Question about Bosch Washing Machines
I just got a new Bosch 800 washer machine I hooked it up but the door want lock to start machine
    Top Expert:
  • Bosch Master
  • 49,781 Answers
Even though your Bosch washing machine is new, the door lock may be defective and will have to be replaced. It should be a warranty repair
Posted on May 21, 2018
Nitrotrike
  • 589 Answers
SOURCE: Bosch Nexxt 100 series washer wfmc1001uc
According to the manual, you have to:
1. Turn program selector to "off"
2. Turn selector to Drain or Spin
3. Press the start / pause
Wait until program ends.
Open door.
or
Press "start / pause" until the start / pause light flashes.
Posted on Jan 11, 2008
  • 1294 Answers
SOURCE: Bosch Front load Washer
Try some WD40 on the door lock.
Posted on Jan 26, 2008
SOURCE: Bosch WFMC3200UC
I'm having a hard time understanding what is happening with my Bosch. Mine is filling and then immediately emptying out. Then the door unlocks but the timer indicates 45 minutes left (or so) and the door lock light is still on. Usually the only cycle that spins now is the spin cycle, but this doesn't help me get the soap out of the clothes still in the drum.
When the machine fills but doesn't rotate, the water level seems low as well. I had a repair man out who thought it might be the door latch sensor needing replacing (honestly, my toddler was pushing that button repeatedly), but I don't think that's it.
What does work: I unplug it for a while. Then if I'm lucky and the laundry Gods are shining down on me, I can wash normally (usually I'm luckier on Permanent Press but I always used to use the Cotton side). However, once I turn the machine "off," that's it all the problems persist so I have to wash it all, one load after another.
Posted on Aug 20, 2008
beltronic205
  • 1474 Answers
SOURCE: Bosch Classixx 1400 Express does not start at all, does not fill.
fit new door interlock switch ..Take note of wiring 1st//
Posted on Oct 04, 2009
SOURCE: Bosch Nexxt Essence Washer
i have the same problem with a bosch at a rental unit i just moved into. the door is locked up until the 25 or 41 minute cycle depending on the cycle used.
$500 to fix the motor, YIKES! and its my responsibility, yikes again.
definitely a motor problem not a door problem.
Posted on Apr 09, 2010
Washing machine will not start / door will not lock
check first the thing on your door moves ok this the bit that locks in if ok then it may be your door lock
Dec 28, 2013 | Bosch Washing Machines
Bosch washer door is locked
Remove the cover on the lower right corner, you will see a white plastic pull cord. Pull the cord and pull open the door. Don't force the door, you could damage it. If that doesn't re-set the door lock you will need to replace the lock.
Pl click if helped.
Mar 08, 2013 | Washing Machines
Bosch washing machine WVT 126S, error F01 on the start. Please help
F01 means the machine thinks that you have pressed start and the door is still open, so, either the door is not completely shut or you will need a new door interlock (part number 182154) you can get the part by calling 0844 892 8979 (UK) or http://www.bosch-home.co.uk/customer-service/spare-parts-accessories.html. Or the connection to the door lock is not loose or detached.Hope this helps
Aug 28, 2011 | Bosch Exxcel WVT 2850 Front Load Washer /...
I have a bosch washer model wfk2401. i cannot get
door lock mechanism must have jammed in open position. unless the door gets locked, the wash cycle would not start. check the electrical connection in the door lock and physically verify the lock operates when commanded
Mar 19, 2010 | Washing Machines
How do you clean the drain in a bosch next 800 series washer?
Almost all Bosch machines have a manual drain trap that usually can be accessed from a small door in the front panel. Open the door and you will see the trap access.
Jun 05, 2009 | Bosch 3.81 cu ft WFMC530 1UC Nexxt 500...
Bosch WFK 2401 Need to slam door several times to lock door
Sounds like you need the electric "door interlock" replaced. It is a simple matter of seperating the front of the machine enough to unplug the interlock mechanism, remove the two screws holding the mechanism in place and remove it from the back, reverse the procedure to install the new "updated" replacement part (- Bosch #170935 btw. about $37.00 from Sears). - time: approx 1/2 hour if you aren't mechanically inclined.
Jan 24, 2009 | Bosch Classixx WFL 2462 Front Load Washer
start a cycle, once the door lock light comes on pull on the door to see if its really locked if not, you need a new door lock assembly
Nov 12, 2007 | Bosch WFMC2100UC Nexxt Essence Washer
Washing Machines Logo
763 people viewed this question
Top Bosch Washing Machines Experts
Marvin
Marvin
Craig Butler
Craig Butler
Carmen Mikulic
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
