Question about Whirlpool 4.0 Cu. Ft. Plus Washer
Machine didn't empty water after rinse cycle. Now
Machine didn't empty water after rinse cycle. Now it behaves as though there's no power; nothing works and it's full of water
    Brigadier General:
  • 4,088 Answers
Check for power at socket using a lamp. If nothing, check the breaker for that circuit in the house electrical panel--push OFF, then ON. If now get light, try the washer again. If you get a loud hum from the machine, it may be a locked motor. Pull the plug again and check the motor. The tub can be drained by lowering the end of the drain hose below the interior water level.
Posted on Aug 01, 2009
Operation of machine wash, rinse, spin
at the end of the wash does it empty ok it needs to before it can move on to take on water for the rinses if it doesn't check the pump is not blocked if it does empty the issue may be water valve for cold water also on the wash cycle does the machine heat up if not it will just sit there washing forever
Mar 04, 2014 | Indesit Washing Machines
Kenmore Washing Machine Belt-driven, top loading Model 110-8228310 Stock # 22831 Machine was over- loaded. Machine Stopped in Rinse Cycle did not empty water. Cleared load. Made New loads, machine...
I'm surprised the main breaker didn't trip or fuse blow as the washer has obviously demanded a fair amount of current to 'slightly' melt the end of the cord!
Sorry but with such a fault it is extremely difficult for anybody on this forum to remotely guess what is wrong with your washer. It could be the main motor, following the overload, or drain pump/motor as primary cause followed by damage to internal wiring/plugs sockets, I fear that your only real option is a service call as the engineer will have the right equipment to safely diagnose what is wrong.
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Jun 27, 2011 | Washing Machines
Will not empty water
Good day,
That's always a bad lid switch. Check out this tutorial.
http://www.youtube.com/watch?v=fC8SY3cU1Yc
May 08, 2010 | Whirlpool Washing Machines
Power light and extra rinse rapidly flashing
Sounds like a cold water supply fault which could be the solinoid valve, the water turned off, a kinked or twisted cold supply pipe or a wiring fault. Check out the error code sequence here. You never said what make or model you have (the error codes are only for Hotpoint, Creda and Indesit machines)
Mar 20, 2010 | Washing Machines
Washer stop in middle of rinse cycle
All content © 2000 © 2009 Washerhelp
> Home / Repairs DIY washing machine advice (part 8) Washing machine sticks or stops mid-cycle repairs-sm.gif A very common fault on washing machines is when the program timer fails to complete the cycle and stops part way through. Many people blame the program timer for this but although it is a possible cause, there are many more likely causes for this fault. The program will stick if the heater isn't working, if the thermostat fails, if it can't fill up with cold water for the rinses, if it can't empty the water etc. There are too many possible causes of this fault to be able to give anything other than rudimentary advice. However, the common causes of a washing machine sticking that can easily be fixed are filling and emptying problems.
Check that the cold water supply is available to the washing machine, which is a common cause for sticking on rinses. If the washing machine appears to stop mid-cycle and isn't filling with water on rinses then see Washing machine won't fill with water (or no water goes into washing machine) before calling an engineer. If the washing machine can't drain the water out then it will stick on the rinses, or it will abort with an error code. If you can see water still inside the washing machine then check the following advice Washing machine won't empty water
Dec 02, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Maytag Top Loader won't work on Regular Cycle
I suspect bad motor windings. it has enough power to run delicate but not other cycles?
Nov 13, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Rinsing cycle won't START
After all, I turned machine off with power switch, waited 30 seconds and turned it back on. It displayed "RINSING CYCLE" message, but this time went through regular rinsing cycle, then rinsed thoroughly (I counted several cups of water) and RETURNED TO NORMAL.
Halleluiah! Now I can get my morning coffee again!
Aug 30, 2008 | Gaggia Titanium Espresso Machine
Bosch classixx 1000 washing machine - stops on spin
Washing machine stops at the spin cycle - light flashes. Have to drain water out manually. Happened last week and was then able to run an empty rinse cycle. Machine worked normally for another week. Same problem today but have had to drain water manually from the drum after trying an empty 90 wash and rinse cycle (both stopped on the Spin and flashed). Any ideas? Thanks. x
Apr 29, 2008 | Bosch Classixx WVF 240S Front Load Washer...
Inglis Washing Machine - Heavy Duty Extra Large Capacity
if it doesn't empty check the pump for blockages or just not working electrically, or check cold water supply to machine, or the cold water solenoid, this may also be faulty hope you can find what you need starting from the above, if i have helped please rate me
Oct 04, 2007 | Washing Machines
Whirlpool 4.0 Cu. Ft. Plus Washer Logo
79 people viewed this question
Sal De
Gerry Harvey
Gerry Harvey
