Question about Toshiba 42HP83 42 in. HD-Ready Plasma Television
No power I have a Toshiba 42hp83 plasma that will not power on.I am getting 120volts from the power cord but no power to tv.Any help would be appreciated.Thank you.
  • 2 more comments
  • lee777 Nov 27, 2007
    I am not sure where these are located.I do know that I am getting power from the wire and it is running to the coil next to it but,that"s it.Shop is asking $500.00 to fix it.I took electronics in college and I do have some knowledge of how circuits work.I would really like to fix this myself.I have been combing the web looking for a schematic but, with no luck.
  • lee777 Nov 28, 2007
    found service manual with schematic.Checked the areas you suggested and they are fine.I am still getting no power.
  • lee777 Nov 29, 2007
    It states that the main power board is bad.Ptf-422.I checked to see if The tv was getting power to the lowb1 board and it had no voltage in the wires.
  • Anonymous Sep 08, 2008
    my tv will not power on
  • 934 Answers
Something VERY common in this unit that can cause multiple problems, depending on the pins involved, are bad solder connections at PF01 on the micon module and socket PJ109 on the scaler module. Symptoms include; dead set, no picture, picture all one color, intermittent picture or shutdown.
If you do it have a good light and a quality magnification of some type. If you have a shop do it take it to them and ask for an estimate first.
Good Luck!
Posted on Nov 25, 2007
  • William Rayburn
    William Rayburn Nov 28, 2007
    I ass-u-me you got a written estimate? What does it show for parts requirement?
  • William Rayburn
    William Rayburn Nov 29, 2007
    That's it then - the SMPS has failed and that's only a modular replacement or rebuild and that's why the tech is charging $500.00 because the board is fairly expensive.. I show that as Toshiba p/n# 23122442 at $299.95 plus shipping and core. If the shop quoted you $500.00 that's a real bargain and I'd strongly consider letting them make the repair for several reasons - not least of which is the repair warranty they'll give you on parts and labor.. If you're still insistent that's the part you need. But I would be extra careful powering this up after replacement. Use a variac to bring it up at 90v until you know that there is no other shorts or failed components that could have contributed to the SMPS failure.
My Toshiba 42hp83 has a rectangular area of the screen that changes colors randomly from the left-center of the screen down to the bottom. After about 20 minutes of the TV being on, the problem usually...
We had a similiar issue with our SAMSUNG Plasma TV. It had a 2'or 3" vertical bar of random colors on the right side of the screen. It would also go away but then come back. Fortunately for us the TV was still under its original 1yr manufacturers warranty. We called the customer support and they scheduled a service call. The TV repair man took our TV to the shop and replaced the defective components. It took about 3 weeks for the repair.
Nov 06, 2010 | Toshiba 42HP83 42 in. HD-Ready Plasma...
I have a 42hp83 toshiba tv n when turned on i get pixils at bottom and blotchy pixils all over screen..
Check the connections to the TV, try to double check if the input source is good and does not carrry any video noise. the next thing would be a fault within possible with the drive, a screen failure or a processing fault..
Jun 29, 2010 | Toshiba 42HP83 42 in. HD-Ready Plasma...
I have a toshiba 42hp83 that is getting no power whatsoever not even a stand by light.
Check ur power source?Buy a refurbish power supply board at, for the replacement.
Apr 18, 2010 | Toshiba 42HP83 42 in. HD-Ready Plasma...
Screen went black and power light flashing on a Toshiba Plasma 42HP83
Manufacturer Toshiba Part Number 23122442 Description POWER UNIT ASSY, P
Jan 19, 2010 | Toshiba 42HP83 42 in. HD-Ready Plasma...
Direct TV says that they will offer 1080p quality. Need update
1080I and 1080P is more than a software difference. It is a hardware difference in the TV's capability to display a progressive picture at that resolution, so no software update will be able to help you. The processors are only capable of 1080 Interlace, and the TV is only capable of 720 Progressive or 1080 Interlace at it's maximum performance.
Hope this helps you...
Jan 06, 2009 | Toshiba 42HP83 42 in. HD-Ready Plasma...
Toshiba 42hp93
Press the MUTE button twice on the remote control, then press and hold the MUTE button, while pressing the MUTE button press the MENU button on the TV at the same time. This should get you into the service mode Good luck and be careful.
Oct 26, 2008 | Toshiba 42HP83 42 in. HD-Ready Plasma...
Problem with Toshiba 42HP83 Plasma TV
Just on a whim I'd say you have video out put circuits in distress.
can you say WARRENTY lol
Aug 24, 2008 | Toshiba 42HP83 42 in. HD-Ready Plasma...
Green line on each side of the plasma display.
Anybody knows how to reapair about vertical color- stripped lines appeared on screens and some trace of greenish images exist after each images changing, my TV is Toshiba Plasma Color 42HP83, I appreciate , thanks
Jun 05, 2008 | Toshiba 42HP83 42 in. HD-Ready Plasma...
Toshiba 42hp83 plasma power supply problem?
I had the same problem. It turned out that one of the cooling fans get dusty and does not work. I opened the back of the Toshiba plasma TV and cleaned the failed fan, and it worked like a champ.
Nov 05, 2007 | Toshiba 42HP83 42 in. HD-Ready Plasma...
Toshiba 42HP83 42 in. HD-Ready Plasma Television Logo
180 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
