Question about Weight Watchers WW51 Chrome Style Precision Electronic Scale
CAL 0 keeps flashing across the screen - Weight Watchers WW51 Chrome Style Precision Electronic Scale
Phone keeps flashing internet has stopped on my samsung prevail how do i fix it
Bring the notification window up, up the top you will see WiFi , sound, when you come across Mobile data make sure it is turned on.
Aug 20, 2014 | Samsung Galaxy Prevail
How do you set this atomic clock C17D2090 (WIC#628865)
Instructions to set the C17D2090 atomic clock
A. To manually set the clock
1. Use the CAL/ALM button to toggle the display until it shows the calendar
2. Press and hold SET until the screen flashes "12hr"
3. Use the UP (antenna) and DOWN (alarm) buttons to change the settings
4. Press SET to set the value
This mode will let you set the 12/24 hours clock, the time, date and year. You should be in the right time zone before you start.
B. To set the alarm1 time
1. Use the CAL/ALM button to toggle the display until it shows the AL1 alarm time
2. Press and hold SET until the alarm time flashes
C. To set the alarm2 time
1. Use the CAL/ALM button to toggle the display until it shows the AL2 alarm time
D. To turn on alarm1
2. Use the DOWN (alarm) button to toggle the alarm on and off (a bell appears on the screen)
E. To turn on alarm2
F. To have the atomic clock set automatically
1. Press and hold the UP (antenna) button until a little triangle flashes on the screen
2. Wait for clock to set
3. To give up waiting, press the UP (antenna) button again.
G. To change the time zone
1. Tap the ZONE button to toggle between the 4 time zones
Aug 16, 2012 | Audio Players & Recorders
Shows 0.0lb no weight
Well I figured it out, just in case anyone comes across this. Turn it over, push the button on the top middle of the scale, hold, turn back over, wait until "C" appears on the screen, stand on scale, now it works. :)
Jan 10, 2012 | Taylor Biggest Loser 7206 Electronic Cal...
Atomic travel alarm clock. Model number C17D2090 WIC#693047. (No brand name on clock.) I am living in outside US time zones and can't manually reset my clock to the correct time. (I lost the instructions.)...
Mar 26, 2011 | Audio Players & Recorders
My vizio 32" flat screen keeps shutting off by
sound like the main board is starting to fail
Feb 21, 2011 | Vizio L32 32 in. LCD HDTV
We use the Ohaus CS 200 and it shows "E" (error?) What does that means and how can I get it to normal measure
Ours does that too. I hold both the "Unit/Cal" button and the "On/Off/Zero" button down at the same time until the "E" changes to "Off" then release both buttons at the same time. The screen goes blank. Then I hold down both buttons at the same time again until "Cal" comes on for a split second, release both buttons and the "Cal" switches to the normal "0" ready to weigh screen.
Feb 04, 2011 | Ohaus CS200 Standard room Scale 200g X1g...
Please tell me in E-Z words how to set the clock and calendar on the Canon MP11DX calculator? Manual instructions, which I cannot locate anyway, are absolutely unclear. Please HELP!
To set the calender: Press the Calender/Time button. Press and hold the Time Set button for 3 seconds; the first digit of the date will start blinking. Then type in the date as two digit number for the month and date and a 4 digit number for the year. Add a zero in front of the month or day if under 10. Then press Time Set again. Press the CE/C button to return to the Calculation mode
(hold for 3 seconds)
Thus for today [Cal/Time] [Time Set] 0 9 1 5 2 0 1 0 [Time Set] [CE/C]
For December 1, 2010 [Cal/Time] [Time Set] 1 2 0 1 2 0 1 0 [Time Set] [CE/C]
To set the Time from the Calculator mode, you press the Calender/Time button twice before pressing and holding the Time Set button for 3 seconds; again the first digit of the current time will blink. Then type in the time as a 4 digit number followed by the AM/PM button to switch from AM to PM or PM to AM. Then press the Time Set button again and then the CE/C button to return to the calculator mode. You will see an A (AM) or P (PM) to the right of the time as you set it.
So for 5:06 PM you type
[Cal/Time] [Cal/Time] [Time Set] 0 5 0 6 [AM/PM] [Time Set] [CE/C]
I hope this helps. You can find the manual here: http://www.usa.canon.com/cusa/consumer/products/calculators/printing_calculators/mp11dx#BrochuresAndManuals as a pdf.
(I'm using Cal/Time for the button that has an icon that looks like a 1 month calender on the left and a clock on the left.)
Sep 15, 2010 | Office Equipment & Supplies
Ice dispenser/Water dispenser not working
I will need to get your model number to help you better. Thanks Sea Breeze
Jul 26, 2009 | GE Refrigerators
Motorola v3i
Keeps entering 6's, tries to go online, tries to increase ring volume, keypad flashes....resetting by switching on/off or removing battery does not work. It's not water damaged. Help !!!
my v3i keeps connecting to the internet by its self and flashes error GPRS or somthing like that,across the screen and no buttons work at all, removing the battery is the only way to stop it. please help.
Have the same problem? Click Here
Nov 15, 2007 | Motorola Mobility RAZR V3i Cellular Phone
Weight Watchers WW51 Chrome Style Precision Electronic Scale Logo
44 people viewed this question
Top Weight Watchers Health & Beauty Experts
aravind shet
aravind shet
Andrew Taylor
Andrew Taylor
Are you a Weight Watchers Health and Beauty Expert? Answer questions, earn points and help others
