Question about Dryers
Dryer stopped I was drying a rug in the dryer and when I went out to remove the rug it was stuck in the side. I put more clothes in the dryer and now the dryer does not turn on. It makes no noise it does nothing.
  • 213 Answers
Some dryers have a switch thats attached to the tension pulley for the belt. if the belt breaks the dryer wont start. if the rug got stuck it probably broke the belt
Posted on Nov 25, 2007
I have a Samsung Dryer (DV218AEB/XAA) and it is not providing heat. I recently had the laundry room painted, so I needed to move the dryer away from the wall...the next time I went to use it, it wouldn't...
Check the circuit breaker for the dryer. There are 2 of them side by side with their handles joined. Sometimes one will trip but not the other. This stops the heating element but not the rest of the dryer.
May 10, 2017 | Samsung DV218AEW Electric Dryer
What is the bruning rubber odor - new dryer!
Im not familier with that particular machine but it sounds as though bits of the rubber backing you talk about has flaked into tiny bits and moved beyond the drum and into the workings of the dryer moter and heater. Contact with these will produce the smell and slight risk of fire.
The back of the applience will need to come off and cleaned out.How you accomplise this is up to you!!. If you have some one who is very handy at this sort of thing then grt.otherwise leave it to a proffesional. Obviosly compressed air gun is the way to do it.
Oct 15, 2013 | Maytag MEDE201YW Electric Dryers
I was drying rugs and one of the rugs got caught and the drum stopped turning. The power comes on but the dryer drum will not turn.
Hello, one possible cause of dryer drum not rotating is the rugs stuck between the drum and front panel.Secondly, maybe the dryer belt dispart.
Jul 31, 2013 | Sears Kenmore Elite Gas Dryer Front Load...
Kenmore Elite He3 dryer..fine on timed but leaves cloths wet auto
find the metal sensors in the drum
scratchem up with sand paper
especially if you wash rugs, sneakers , or anything with acyrlic
Oct 05, 2009 | Kenmore Elite HE4 Electric Dryer
Dryer problem
heating element or limit switch is out both are inexpensive to replace
Aug 20, 2008 | Estate EED4300SQ Dryer
Dryer stopped before clothes were dry and now it will not start again
possible bad thermal fuse remove back look for small white object on left side just above blower on side if lint screen housing with continuity checker ck to make sure there a closed connection through fuse
Jun 04, 2008 | Whirlpool LER3624JQ Electric Dryer
Dryer will not dry cloths
make sure that the dryer has the proper voltage going to it and if it does then check the heating element and the safety on the left top of the element housing
Apr 18, 2008 | Whirlpool LGR7646E Dryer
LG DLG2532 Gas Dryer will only dry on manual setting
If you use dryer sheets, LG recommends no.  Dryer sheets cause a film that will not allow the sensors to feel the clothes moisture during the drying process thereby causing the computer to countdown the timer quickly.  To clean out the sensors, use a green pad and scrub the sensor bars inside the dryer drum.  That should remove the film left by the dryer sheets.
Mar 12, 2008 | LG DLG2532 Gas Dryer
Dryers Logo
96 people viewed this question
Top Dryers Experts
