E
Elaine Lim Posted on May 21, 2018
When epson lq300+ii printer head not responsive
The lights are blinking and the paper out and pause lights too blinking with a long peep sound upon power on
5 Related Answers
Anonymous
  • Posted on Jan 28, 2008
SOURCE: epson r230 2 red lights blinking and wont print
download the epson ssc service util
http://www.softpedia.com/get/System/System-Miscellaneous/SSC-Service-Utility.shtml
install it set for r230 then using the tray icon right click the tray icon choose protection counter from the menu then choose reset protection counter then turn off the printer then turn the printer back on
Anonymous
  • 159 Answers
  • Posted on Sep 06, 2008
SOURCE: Epson LX-300+II, the font problem
yes you can change the font tray to print the printer internal setting tray that press and hold any key by tarn the printer off then on after you tarn the printer on release the key
Anonymous
  • Posted on Oct 27, 2008
SOURCE: Epson R230 ink & Paper Lamp Blinking
could someone show us how to open the r230? im having hard time cleaning the waste ink pad because i cannot open the r230..
Anonymous
  • Posted on Nov 24, 2008
SOURCE: EPSON LQ - 2180 paper settings
I HAVE CUSTOME SIZE OF PAPER WHICH IS NOT AVILABLE IN THE PRINTER LIST .WHEN I DEEL WITH WINDOS XP
BUT WHEN DEEL WIHTH WINDOS 98 ITS OK
NO I DONT HAVE WINDOS 98 . MY QUESTION HOW I CAN ADJUST PAPER TO CUSTOM SIZE
Anonymous
  • 5 Answers
  • Posted on Jul 01, 2009
SOURCE: EPSON LQ-680 DOT MATRIX PRINTER
problem with detector cable or detector sensor
Epson R265 - both red lights flashing fast, and simultaneously
When your Epson printer's print head is clogged , then the red light for your ink and paper out is blinking. In this movement, the printer print head is blocked due to foreign objects or jammed paper.
Fix the Epson printer red lights blinking error with simple steps.
Epson L800 all lights blinking, cannot print
Epson printer blinks both red and green lights, which means the paper gets jammed in your Epson printer. You can fix the issue using the steps:
·Check printer ink cartridge
·Check the printer print head and fuser
·Fix the paper jammed
Follow the
steps to fix Epson printer lights blinking error.
Epson 7010 all lights flashing & won't print
Epson printer blinking different lights. The different lights blinking has different meaning and solutions. When the Epson printer red light blinking that means ink cartridge of your printer is out of ink. And when your printer green light blinking that means paper gets jammed inside the printer.
You can fix the Epson printer lights blinking error using following steps:
·Check empty or damaged ink cartridge
·Clean the dirty print head or replace missing or failed print head
·Read the steps to fix the Epson printer lights blinking error.
PRINTER PROBLEMS 2 GREEN LIGHTS SIDE BY SIDE KEEP BLINKING. THEN THE PAUSE/ PAPER OUT LIGHTS ONE RED, ONE ORANGE ALSO KEEPS BLINKING. pAPER WONT AUTOMATICALLY FEED
There are several reasons for this problem. One is the paper tray is either too full or not closed properly. There is a sensor and if the sensor is faulty the same symptoms happen. It happened to me sometime back. How old is your printer? If it is within the guarantee period you should take it to the dealer and he will have to either repair or replace it.
Cx4500 lights blink and Error on display
The Epson Printer Light blinking error can be caused due to printer print head is overheated, low or empty ink tank, printer fuser not working and more. Follow the simple steps to fix Epson printer lights blinking error:
·Check printer ink cartridges
·Fix paper jammed
·Check printer print head and fuser
Follow more steps to fix Epson printer lights blinking error.
Paper jumping problems
kindly set the page length in printing setting just press the pause button and go to configuration setting mode and set the parameter as per your software or print file.
Hope this helps. Please rate my response.
Thanks.
Have a good day
17helpful
2answers
1helpful
3answers
Pause & ready led blink alternatly after initilize
Check if the paper type is set correctly (in thebackside right there is a lever to set continuos paper, or single sheets).
Top Epson Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
NH TECH
Level 1 Expert
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
