Question about Black & Decker Vacuums
MY Bissell Little Green Machine doesn't seem to be sucking as well as it should be ...dirty water is leaking out of the attachment used for **** it up (the brush) whats with that and what do I do? Thanks!
Well i see you wrote the question a long time ago but here is what I found. I have new carpet and we got a puppy. You know what that means. Anyway a lot of use and the new carpet gave up a lot of fibers. The fibers lodged in the "s" shaped portion of the suction line. You must remove the bottom (just 6 screws) to see this part. I could not figure out how to detatch the hose so i rigged a way to put air pressure though the head end of the hose and gentrly tapped the "s" shaped part with a plastoc mallet, clumps of fibers started to come out, eventually a real big one popped out and the thing was clear. What a pain it was!
Posted on Oct 10, 2009
How can I download Bissell Little Green Clean Machine manual?
direct
https://canada.bissell.com/support
or the first link has it, also videos
  • BISSELL LITTLE GREEN 1400 SERIES USER MANUAL Pdf ...
    www.manualslib.com > ... > Vacuum Cleaner > Little Green 1400 SERIES
    Bissell LITTLE GREEN 1400 SERIES User Manual. ... Vacuum Cleaner Bissell Little Green 1400 SERIES User ... Rcvd a used bissell little green machine w stagnant ...
  • Bissell Little Green Machine ' Walmart.ca
    www.walmart.ca > Walmart.ca > Appliances > Vacuums > Steamers
    • 4.1/5
    • 185 REVIEWS
    • $99.96
    Bissell Little Green Machine for sale at Walmart Canada. ... Powerful suction lifts stains and spots with water or any of the Bissell cleaning solutions.
  • Little Green® Portable Carpet Cleaner ' BISSELL®
    www.bissell.com > ... > Browse By Type > Carpet Cleaners > Portable
    The Little Green® portable carpet cleaner is produced with a minimum of 50 ... Coupon code for purchases on bissell.com: ... (including all accessories and manuals) ...
  • BISSELL LITTLE GREEN CLEAN MACHINE PDF - fenbook.me
    fenbook.me/get-it-free/b/bissell-little-green-clean-machine-manual.pdf · PDF file
    Get Free Read Online Ebook PDF Bissell Little Green Clean Machine at our Ebook Library. Get Bissell Little Green Clean Machine PDF file for free from our online library
  • Bissell Little Green Owners Manual ; Bissell Little Green ...
    www.youtube.com/watch?v=PpQji8obNz4
    • BY BOTHSHOOP
    • 4 MIN
    • 11K VIEWS
    2012-11-07 · Video embedded · Bissell Little Green Owners Manual ; ... Bissell Little Green Owners Manual ; Bissell Little Green Machine ... How to fix a Bissell Carpet
  • Bissell LITTLE GREEN 1400 SERIES User Manual
    May 24, 2016 | Bissell Vacuums
    Bissell little green leaks
    the tank where the water is has a crack in it mostlikely
    Sep 10, 2009 | Bissell 1425 Little Green ProHeat Handheld...
    Not sucking up dirty water
    Sounds like the suction motor is not working correctly. Either clogged with dirt or objects or it is failing.
    Check this first:
    Not suctioning properly, first check the motor duct gasket. To check this, first remove the tank and place your hand over the rubber square opening.
    If your machine does have suction at the duct, continue to check the following:
    Ensure the Ready Tools Dial is set to the appropriate setting (Floor Cleaning or Hose Attachments).
    Remove the tank from the machine and ensure the tank lid is attached properly. The front window must first hook onto the lip of the bottom of the tank and then drape over the tank. Latch the bottom tank to the top tank lid. THIS LID CANNOT BE
    ATTACHED PROPERLY IF THE TANK IS NOT REMOVED FROM THE MACHINE.
    Make sure the Water Tank is not full on the outside of the bladder. If it is, empty the tank.
    Ensure the hose is firmly attached to the back of the machine. If not, re-insert as necessary by twisting into place.
    The machine must be in an upright, locked position and set to the Hose Attachment setting. If the handle is slightly tilted back while using, it will create a small gap at the suction inlet (where handle meets gasket, above the Bottom Tank) which will cause little or no suction.
    Check the red Tank Lint Screen for debris. If the Lint Screen is dirty, the unit will have poor suction. Clean the Lint Screen if necessary.
    If the float flap door in the tank lid is activating prematurely when you turn the machine on, this flap door should be replaced.
    Check the Tank Lid and Tank for damage.
    If there is no suction there, please take your machine to a BISSELL Authorized Service Center for inspection.
    Jul 31, 2008 | Bissell 1699 ProHeat Clear View Upright...
    I need directions for using the Bissell Little Green.
    http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=723971
    Generic problem for all Vacuums
    Posted by jkcanger on Jun 30, 2008
    I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. If the instruction did not come with the Bissell Little Green Machine then I would contact the Bissell Factory that I will provide for you listed 2 the bottom of the answer,
    So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
    http://www.bissell.com/ Customer Service 1-800-237-7691
    Hours of Operation Monday thru Friday 8:00 am to 10:00 pm EST
    Saturday 9:00 am to 8:00 pm EST Mail To: Headquarters, Bissell Homecare Inc
    P.O. Box 3606 Grand Rapids. MI 49501
    Thanks, Don the Vac Man
    Go Ahead. Use Us.
    Jun 30, 2008 | Kenmore Progressive Bagless Upright with...
    Bissell little green steam machine
    There is a small pump inside the unit that may be bad.
    Dec 19, 2007 | Bissell 1200B Handheld Steam Vacuum
    Will not spray
    I have the same problem. I took it apart and found that the water pump had leaked and burned out the water pump motor. It's a $20 part.
    Aug 16, 2007 | Bissell 1425 Little Green ProHeat Handheld...
    Vacuums Logo
    181 people viewed this question
    Top Black & Decker Vacuums Experts
    GG TECHNOLOGIES
    Greg Cann
    Greg Cann
    Are you a Black & Decker Vacuum Expert? Answer questions, earn points and help others
