Question about Dell Dimension 4300 PC Desktop
Dvd/cd rom yes hello there i have a dvd drive that came out of a sony vaio and was tryin to put it in my dell 4300 dimension it reconiez it but still wont play a dvd i did the add hardware wizard and all if u have any ideas of what i can do to get it running in my system id be thankfull...Dwayne
    President:
  • 1,383 Answers
It is your dvd drive lense issue .If your computer is in warrenty take it to service shop they replaced dvd drive or lense.
If it is not in warrenty you need to repalce or repair dvd drive lense.
Also you can try 1 more thing pur chase disk cleaner disk and put it in dvd drive then play then it clean dust from dvd drive then check .
Posted on Aug 01, 2009
Hello i want buy solution cd-rom driver..... my
your drivers may have been corrupted or you might have a virus run your antivrus program
you might have to physically unplug the leads for this cd-rom then plug them back in this should activate the found new hardware wizard or
you might have to uninstall then reinstall your DVD/CD or uninstall the driver then reinstall for this device
click start control panel admistrive tools,computer management,device manager scroll down cd dvd rom drives right click you will see options to update driver,roll back driver,or
select properties you will have options under general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall
Jan 16, 2011 | Dell (074JH) Internal 48x CD-ROM Drive
Hello, I have Sony Vaio laptop model VGN-FS515, my internal cd -rom is not working, I've tried to reinstall computer's system from my external cd/dvd -rom, but can't do it because my BIOS doesn't support...
It sounds like you have done your homework, I suggest checking out ebay for a replacement for your CD-ROM, new would be better, but if you want to save money you might be able to scoop up a good used one at a cheap price.
Dec 19, 2010 | Sony VAIO Notebook
Will a Lite-On 22x DVD+/-RW Double Layer IDE DVD Burner Drive - IHAP122-04 fit in my Dell Dimension 2350 as replacement for my CD drive ?
Definitely, yes. Yes it will fit in your system without any problem. Just remove the Cd-Rom drive and install the Lite-On. If you need further help, let me know.
Good luck.
Thanks for using FixYa.
Aug 23, 2010 | Dell Dimension 2350 PC Desktop
CD-ROM drive doesn't acknowledge DVD-ROM, what's wrong?
CD-ROMs dont play dvd becuase they are not designed to read dvd.
If a dvd drive for your model is not available, you can buy an external usb dvd drive.
That should solve your problem
Dec 28, 2009 | Dell Dimension E521 PC Desktop
DVD drive bay
yes you should be able to play CD on the DVD reader.
Dimension 2400 have drive slide mounted on the side of the hard drive, cd drive and floppy. they are different for each device. you need the 2 side mount for the dvd. in order to mount them in the Dell.
the drive is inserted from the inside of the box toward the front. The front panel will prevent the device from pop out.
yes, 3 party DVD, CD drive will be shorter and fater that what Dell porvide, but it will work, al long as the opening is accessable.
get the HP DVD driver.
Nov 04, 2008 | Dell Dimension 2400 PC Desktop
Dvd drive in dell does not work
depending on the drive it can be your upper and lower registry filters, use this link at your own risk and whenever you work in regedit, make sure you create a recovery point before hand!
http://support.microsoft.com/kb/314060
Apr 03, 2008 | Computers & Internet
My Computer Wont Read DvD's or CDs!
Is the CD drive display in my computer? yes
then clean up your CD/DVD rom for there is dust in it, specially on the lazer lens that let the rom read the CD/DVD.
If no, then; Fix some cable connection towards your CD/DVD rom for it was lessen.
If not fix the problem verify the disc if it is readble by your Rom. Please try another disc in your Rom.
if same happen, then maybe its time for a new CD/DVD ROM.
one last try:
try your new purcahse disc in another computer that is compatible with your disc.
hope this help, melnavz
Feb 05, 2008 | Dell Dimension 3100 PC Desktop
Replacing a cd rom drive
put a little jumper lieka blue or green or white cap on soem pins on rear on CS and slide it in. bolt down. put ide cable red or blue edge closest to power socket. carefull with pins pushing it in should look even if looked at from lower angle against cdrom
heres the dell steps manual http://support.dell.com/support/edocs/systems/dim2350/replace.htm#1101572
Oct 17, 2007 | Computers & Internet
Dell Dimension 4300 PC Desktop Logo
50 people viewed this question
Alun Cox
