Question about Sony RDR-VX535 Player
Sony RDRVX535 remote won't work. (How to Fix It) *Take the remote away from the player. Then hold the enter button and the code* 1 or 2 down for 3 sec. and then you will get some use and you can reset factory defaults. Then repeat from * to * reset for code 3. Hope this works for you.
  • 1 more comment
  • rose_steve Aug 01, 2009
  • rbc54 Sep 18, 2009
    I do not have the factory remote and I have tried to use a univeral remote but it wont allow me to get the main menu in order to finalize the cds once they are burned
    Problem Solver:
  • 4 Answers
I took the remote out of that room and programed it holding down the enter button and the code showing on the screen. Then I took in back into the living-room and it let me get to the menu I needed to put the Number 3 code back and then did the same thing again for that code. And it worked now the DVD side is working again. I hope this helps someone else with this machine. I doen't tell you how to do this in the manual, It just said (YOU WON'T BE ABLE TO USE THE MACHINE)
Posted on Aug 03, 2009
    Problem Solver:
  • 4 Answers
What is the unlock code
If you just need the unlock code see below
You will need to use a "universal" remote control like the One4All 'Kameleon'.
Firstly configure the remote for your sony DVD player:
1. select dvd device on remote
2. hold magic button until rabbit comes out
3. enter device code 0533
Now we need to program buttons 1..5 (you may want to use the buttons with roman numbers at the bottom of the remote, and use another button for V, which doesn't exist) with the following codes, read below for instructions:
1 - 189
2 - 255
3 - 095
4 - 221
5 - 079
For some "universal" remotes, all of the buttons you need to reprogram need to be prefixed by 00. So 1 would be '00189'
This is how you program those numbers:
1. Hold magic button until rabbit comes out.
2. Press 994.
3. Press magic (don't hold).
4. Enter 3 digit code from above.
5. Press button (1..5) where to program it.
6. Repeat steps 1 to 5 for all keys.
That works, but more information on macros is included in the one4all manual for you particular model.
Having set up the remote with the codes unlock the player as follows:
1. Remove disk, put player on standby.
2. Press 1,2,3,4,5 - SUCCESS is displayed and player starts up.
3. Press 1,2,3,4,5 - player shuts down and the unit is region free.
Note that you try this at your own risk as Sony do not support this "feature".
May 28, 2014 | Sony DVP-PQ2 Portable DVD
I purchased a second Sony RDR-VX525 Video Cassette Recorder/DVD Recorder for our bedroom to replace a failing Zenith VCR recorder/player. I began using the Sony VHS/DVD recorder to transfer our movies...
This is a known issue that happens with these players
To fix the Sony remote dvd-1 dvd-2 dvd-3 issue, take the remote for that recorder into another room or unplug the dvd recorder a moment. Then hold down the enter key and the number of the mode its stuck in ie if its stuck in dvd-1 mode hold down the enter key and then the 1 key. hold both buttons together for 3 seconds. After this go back into the room and try it or if you unplugged the player, then replug it back in. The remote has to be away from the player to work. again
here is an example
<stuck in dvd-1mode> get away from player different room so it can not sence remote. Hold down enter and 1 button for 3 seconds and then try it
if its stuck in dvd-2 mode dold down enter and the number 2 button together for 3 secondsd and try it. The idea is you have to be far away from the recorder so it dosent recieve any inputs from the remote while doing this.
Let me know if you are still having problems with this and I would be glad to help you.
thanks
May 05, 2008 | Televison & Video
How can I change my Sony RDR-VX530 to a multi region DVD planer?
Follow the below instructions closely;
1. In order for this hack to work, you will have to send an infra-red code to your player with a OneForAll remote such as the OneForAll 6 (or URC7560) or OneForAll 4 (or URC7740) or OneForAll 4 Digital, or One For All 5 Digital (or URC 7555) with the following instructions:
* Press the DVD button
* Hold down the Magic button until the unit performs a double LED flash
* Configure your remote using the setup code 0 5 3 3
2. On your DVD recorder, using the official Sony remote, select the System-Menu option
3. On your DVD recorder, using the official Sony remote, select the Setup option
4. On your DVD recorder, using the official Sony remote, select the Options option
5. On your DVD recorder, using the official Sony remote, select the Command-Mode option
6. On your DVD recorder, using the official Sony remote, select the DVD1 option
7. On the official Sony remote, set the DVD1 option for the Command-Mode switch, under the sliding cover
8. Verify that both the official Sony remote control and your OneForAll remote control can power off and on your DVD player
9. Program your OneForAll remote with the following instructions:
* Configure your remote using the setup code 9 9 4 or 0 0 9 9 4 if your remote only accepts 5 digit codes
* Press the Magic button once
* Configure your remote using the setup code 1 8 9 or 0 0 1 8 9 if your remote only accepts 5 digit codes
* Press the 1 button once, a double LED flash should occur
10. Program your OneForAll remote with the following instructions:
* Configure your remote using the setup code 2 5 5 or 0 0 2 5 5 if your remote only accepts 5 digit codes
* Press the 2 button once, a double LED flash should occur
11. Program your OneForAll remote with the following instructions:
* Configure your remote using the setup code 0 9 5 or 0 0 0 9 5 if your remote only accepts 5 digit codes
* Press the 3 button once, a double LED flash should occur
12. Program your OneForAll remote with the following instructions:
* Configure your remote using the setup code 2 2 1 or 0 0 2 2 1 if your remote only accepts 5 digit codes
* Press the 4 button once, a double LED flash should occur
13. Program your OneForAll remote with the following instructions:
* Configure your remote using the setup code 0 7 9 or 0 0 0 7 9 if your remote only accepts 5 digit codes
* Press the 5 button once, a double LED flash should occur
14. Place your DVD player into Standby mode
15. Press the buttons 1, 2, 3, 4 and 5 on your OneForAll remote control, in order, one at a time
16. Your DVD player should show the words TIMER OK
17. Press the buttons 1, 2, 3, 4 and 5 on your OneForAll remote control, in order, one at a time
18. Your DVD player should return itself to Standby mode
19. Remove the batteries for significant period of time to wipe the programmed codes on your OneForAll remote
Good luck.
Jan 14, 2011 | Sony RDR-VX530 DVD Recorder/VCR
When i press the remote all i get is DVD 3
Your player has been set on remote mode 3, you need to change remote control itself on remote-3 so unit can get remote signals.
Set the command mode for the remote so it matches the command mode for the recorder.
Hold down ENTER.
While holding down ENTER, enter the command mode code number using the 3 number button.
Hold down both the number buttons and ENTER at the same time for more than three seconds.
Remote control has been set on mode-3, now player will accept remote commands.
Hope this will help you.
Thanks.
Nov 24, 2010 | Sony RDR-VX525 DVD Recorder/VCR
I have a Sony RDR-GX360. Some how I have changed the command mode from DVD1 to DVD 3. Now my remote has frozen and I can't do anything with the DVR player. Is there a reset button or please help.
To fix the Sony remote dvd-1 dvd-2 dvd-3 issue is to take the remote for that recoreder into another room or unplug the dvd recorder a moment. Then hold down the enter key and the number of the mode its stuck in ie if its stuck in dvd-1 mode hold down the enter key and then the 1 key. hold both buttons together for 3 seconds. After this go back into the room and try it or if you unpluged tthe player replug it back in. The remote has to be away from the player to work. again example
if its stuck in dvd-2 mode dold down enter and the number 2 button together for 3 secondsd and try it. The idea is you have to be far away from the recorder so it dosent recieve any inputs from the remote while doing this.bigsmile.gifclap.gifagreed.gifpuh2.gifbowdown.gifeek.gif To fix the Sony remote dvd-1 dvd-2 dvd-3 issue is to take the remote for that recoreder into another room or unplug the dvd recorder a moment. Then hold down the enter key and the number of the mode its stuck in ie if its stuck in dvd-1 mode hold down the enter key and then the 1 key. hold both buttons together for 3 seconds. After this go back into the room and try it or if you unpluged tthe player replug it back in. The remote has to be away from the player to work. again example
Mar 08, 2010 | Sony RDR-GX360 DVD Recorder
Can't get my sony RDR- VX535 out of the 2 mode. remote will not operate the recorder. i perchased this unit used on ebay. it played fine until i got it out of wack the remote with this unit is a sony...
Jul 28, 2009 | Sony RDR-VX535 Player
SONY RDR-GX3 region code unlocking
prepare: your one for all
2. hold magic button until flashes twice/comes out
3. enter device code 0533 (this programe the GX300 as the DVD choice in your one for all)
Now program buttons 1..5 with the following codes using the instructions below:
1 - 189
2 - 255
3 - 095
4 - 221
5 - 079
1. hold magic button until rabbit comes out
2. press 994
3. press magic
4. enter 3 digit code from above
5. press button (1..5) where to program it
6. repeat steps 1 to 5 for all keys.
have it a go:
1. remove disk, put player on standby
2. press 1,2,3,4,5 - success is displayed and plyer starts up
3. press 1,2,3,4,5 - player shuts down and BINGO!
Good Luck!!!
Mar 22, 2009 | Sony RDR-GX3 DVD Recorder
Sony rdr gx360 only responds by displaying "DVD3" to remote cntrl
http://www.docs.sony.com/release/RDRGX360_EN_ES.pdf
Page 23 in the manual. Had the same problem. Press and hold ENTER and 3 for at least 3 seconds. Problem fixed
Dec 17, 2008 | Televison & Video
Dvd recorder rdr-hxd860
press stop button then the power button together the player will go off. put it on again the remote should work.
Mar 15, 2008 | Sony RDR-HXD860 DVD Recorder/HDD Recorder
Sony RDR-VX535 Player Logo
2,033 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
