I have the vertical lines on my vizio plasma tv. I notice that the lines starts on the left and ends up on the right. I started with one line now I have four. Can you help
  • 5,138 Answers
In order for me to help you I need the Model number to your TV it will be on the back of set. Thank You
Posted on Dec 09, 2009
Vizio VW46LFHDTV10A vertical lines on either side of the screen. I tapped screen and left side lines disappeared.
If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Oct 27, 2016 | Vizio VW46LFHDTV10A 46 in. LCD TV
How do I fix vertical lines on my TV?
Line Defects On Vizio TV Screens - Vizio TV Help
vizhdtv.com/line-defects-on-vizio-tv-screens/
Aug 26, 2015 - If you see a line on your TV screen it might be the result of several causes. Some might be simple to fix and others may actually require you to replace theTV. Pixels on a TVs display panel are organized in groups of straight vertical lines. ...Notice the line defect above is red but they can be white, green, ...
how to repair vizio lcd tv vertical lines then fail - YouTube
? 17:05
https://www.youtube.com/watch?v=YUKMl7_19gk
Jul 5, 2014 - Uploaded by bam6972
how to repair vizio lcd tv vertical lines then fail ... I do know quite a bit, not everything but I do know my fair share about tvs. this tv needed a new ...
TV Repair Help for Vertical & Horizontal Lines on Your TV ...
? 2:47
https://www.youtube.com/watch?v=b0sI7LB4cZE
Apr 25, 2014 - Uploaded by ShopJimmy.com
TV Repair help with troubleshooting lines on your TV Screen. ... I have Vizio M470SL. My TV has .... Why does my T.V. suck Don't buy Rca T.V..
Jan 19, 2016 | Vizio E480-B2 48" 1080p 60HZ LED HDTV
Any idea on what is causing these issues with Vizio TV? Black lines horizontal, shadow vertical.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent. Line faults to all LCD TVs will be similar, irrespective of its screen size and brand.
Jul 27, 2015 | VIZIO M701d A3R 70 Inch 1080p Smart
Multiple vertical white lines
hi,
As you mentioned its sounds like the X buffer (Right and left) of your tv is faulty. There are two boards in your tv for driving the X plane of the plasma panel. Normally you can find these board on the top or bottom portion of the TV. . Its part numbers are Right buffer board is 6870QSC107A 6871QRH073A and Left buffer board i EAX35683901 EBR35855501. Before purchasing the boards identify which board is faulty. That you can find easily. Check which portion of the screen have vertical line in right or left side of the panel. The board for that side is faulty.
You can find these boards on the following link.
http://www.interliquidparts.com/products-page/plasma/vizio-p50hdtv10a-50-plasma-hdtv-flat-panel-xrlbt-xl-eax35683901-ebr35855501/
http://www.interliquidparts.com/products-page/plasma/vizio-p50hdtv10a-50-plasma-hdtv-flat-panel-xrrbt-xr-6870qsc107a-6871qrh073a/
If you need any more assistance feel free to contact me through fixya.
Ajin
Dec 12, 2011 | Vizio P50HDTV10A 50 in. Plasma HDTV
I have a vertical black line on the middle of the
You have A buffer board out if the line goes up and down then its the long board going left from right look were the line is and see what board the line lines up on the screen and replace that one
these boards are the closet to the edge of the tv
same process if the line goes across the screen
look for the part number on the board and search with google or go to shopjimmys.com and seach there or call them
Oct 19, 2009 | Vizio Televison & Video
I have a 42" Vizio picture has an annoying thick red line
Ur backlight inverter video board is dying.
Need a new one.
Sep 22, 2009 | Vizio P2 42 in. HD-Ready Plasma Television
VIZIO P42hd PS42a plasma Picture has two vertical lines (one red/orange, one blue) going down the right-hand side of the screen. Lines are clearly visible
The panel is almost certainly bad. The only fix for this is to replace the whole panel which would cost more than the whole TV.
Mar 30, 2009 | Televison & Video
Vertical lines on screen
1. Frist on the BURN MODE.
2. Check whether same
Vertical lines on screen ?? 3. If yes ..?
4. Then change the LOGIC BOARD or PDP
Jan 11, 2009 | Hitachi 42HDS69 42 in. Plasma Television
Red line on screen
I had the same problem -red, vertical bars along the right side of my Samsung 42" Plasma- and this is what fixed it: Removed unterminated cable.
I had hooked up an HD video camera to the set about two weeks ago.  While I disconnected the camera I left the other end of the connector cable plugged into the T.V..  As I've since learned from friends who work in television, this is what's called an "unterminated cable" -meaning one end is unconnected.  It can lead to problems with electrical interference and appears to have been the problem in this case;  When I disconnected this cable from the T.V. the red bars went away.
So, check your cables.  Make sure everything is properly connected and get rid of anything that might be picking up interference.
Hope this makes sense.
Sep 29, 2007 | LG 50PX4DR 50 in. Plasma TV
Televison & Video Logo
16 people viewed this question
Top Televison & Video Experts
Electro Med Services...
