SOURCE: Drive Lock Password for Hitachi HD in HP Pavilion zv5466ea notebook
probably a little bit late but I think I found a solution ...
1.pull the hard drive out of the laptop
2.boot computer into bios settings
3. set a new bios password and check lock computer
4.while the computer is on slide the HDD in the laptop again.
5. save and exit bios
6.fortunately in the next boot you will get your hdd back
SOURCE: i wanna change the password
Connect your router to computer with ethernet cable then you can access it with following default link. http://192.168.1.1 or http://192.168.0.1 or http://192.168.15.1 or http://192.168.2.1 If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it. Then it ask for user name and password. Type user as "admin" and password as "admin" or "password" or blank. Then you can see configuration page of router. If you are still not able to access router with above ip then you need to RESET it for that press RESET button for 10 seconds it is in back side of router then all settings defaults..Then you can access it with above method. . Then click on wireless->wireless security->WEP security there is code password note down it or enter new password then save setting s and restart router. then you can connect wireless with new password. Let me know if you need further assistance. Thanks for using FixYa.
SOURCE: my motorola c118 ask
Do not worry surely you can get the subsidy code for your Motorola C118 model mobile,
Just visit this site www.onlinegsmunlock.com/motorola-c118/rs7wp9 , it has the step by step instructions and simple methods for getting the subsidy code for your Motorola mobile from the network lock.......
