Question about AEG Lavamat Lavalogic 1600 Front Load Washer
Water will not drain properly leaving a very wet load ... screen says drainagae blocked
    President:
  • 1,273 Answers
Check two things:
Clean your strainer, located behind the kick panel at the lower front of the machine. It will be in between the drum and the pump, and will have a lid that unscrews.
Check your Drain Hose: The easiest way is to remove it from the house drain, and empty it into a bucket. If at all possible, point it outside and run a cycle with fresh water only.
The strainer will probably fix you up, and usually makes the clothes smell better too.
Best regards, --W/D-- please feel free to rate this solution..thanx!
Posted on Aug 01, 2009
When first driving forward there is a sound of rushing water heard from passenger front firewall area. is there an area that water can be trapped.
Yes there is. When your a/c runs it creates condensation which collects under the evaporator in a small collector, and then drains onto the ground. This is the puddle of water you will see under a parked car if the a/c has been running. If the drains are blocked the water will not drain away and you will hear water sloshing about. If it gets too full, the water will overflow and you will get water onto the front mats and you might get wet feet. You will need to find the drains under the car and clear what ever is blocking them. It is usually road grime and dirt. It might also be the drains at the front of the windscreen are blocked, although this usually wont end up in the car.
Jul 09, 2017 | Cars & Trucks
Kenmore Series 70 Top Loading Washing Machine Model # 110.20722991 Serial# CL 1134809 Hello, Our washing machine is leaving our clothes soaking wet when finished. What could the problem be?
2 things are possible. Can you tell if the spin cycle is engaging? If the spin cycle is not engaging properly or very fast, then the water will not leave the clothes. less likely is that the machine is not draining the water away properly or fast enough.
Jun 09, 2016 | Kenmore Washing Machines
Diagnostics ok but only spins slow
Water pump screen is plugged. Will not drain properly even though it goes into high spin.
Mar 14, 2014 | Kenmore HE3T Washer
Kenmore washer model 15862400 leaves clothes really wet, why
Possibly a blockage in 1 of the outlet pipes or pump causing water not to drain out properly.
Dec 22, 2012 | Kenmore 24032\24036 Top Load Washer
LOAD TOO WET AFTER SPIN CYCLE
  • NOT DRAINING PROPERLY
  • spin bowl not turning
  • spin bowl slipping and not gaining proper speed
  • pump blocked
  • pump not working
  • too much soap used
  • take out pump and check all the water ways
  • observe the spin bowl turning
  • Next call for pro help
Apr 01, 2011 | Kenmore 23822 Top Load Washer
Doesn't wash dishes properly and leaves some soap powder in holder
water is there enough in there and if so does is syphon out after a while, my guess is the drain goes down thru the floor, not good if it does
Jul 28, 2010 | Kenmore Dishwashers
Washer is not draining properly. Goes through the wash cycle but does not drain leaving a small puddle of water in the tub...along with wet clothes.
If repeating the drain/spin cycly reduces this problem, it's probable that the pump filter is partially blocked. Assuming the washer is front load type, the pump filter is accessed by a small door at floor level. Undo the filter cover and clean the filter of debris. Be careful, because any water in the machine will flow out at this point. Leaning the machine back can reduce this...Good luck....Nomess
May 12, 2010 | Washing Machines
Laundry comes out very wet
Hello tcburns07,
If possible, can you cycle a very small load of wash ( perhaps a towel or two) on the lowest setting to validate that : the washer is spiining up to normal speeds while draining water and that the water being drained is complete? Chancves are you have a either a blocked filter that limits water from completely draining, something in the drain pump or a restriction in your drain system. You could also have a worn belt that drives the pump. The test I suggested will at least determine if your washer is capable of draining all of the water from even a small wash load. Try that and let me know the results.
Regards,
Rick
Nov 23, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Cycle is leaving loads of soaking wet clothes
Power off the wall. Get user's manual, look for blocked filter. Open up the filter, usually front bottom right side, clean, refit. Be prepared for much water to come out. The filter requires periodic cleaning according to usage.
Also possible your hose under the machine tub is blocked.......
Dec 23, 2007 | LG WM3677HW 3.7 cu.ft. Front Load Washer...
Front load washing machine
There's usually a little drain hole tucked away out of sight at the lowest point of the gusset between the inner and outer seals. Before you try anything else, suggest you check this hasn't got blocked with wet lint (the place I'm trying to describe is the bit that's filling up with manky water). A.
Mar 28, 2007 | Frigidaire GLTF2940ES Front Load Washer
AEG Lavamat Lavalogic 1600 Front Load Washer Logo
289 people viewed this question
Top AEG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Einar Axel...
Einar Axel...
Level 1 Expert
Are you an AEG Washing Machine Expert? Answer questions, earn points and help others
