Question about Maytag MGR4452BDW / MGR4452BDQ / MGR4452BDB Gas Kitchen Range
As oven takes 10 minutes or more to light after turning on
    President:
  • 1,723 Answers
Do you have 'glow bar' ignitor? These can be causing the problem OR the gas valve.
Posted on Aug 01, 2009
Whirlpool gold oven
One must preheat the oven to the desired baking temperature. If the oven is turned on and the food immediately put in to bake, it will take longer to bake the first batch than the second and subsequent batches, because the oven need a few minutes to heat up.
In other words, the oven isn't at 350 degrees the instant you turn it on. It takes about 15 minutes for the oven to reach 350 degrees. I hope this helps.
Jan 20, 2014 | Kitchen Ranges
Unable to remove blown Blanco oven light bulb-stuck fast
I boiled the kettle, added the hot water to a tray and placed it in the oven, shut the door then left it for 10 minutes so it steams up the oven (make sure power is off first). Do the same again. Then get a multi grip spanner and place a kitchen rag over the cover and turn to the left. It does take a bit of force depending on how stiff it is, but the steam will loosen the cover. The steam also cleans the oven quite a bit too!!
Mar 04, 2013 | Blanco Ovens
How do I start the oven? I want to cook a pizza
Open the oven and make sure it is empty nod one rack is near the middle level. Turn the knob that says OFF to BAKE. Then turn the knob with all the numbers to the temperature that Theo Sri toons on the box tell you to use. Allow the oven to heat up for 10 minutes. It may beep when it is up to temp or a red light will turn off to let you know it is ready. Put the pizza in the oven on middle rack. Take it out according to box instructions ( usually 8 to 15 minutes). That pizza out by sliding it onto a plate. Turn off the oven and eat the pizza. If it is not done completely, leave it in longer next time. Enjoy
Jul 08, 2011 | Ovens
My Westinghouse 668 oven turned off in a recent power failure. I need to reset the time so the oven will work. How do I do it?
A lot of the time, particularly if you haven't got a manual, it is trial and error. I normally turn the oven to on. I then watch the oven indicator light as I manipulate the timer buttons/controls. It sometimes takes 5 to 10 minutes. Just try all different combinations.
Feb 12, 2011 | Ovens
Have a viking professional oven and it takes too
A weak oven ignitor will cause this problem. even though it eventually lights the temp has dropped considerably so you don't get consistent temp. turn the oven on and listen for the burner to light. should light within about 2 minutes. if not replace oven ignitor(s)
May 20, 2010 | Viking 27" Professional Select Built-in...
I turn on oven and can smell gas for a minute,then hear it ignite
I tapped on the valve a couple of times and it seems to work fine now.
Dec 09, 2009 | Kitchen Ranges
Oven takes 5 minutes to come on (ignite).
Replaced the igniter. The parts guy told me that the amperage changes with age and use; thus the igniter still glows, but it takes much longer to operate the gas valve with the reduced amperage. Cost - $70.14
Oct 18, 2009 | Tappan 30IN ELEC IGNa Oven
Oven stopped 5 to 10 minutes after pressing START
sounds like a wiring problem check your power source
Nov 29, 2007 | Whirlpool RF262LXS Kitchen Range
GE RANGE MODEL #JGBP35BEA2BB
Sounds like that ignitor is weak.  When the ignitor glows it builds up resistance to the gas valve for gas to come in.  If it sometimes takes 10 min then the proper resistance isn't there and this will give you that gas smell.  Replace the ignitor and this should solve your problem.  Can expect to pay $80 - $100 for the part.
Oct 14, 2007 | Kitchen Ranges
Oven will not turn off
it sounds like the pilot could be restricted and not heating the thermocouple completley,or the t-couple is weak.is there ant drafts hitting the oven?
Aug 02, 2007 | GE JGBP28SEHSS Gas Kitchen Range
Maytag MGR4452BDW / MGR4452BDQ / MGR4452BDB Gas Kitchen Range Logo
246 people viewed this question
Top Maytag Kitchen Ranges Experts
vince
gbob59
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
