Question about Panasonic Televison & Video
Picture visible only during fast forward
Blue screen when tape is played; picture visible only during fast forward
  • Panasonic Master
  • 458 Answers
You have dirty heads, hence the blue screen, either try using a head cleaning tape, although these do not always do a through job, or if you remove the top cover & using a head cleaner fluid, VERY GENTLY wipe the heads at the sides of the round silver drum using either a head cleaner stick with the fluid or a piece of sturdy card. DO NOT put too pressure against the head or you will damage them completly & would need replacement heads. Leave them a few minutes to dry then try playing a tape once more.
Posted on Aug 01, 2009
I have a sony handycam camcorder and at first it said to reinsert tape so I found this website and it said to smack it around lol!! so I did, well it took care of that problem however now its a blue screen...
Hi it seem for me thats is the mechanism defective ;pinch roller as to be replace and the mode switch plus a good clean up of head system all of them....
Hope that will help you
Regards Allan..
Sep 24, 2010 | Sony Video Cameras
Vhs tape won't play
sounds like to me the tape is to tight .try rewinding the tape all the way then fast forward all the way till it stops repeat and it should loosen up. if not the tape is no good the blue screen might go away after the tape is loosened n try cleaning the tape player good luck
Sep 19, 2009 | JVC DF420 D-VHS Tape
Play back fuzzy
It looks like dirty video heads. Put brand new tape on camera and play it all the way to the end several times if necessary. It will clean the video heads. Good luck!
Nov 24, 2008 | Sony Handycam CCD-TR517 Camcorder
Cannot play tape.
Sometimes that happens to me too. What I do is just push play, then fast forward, and normally if you watch it, the picture starts to come back. Just keep fast forwarding until you can see all of the picture, and you should be fine.
Mar 24, 2008 | Panasonic PV-GS19 Mini DV Digital...
VCR problems on my new Hannspree HDTV
It is unlikely that you will be able to solve this issue. This is due to the way a digital TV works.
The output from your VCR is an analogue signal - a constantly varying electrical signal carrying information about the picture. This is interspersed with a synchronisation signal that tells the TV where the start of each frame begins within the stream. With me so far?
When you fast-forward a tape, two things happen: the sync signals appear faster than expected and bars of static noise appear across the picture (I won't go into the technical details as to why!)
On an old analogue TV this isn't an issue - The way they work means that they will display some sort of picture. In other words, whatever signal is coming in (no matter how corrupted) it will show it on the screen.
Digital TVs are different. They have to read all the information for each frame and process it before it is displayed. When you fast-forward the tape (and the sync signals are at the wrong speed and interspersed with noise) a digital TV gets 'confused' - It cannot make sense of the signal, so ignores it, acting as if there is no signal at all (hence the blue screen).
Most VCRs are designed to retain enough of the signal that some sort of picture can be displayed while fast-forwarding. However, because you are recording in LP mode (which effectively halves the normal speed of the tape and also reduces the quality of the recording) there just isn't enough information in what is left for a digital TV to recognise as a 'proper' signal.
Your only option is to revert back to SP mode, or treat yourself to a new digital recorder :-)
Hope this helps,
Matt.
Mar 05, 2008 | Televison & Video
VHS tape won't play or rewind
I work at the History Channel and have  a VHS that had the same troubles. I need it desperately for the show I am working on. I tapped it on a table fast forwarded it and presto! Tape fixed, crisis averted. Thank you, Thank you, thank you.
Feb 28, 2008 | Televison & Video
No Picture on playback
alignment is offset, should be easy fix with you local electronics repair place....if you need a cost estimate let me know model
Jan 20, 2008 | Video Cameras
No playback on DCR-TRV103
In playback mode the lCD displays the battery time, hi8 symbol and the tape counter. all the functions work the tape will play, rewind, fast forward. The screen stays blank on playback and the tape counter stays at 0:00:00 eventhough I can see the tape turning. I also hooke the camera to my tv and I got no picture.
Dec 23, 2007 | Sony Handycam DCR-TRV103 Digital Camcorder
No Picture, sound or anything during playback...
cleaning cassette may help - if the picture comes back but soon goes blue screen ? your heads need thorough cleaning or replacement ;
Jul 30, 2007 | Canon ZR100 Mini DV Digital Camcorder
Televison & Video Logo
177 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
