Question about Archos 5 MP3 Player
I have an archos 5 and and it stay on the begging screen
I have an archos 5 and when ever i turn it on it stay on the same screen and keep making a beeping noise. Then it turn off a few second later and turn back on and does the samething over and over. How do I fix it?
    Problem Solver:
  • 14 Answers
try hitting the reset button as a first step when it comes on. You might have to do a hard reset. Make sure you have either your original firmware or the latest from Archos saved on your desktop. When you do a hard reset if it comes to the Archos screen hold down the volume+ button until the white recovery screen comes on. If you have data you don't want to lose in it you might be able to save it if you try the repair or recovery function but if they don't work you will lose everything if you have to format. You probably will have to format sorry for the bad news but try everything first before formatting.
Posted on Aug 24, 2009
Archos 5 not working, will not switch on.
Hi I would think the best place to start is with ARCHOS,
give them the lowdown and see what they come up with.
You could use the Archos forum and look through the help files
Apr 13, 2010 | Archos 5 MP3 Player
Broken screen
Here are a couple of links of were to get a replacement LCD Screen.
It should come apart fairly easy and the lcd ribbon should unplug so then you can place the new one in and plug it in.
I hope this helps to give you an idea of the cost.
http://shop.ebay.com/i.html?_nkw=Archos+5+lcd&_sacat=0&_trksid=p3286.m270.l1313&_odkw=Archos+5+screen&_osacat=0&bkBtn=
http://shop.ebay.com/i.html?_nkw=Archos+5+screen&_sacat=0&_trksid=m270&_odkw=Archos+5+lcd&_osacat=0&bkBtn=
Apr 04, 2010 | Archos 5 Internet Media Tablet
Stuck on the ARCHOS Screen and it won't do any thing
A) Download the firmware from Archos and save it to your desktop (Make sure the file name on the desktop hasn't changed from the original download file name)
B) The Archos 705:
1- Connect the unit to its power source.
2- Start the unit in recovery mode: Press the TV button first then the power on/off and keep pressing TV button (do not release it)
3- The recovery mode will start (the screen that asks for repair or format etc…)
4- Select "Repair" by scrolling up and down with the TV Button (it is all explained to move through the menu at the top of the Archos screen) (Do not press "Format" at any time)
5- Now that you are on "Repair" select it to validate your selection
6- The unit will go to "Plug the unit etc…" plug it with the USB cable to the computer
8- Wait until Pc should recognizes your Archos (around 5 seconds)
C) Computer
1- From your computer select the firmware file you downloaded from the net and put it in your Archos (in the root folder, nowhere else, where it has the folders, music, videos, pictures etc… as a file)
D) On the Archos 705:
1- Select "Ok" on the Archos (on & off button) shortly to select and confirm the file is now on the Archos
2- you are done! The Archos 5 or 7 should now read through the file you have transferred and repair the system
3- DO NOT DISCONNECT the power cable until the process is finished
4- When done safely disconnect (as you usually do, for Mac trash the letter of the Archos to the bin or for PC's: right click the green icon bottom right of the screen for xp & vista)
5- Press on/off button to reboot
Your unit should restart with a fresh repaired, updated system like day one.
Jul 24, 2009 | Archos 704 WiFi Digital Media Player
Audio slider does not work
I have the same problem. After trying the adjust the volume on the screen, it went all the way down and slided back to mute everytime after I pulled it up. The volume button on the right didn't work either. I called Archos tech support on Feb 13, 2011 and they said they no longer fix this product because it's 4, 5 years old. But they would offer me a 15% discount for an upgrade. Why would I want to buy the same brand again if it's so unreliable?
Mar 27, 2009 | Archos 605 WiFi Digital Media Player
Getting a white screen with 102 error message
I fixed my son's 605 4 GB had Recovery code (104) on it. This might work for other error codes too. These are the steps i followed
* Use the computer for this process that you always used for this archos Archos should be plugged in toPc before starting the process.
* Download the firware Upgrade 2.1
* Plug the Archos to Pc
* When the white option screen comes up pick the format disk
* Wait until all done do not pick any option on archos after format is done Pc should recognize your archos in 5 seconds
* Put the firmware in root section of the archos not in any folder.
* Safely remove the usb for Archos from your pc first and then unplug the cable.
* Do not pick any option on the Archos screen
* Just turn it off from the power button by holding it until it turns off
* Wait about 5 minutes and plug it back to pc
* it will come up with white screen again but this time it will start Update you will see the progress bar moving, wait until it is all done, it will shut off. Turn it back on and  your archos will be back to normal
Mar 13, 2009 | Archos 605 WiFi Digital Media Player
Archos 5 frozen screen
I have found a solution for this issue, if you hold down the volume button and the power button for several seconds the Archos goes into a restore type mode. You then plug it into your computer and download the latest firmware update and cut and paste it onto the archos removable hard drive icon that appears in my computer. It will take a few minutes to update but then it will work perfectly.
Feb 03, 2009 | Archos Internet Media Tablet MP3 Player
Just got Archos 5 goes into error 101...
Hi there, these instructions are for the archos 705 but they are the same for the 605.
B) The Archos 705:
C) Computer
2- you are done! The Archos 705 should now read through the file you have transferred and repair the system
Jan 21, 2009 | Archos 605 WiFi Digital Media Player
Touch screen not working
after reseting my archos 605 my touch screen has stoped functioning properly i youch 1 part of the screen and it keep going to my menu bar i hit video it will open the menu bar or any part of the screen i touch it opens the menu bar
Oct 16, 2008 | Archos 605 WiFi Digital Media Player
MY ARCHOS PLAYER WONT WORK
Just watching a movie and my archos just froze in mid play , did a switch off to rest it and guess what it wont restart , ses ARCHOS in green at the start but wont reeboot have tried the reset button inside but no joy what so ever , any tips or advice 'or shall i just ship it back to Archos ....
Jan 05, 2008 | Archos 605 WiFi Digital Media Player
Archos 5 MP3 Player Logo
212 people viewed this question
Top Archos Audio Players & Recorders Experts
kaiserh1
 Grubhead
Grubhead
Are you an Archos Audio Player and Recorder Expert? Answer questions, earn points and help others
