Question about GE Refrigerators
ICE DOOR FLAPPER SPRING IS MISSING. HOW DO I REPLACE IT. MODEL# GSS25WGMDCC
  • GE Master
  • 19,396 Answers
You have to take apart the ice maker.
Use the diagram below.
Click on the picture to enlarge.
The spring you are referring must be part 330.
Here part and instructions to replace, scroll down the page.
Regards.
Posted on Aug 01, 2009
Can the flapper for ice be replaced?
Refrigerator model number? ice chute door replacement
26177815-rm0wrikgpdq1hfoxb3io2p34-3-0.jpg need your model number for the correct part Dispenser Door 8201756
APPLIANCE 911
Apr 27, 2016 | Refrigerators
I am trying to install a new heat motor on a frigidaire refrigerator model frs26zrg. I am having frost build up on front side of ice maker, assuming its from flapper not closing all the way.
I assume your frost is at the front of the ice bin? If so, your correct. Room temperature air is leaking in to a 0 degree environment and causing frost build up. First, I would see if the ice door closes 100% without spring by pressing your finger on the door. I've had bad ice doors that were warped. Next, inspect supporting rod and spring and make sure they look ok. An eye test should suffice. Next, without heat motor, the spring should keep door shut 100%. See if that helps, good luck!
Sep 18, 2015 | Frigidaire Refrigerators
Red light inside the freezer part stay on for my side by side Kenmore refrigerator
Hello William;
My name is Peter. I am a retired field service refrigeration technician.
The, 'Red' light is a infra red light. This light assembly on the right hand side of your freezer is the transmitter.
Directly across is the receiver. On the receiver is a spring loaded plastic flapper.
This is a safety device for your ice maker. When the freezer door is closed, the flapper is closed, allowing the infra red transmitter to complete the signal to the receiver. This allows the ice maker to discharge ice cubes. When the door is open the signal is broken, the flapper springs out blocking the circuit signal, and the ice maker will not discharge ice cubes.
There is a On/Off switch on the red transmitter. I do not know why you would want to turn it off. If you turn it off and the transmitter stays on then you have to replace both the transmitter and receiver.
Nov 11, 2014 | Kenmore Refrigerators
How to install spring on french door flapper/divider for Samsung RF266
On mine one end of the spring broke off in the hole on the door. It was on top of the hinge so it looked like a pivot pin. I found that this was the second hole for the spring. I pushed the end of the new spring up under the hinge and popped the broke piece of old spring out. Now I could see the 2 holes. You then need to put the spring into each hole. The hole on the flap also needs a white plastic sleeve if that is missing. that goes on the end of the spring and fits into the flap hole. Then the trick part is understanding how the spring works? If you put both ends of the spring in the holes and shut the flap, it now stays in position to close and be flipped open by the guide that swings it open to seal.
Good Luck.
Feb 03, 2014 | Samsung RF266ABRS Bottom Freezer...
I have the model ED5VHEXVQ Whirlpool side by side refrigerator and the ice dispenser flapper will not close all the way after dispensing ice which causes the build up of ice crystals inside the door. This...
Hello, Thank You for using FixYa. I will be helping you today.Alot of times the plastic clip breaks that holds the pin and spring for the flapper door the only way to fix it is install part 8201756 and it comes with directions.
Thank You and please rate my answer if it was helpful..
Jun 10, 2011 | Whirlpool 25.6 cu. ft. Side-by-Side...
Ice will not dispence thru door.
Without knowing the brand and model # I can offer the most common solution.
On most "pass the ice through the door" models there is a flapper door where the ice dispenses. The spring which holds this door closed when you are not dispensing ice becomes weak allowing the flap to stay open jsut a bit. This open space will create an ice dam in teh dispenser thus not allowing the ice to dispense. The repair is generally made by replacing the flap assembly.
All the best.
Nov 21, 2010 | Refrigerators
Door Ice dispencer Problem
First , remove the top freezer door hinge cover ( only held by 1 screw ) . Disconnect the plug there , to remove power to the door . Use a butter knife or flat head screw driver , and pry outward from the BOTTOM of the dispensor control plate . Disconnect the 3 plugs there and set aside . Remove the 3 or 4 screws holding the arm and cover in place , and slide out . Your problem , is probably a rusted coil and plunger , in the top right corner with 2 black wires going to it . The part # is WR62X10055 . Solenoid coil and plunger is the correct term for it . Cleaning will not work for long , only replacing will correct for a long period of time .
Apr 10, 2010 | GE 25.0 Cu. Ft. Side-by-Side Refrigerator...
Refrigerators Logo
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
