SOURCE: ran tractor out of fuel try prime got fuel to pump
you need to open the fuel line at the injector on the cylinder to get the air out of the line while still priming the pump ,its building back pressure and fuel cant get past the pump,another way would be is to remove the air cleaner and carefully get a spray container of diesel fuel and spray directly into the air intake and see if it will fire,if so it may pull the air lock thru when the engine starts and till it gets fuel from the pump directly and runs on its own
