SOURCE: setting time and date crown positions
Yes, you must unscrew the crown before you wind up or set the watch. Always screw the crown down afterwards this keeps the watch in a water resistant condition.
SOURCE: I am unable to return to the 0 crown Position - TAG-CAF2112
The aquaracer has a 'screw-down' crown. This means that the crown needs to be screwed in the reset it back to the 0 position.
SOURCE: set time and date
You can get instructions from the Timex web site "timex.com".
At the
bottom of the screen click on "manuals/downloads", then on "product
manual download"
Enter your watch type in the search box and click on "search"
Press and hold the "Set" button for 2 seconds. The "Set" button is on the lower right side
Press the "Date Advance" button on the upper right side. This will reset the seconds.
Press the "Change Mode" button on the lower left to set the hour. The hour will flash. Press the "Date Advance" button until the correct hour is displayed.
Press the "Change Mode" button again to set the correct 10s unit (first digit 1 or 0) for the minutes. Press the "Date Advance" button until the correct first digit of the minutes is displayed. Repeat this step to set the second digit of the minutes.
Repeat Steps 1 through 4 of this section to set the year, month, date and day and whether to use 12- or 24-hour time for your watch.
When finished, press the "Set" button (on the lower right) to return to the current time view and lock in your settings.
