SOURCE: Cub cadet Z Force 48 inch zero turn blades won't engage
I hope this will help you...under the side panels on each side of the mower, there are "reverse lockout safety switches", they are supposed to stop the blades when both handles are pulled back. If one or both of the switches are out, the deck will not engage. Also, under the right side panel (when sitting on seat) there should be 3 relay switches, the one closest to the motor controls the PTO., if this is out, the PTO will not engage.
SOURCE: Cub Cadet LT1042 PTO won't disengage
If its an electric PTO then the switch on the dash is bad, Its a lever type ungagement then the little break shoes that rub on the blade spindles are either worn out or mis adjusted.If it started when you changed the blade drive belt its possibly the wrong belt??
SOURCE: I need a wiring diagram for a 3165 Cub Cadet Lawn
My name is Dane and I am going to try to help you solve your problem. Here is a link to where you can find your 3000 series manual. The wiring schematics start in chapter 13.
http://www.mymowerparts.com/pdf/Cub_Cadet/Cub_Cadet_Service_and_Repair_Manuals/
I hope I've helped. If you found this information useful, please leave me some THUMBS UP as deserved. Thank you! Dane
Testimonial: "Dan was very helpful. Thank you for everything. You're the best."
SOURCE: NEED A WIRING DIAGRAM FOR
Hello, I hope I've helped. If you found this information useful, please leave me some THUMBS UP as deserved. Thank you! Dane
Here's a link to where you can find your 3000 series service manual. You will find the schematics starting in chapter 17. Please find your correct engine configuration to match the correct schematic.
