Question about Canon PIXMA iP3000 InkJet Photo Printer
Ink not working
Even though all ink containers full colours are coming out magenta
  • 3 Answers
Assuming that all your cartridges are clean. Then the next step is remove your print head and clean it. If you haven't done this before, it is very easy. First printer's remove your cartridges and life the lever on the upper right hand side of the print head. If you have done this, skip the next paragraph.
Gently remove the print head and put it in a container, and fill it with hot water. I usualy empty the contents of a small bottle of ink jet cartridge cleaner into the tub as well. You should see the ink literally seep out of your print head. It's best to leave it for a few hours, but if you can't wait, leave it for several minutes, and gently press a folded paper towel against the print head base. It should make a clean impression. Dry it and put it back in your printer. Test print.
If your inks are clean, and you have cleaned the head. It's unlikely, but there is an outside chance that the contacts at the back of the print head carriage could be dirty. Gently clean them with a cotton bud dipped in ink jet cleaning fluid.
If it still dosen't work, then it looks likely that your print head is damaged and will need to be replaced. You can buy replacement print heads on the internet for about £50 pounds. (UK)
However, with the price of printers falling, it might be better to cut your losses and buy a new printer. I would pay a bit more and go for the Canon IP4600 which is the nearest replacement model to the IP3000. It also has separate ink tanks and significantly a removable print head. The down side is that the inks are chipped, so if you plan to refill them, you will need to plan to buy a Canon cartridge ink resetter to keep your printer happy. (About £20)
Hope it helps.
Posted on Aug 04, 2009
* After refile ink yellow color does not print at all.(ip 2772) * How to setup CIS system for canon Pixma ip 2772. which contains PG810/CL811 cartridges ?
I refilled Canon cartridge CL-811. I filled all 3 colors. Magenta Cyan Yelloware flowing well,. Even if I wipe the cart on paper tissue, 3 colors are coming out (pink magenta and Yellow).but while printing yellow colour isnot printing,. Any idea how I can fix the problem?
Jan 20, 2011 | Canon PIXMA iP1800 InkJet Photo Printer
I am out of yellow, magenta, and cyan. I only want to print black. Is it possible to still print even though im out of those three colors? Both Black cartridges are full. The screen tells me that im out of...
I think that the Canon printers require the colour cartridge to be full so as to print B&W. In Some makes like epson it is possible to continue printing in B&W even if the colour ink is down.
Open properties of the printer and check to see the tools provided, if there is any link to cut off the colour inks .
Just my tip
Aug 30, 2010 | Canon PIXMA MP620 All-In-One InkJet...
Failure to print from computer in colour
I have a similiar issue that just started happening recently - the printer shows FULL inks but the PC thinks it has empty inks. I tried the * #, 123 reset hardware failures, but that didnt help. Printer run self diagnostics says all is fine....
I am using USB connections - and this has been fine for years, until now. Maybe a microsoft patch issue?
Jul 03, 2010 | HP Photosmart C6180 All-In-One InkJet...
My printer prints in the wrong color!
Check to see if the correct colour is in the correct place in the printer. You may have the Cyan and Magenta mixed up
Aug 18, 2009 | Brother MFC-465CN InkJet Printer
When I calibrate colour Magenta and Lt.Cyan fail to print
boil the head printer in a hot water for ten minutes and wiped it smoothly
Aug 09, 2009 | HP DesignJet 130NR InkJet Printer
Colour Ink Jet Cartridges emptying during a black ink print run
If you go to your printer properties, there should be a setting whereby you have to select the option to "PRINT USING BLACK CARTRIDGE ONLY". Make sure this option is selected, otherwise your printer will use ALL colors even if you only print black.
Let me know if you need any further assistance.
Best wishes,
Graemevm
May 07, 2009 | Epson Stylus DX6050 All-In-One InkJet...
Why is it that my printer won't work if one ink cartridge is empt
Hi, this is not a solution because I don't think there is one apart from buying new inks. Epson and all other inkjet printers do this to prevent the coloured print head nozzles from getting blocked. If they are not used for a long time the ink dries up and blocks the nozzles. Epson recommends printing at least once a month with all colours to prevent this. Whenever the printer is turned on it performs a head clean, this is why the coloured inks get used over time even though they are not used for printing.
Mar 31, 2009 | Epson Stylus CX7000F All-In-One InkJet...
I have a used C60. I have replaced both ink cartridges with Epson cartridges. When printing in color, the colors are not accurate. For example, red comes out yellow. Also, there are lines running through...
Hi there. The reason for your problem is that the colour cartridge contains cyan, magenta and yellow ink, plus a black cartridge of course. All the other myriad colours are produced by mixing these four basic colours. So, if you print red, it requires ink from both the magenta and yellow cartridges. Thus if your red produces a yellow print, it means your magenta is not printing. This can be due to a number of reasons, mainly an empty or faulty magenta cartridge or blocked magenta print nozzles.
If you wish me to help you with sorting out the lack of magenta, please post a new comment to this effect.
Mar 04, 2009 | Epson Stylus C60 InkJet Printer
Wont print ANYTHING if ONE ink cartrige is out
need to replace all to! some printers are like that wont print unless all inks are full and inplace!
Feb 26, 2009 | Canon Pixma iP6600D InkJet Photo Printer
Canon PIXMA iP3000 InkJet Photo Printer Logo
256 people viewed this question
old marine
old marine
