP PSC1510 says that the color cartridge has a problem!
It won't let me print nor scan.The color copy light,and the control inkcartridge light blinks,on the select page number shows me an ''E''
  • petey1980 Aug 01, 2009
    I'm using 1 year old cartridges,but is about 1 week ago that i refilled it the first time,the strange thing is that after the refill i could print ca. 20 sheets!
  • petey1980 Aug 02, 2009
    i tried to soldier the cartridge on the connections but the probleme still remains.I will buy tomorrow a new one,and pray that's not the printer that make me probs!
    thank you for your help
  • 724 Answers
Using a new or refilled cartridge?
Posted on Aug 01, 2009
  • tommya300
    tommya300 Aug 01, 2009
    using a new or refilled cartridge?
  • tommya300
    tommya300 Aug 02, 2009
    Sometimes it works ok and sometimes no Well you can try new or fiddle around if time is not a money issue
Color won't print - Deskjet F4210
you are having a defective printer head so just got it replace or get another printer
Feb 04, 2013 | HP Deskjet F4210 All-In-One InkJet Printer
My hp photosmart 5514 won't print. I put in new ink-black and color- and it goes through the motions, but the page is empty
I just had this exact problem on my HP 5514. Black won't print after running out of black ink. New cartridge no good.
I tried everything-no good. I suspected the pinholes in the printhead were clogged with dried ink because I didn't change cartridge in time.
The fix that worked perfectly was when I hacksaw top off old black cartridge & removed all foam wicks so now I had a funnel(can see clear thru). I installed the cartridge & filled it with alcohol, printed page & did head clean; then printed few more pages. Problem cleared almost immediately. I then soaked up extra alcohol inside cartridge with paper towel. Removed modified cartridge & installed good one. I guess this could be done for colors as well. I don't know if this is a proper procedure, but it sure worked well for me.
Oct 05, 2012 | HP Photosmart 5514 e-All-in-One -...
I have an HP Color LaserJet 2600n. Recently I had to replace the magenta cartridge. I bought a 3rd-party cartridge and the printer display shows that magenta is now "full." But, it won't...
I guess you should try to reset it ..and get the cartridge out and see if the toner (ink ) is getting out ..by pressing it (with the part where you removed the tape ) on some absorbent paper ..when it is working well it should leave a mark on the paper ..the mark should be not washed ...but real color and all...
If it do not ..just use a syringe and blow air in the cartridge ..just to agitate it ..and make sure it is not dry ..
Insert it back ..repeat the procedure until works ..and also if you have the procedure ..reset it ..
http://www.ehow.com/how_6881778_reset-2600n-toner-chip.html
Aug 09, 2011 | HP Color LaserJet 2600n Printer
HP LaserJet 2600N All colors are empty, but Black is brand new. It still says Replace Supplies and the light keeps flashing. Oh, and it won't print anything. So even if I want just B&W, do...
None of the cartridges can be empty if you want to print.
Even if you only want to print black, just black you need to
replace the other three cartridges.
Yes color laser printing is expensive.
Jul 14, 2011 | HP Color LaserJet 2600n Printer
New tri-color cartridge has a problem. I can't see what.
I have an HP Photsmart C4100 printer. I purchased remanufactured ink cartridges (both black and tri-colored) from Vivasmart. The black one works fine, but when I installed the tri-color, I got an error message that says "Print cartridge problem" The following print cartridge has a problem:
Tri-color.
And I can't print. The screen on my printer says "Remove and check color cartridge." I have done this several times and it still won't print. I have turned off the power, removed the cartridges, and unplugged the unit, but it still didn't help. Any suggestions?
Jul 21, 2009 | HP PSC 1510 All-In-One InkJet Printer
Hp 5510 io keeps stating to check color cartridge/3 lights blinking/won t print/installed new color'' Let our Experts solve your ''hp 5510 io keeps stating to check color cartridge/3 lights blinking/won t...
hi..
try to install and reinstall the printer cartridge...and also clean the tab circuit of the cartridge and tab circuit of the printer carrier..
if the problem still exist..
rebreak the printer by full-out the power supply...to reset the settings and then turn it back...
Apr 01, 2009 | HP Officejet 5510xi Printer
PSC1510 & Vista problem
The problem cannot BE solved. It's yet ANOTHER Vista screw-up.
Original Problem:
"No matter what I try - every page from Jarte prints out with an UNWANTED gray
background.
This does not always happen when I print from the web, make copies or print from
Microsoft Word. I ran diagnostics on my printer HP PSC1510 and it's fine.
Test pages print ok, too.
Please help - I had Jarte on my last laptop (Windows XP), it worked very well
and I liked it much better than MS Word."
I emailed Jarte Tech support and got the following answer:
"The problem you encountered is a bug in Windows Vista. You will see the same problem when using WordPad on Windows Vista. As you have noticed, not all programs are affected by the bug. The problem is occurring because you are using a Windows color scheme that uses a gray background color for text windows. Unfortunately, the only work around is to specify white as the background color to use for text windows. Hopefully, Microsoft will correct the problem in a future Windows Vista service pack."
Bob Flora
Carolina Road Software
Jul 14, 2008 | HP PSC 1510 All-In-One InkJet Printer
Yellow Hue when color copying
I understand your situation, however let me explain you that whenever you try to make a copy or print, yellow cartridge takes part and provides its color in all the aspects. Please do check that you use the HP ink cartridges and try to clean the cartridges for every 15 days as this may reduce the issues of colors.
Feb 07, 2008 | HP Photosmart 2710 All-In-One InkJet...
Print Cartrige Error
they probably are dried up if they were in storage
Mar 16, 2007 | HP PSC 1510 All-In-One InkJet Printer
110 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
