Question about Intel Ethernet 10/100 Network Adapter
When I connect the ethernet cable to my tower, I gave an orange light. What could be causing this to happen?
  • avalanchemcd Aug 01, 2009
    OK. The lower (led) light is solid orange. The upper (led) light is flashing yellow/orange. What may be the problem?
    Scholar:
  • 31 Answers
What Orange light are you refering to? You have an orange and green LED on the block of the Ethernet connecter, if the cable is plugged into the plug and the other end is terminated into another deive such as a modem,bridge,router or switch the orange light(led) should come on as that indicates a valdi link hence being called the link light, the green light(led) indicates data being received or transmitted. If orange flash with sparks(bad) from the plug it means there is power on the cable..very bad as this could be due to the ethernet card that is faulty or the device on the other end of the cable is faulty.
Posted on Aug 01, 2009
I have a belkin wireless modem router model F7D1401 v1 and a week ago it would be normal then flash orange and stop working. however now it is a constant orange with the WPS button flashing orange.
I think you have the upper light blinking and lower light solid. Is that right? The upper light blinking means that the connection to your ISP is not working. Try unplugging/replugging the Ethernet cable in the top port (probably yellow and labeled "WAN" or "DSL" or something). Check the other end of that cable. If you have another Ethernet cable, try swapping it out.
If none of that works, call your ISP to check the connection.
Apr 05, 2015 | Belkin Computers & Internet
Network fails through one port going orange
The ASUS site has a quick start guide (I read Version 3) that says the lights show blue for connections and blink blue for activity. Sometimes orange indicates a connection at a lower speed. What happens when you try a spare port? What is connected to the 'orange' port? What do the lights at the other end of the suspect patch cable indicate? Note that the manual isn't great because the titles say Gigabit Ethernet but the text talks about 10/100 but not 1000 megabit ethernet.
This is a layer 2 device and it ain't exactly the cleverest box on the LAN. If you move devices to other ports, it is supposed to figure that out dynamically. You should be able to eliminate devices one at a time to determine which port or device is defective. Start by eliminating the 'orange' device. If the router is disconnected can you still print?
If you have limited functionality with the suspect device disconnected, the problem could be with that device. Sometimes cables can be a problem. Not likely but it is necessary to check by substituting a known good cable on a link. If the problem goes away, it was the cable.
Remember to photograph the initial configuration with your smartphone. That can help you when you forget where you started. Label the wires with masking tape if there are no other labels, so you can find your way back to the starting point.
Nov 01, 2013 | ASUS GXD1081 Ethernet Switch 8 Port 8 x...
Hp laserjet m603n flashing orange warning light and says "ready" then changes to "please wait...checking printer" sitting like this for days now. When I reboot withought the ethernet cable it boots u
What do you mean by "When I reboot without the ethernet cable it boots u......?" It boot ok and the flashing orange light, stop? Try using a local USB connection to a nearby computer and see if it works.
Jan 18, 2013 | HP Laserjet 600 M603dn Laser Printer -...
How to fix orange blinking light on ethernet
orange blinking on ethernet means that your connection is 10 Mbps and green blinking means 100 Mbps
there's nothing wrong with it
Aug 27, 2012 | Toshiba Satellite M35X-S163 Notebook
Orange light doesnt let me use the internet
Make sure you have a good cable and you are plugged into the right port usually yellow for incoming signal(modem to router) and the ports go to any devices you have.
Aug 19, 2012 | NetGear WNR2000 Router
When I press the power on it makes a sound twice and the Harddrive button stays orange
This is a hardware problem. Try disconnecting all cables behind the tower then press and hold the power button for 10 seconds. After that try connecting just the power cable and turn on the pc. If there is no change (power light is still orange), it could be numerous things. like your power supply , memory, motherboard or processor. If it works then one of your external devices is causing this problem. If you can open your tower (just incase power light is still orange) try removing the memory and cleaning the contacts using a pencil eraser. Rub it to the gold contacts to clean it (please refer to the manual to do it).
Apr 22, 2011 | HP Pavilion p6210f Desktop 26GHz 6GB...
My dell zino has an amber power light. what can be the possible issue?
Apr 22, 2011 | Dell Inspiron Zino HD Desktop Computer...
Need help! Cannot access YAHOO and FACEBOOK,Thru tp link wired router (TL-R402M). Hope you can help me with my problem. Thanks! Jun Santos
try power cycle by removing the power of the router for one minute then plug it again. check the cable if all of it tightly connected to the specified port if it is a modem router it should have a 3 cable connected to it Phone line, Ethernet cable and the power adapter. the Ethernet cable should be connect to the back of your tower( computer). check you phone for a dial tone. check the light in the router like dsl , ethernet ,internet and activity. all of these must have a light.
Apr 14, 2011 | TP-LINK TPLink 4port ADSL2 Wired Route...
Can you explain to an idiot, which exactly what is the correct way to connect Powerline Adapters to orange livebox, I have connected Powerline Adapter to yellow ethernet socket is this correct with the...
Plug the PowerLine adapter into the wall
Plug one end of the ethernet cable into PowerLine wall adapter
Plug the other end of the ethernet cable into the Orange LiveBox
Plug the Orange LiveBox power adapter into the wall
Mar 09, 2010 | Powerline Ethernet Network Adapter
Cannot get on the internet
light should be green instead of orange. check in your device manager to make sure the driver is installed for the ethernet adapter, if it is then you know the motherboard is bad cause the ethernet adapter is connected to the motherboard.
If the driver for the ethernet adapter is not installed then go to support.dell.com and from there go into the drivers section, type in your model and then download the driver for your laptop and install it and then see if you can connect. If you do this and you still can't connect then that still means the ethernet adapter is bad and the motherboard would still have to be replaced.
Aug 09, 2009 | Dell Inspiron B120 B130 1300 / Latitude...
Intel Ethernet 10/100  Network Adapter Logo
973 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
