Question about Uniden Cordless Phone
Model #26938GE1-P phone won't ring=no sound when press other buttons, but can still talk/hear through it...and YES ringer is turned on.
Our phone wants area code.please tell us about area code
Posted on Dec 04, 2009
Need ringer on uniden ex14246
With the phone in standby mode (not talking, not doing something in the menu, etc), press vol-up or vol-down. The phone will sound the different ring tones at different volumes. To turn the ringer off,
select "Ringer Off". When the phone sounds the ring tone and volume you wish to use, press the end key.
Oct 14, 2011 | Uniden 2.4 GHz Cordless Phone System
Somehow the ringer got turned off. Can't figure
Adjusting the Ringer, Earpiece and Speaker Volume
Adjusting the Ringer Volume
You can choose from four ringer volume settings (off, low, medium, and high) separately on each handset or the base.
With the phone in standby, press or on the handset or VOLUME or VOLUME on the base. The handset or base sounds the ringer at that level.
Use on the handset or VOLUME on the base to make the ringer volume louder. Use on the handset or VOLUME on the base to make it softer or turn it completely off.
When you hear the ringer volume level you want to use, stop pressing keys.
The handset or base will use the new ringer volume starting with the next incoming call.
Note: If you set the ringer volume to Off, the handset or base won't ring. Other handsets or base will ring according
to their individual settings.
Muting the Ringer (One call only)
While the phone is ringing, press /Mute or END on the handset or on the base to mute the ringer
Sep 12, 2011 | Uniden Lands Phones
My phone will not vibrate at all anymore
Hi
Make sure your ringer is not in vibrate mode. Try These this thing first
Press Menu > Settings/Tools > Settings > Sounds > Ringer Type > Voice Calls.
Select Caller IDor No Caller ID. (A list of ring type categories will be displayed.)
Select a category, and then use your navigation key to scroll through the available ringers. A sample ringer will sound as you highlight each option.
Press OK to assign a ringer. Make sure your speaker works. Turn On your speaker phone while talking to someone and see whether you can hear or not. Make sure the increase the volume using keys on side of your phone.
If none of these works the ******** motor needs to be cheked for loose connections inside the phone.
Thanks for using Fixya
Mar 24, 2011 | LG Ally Cell Phone
Phone will only vibrate and not ring
a. Make sure your ringer is not in vibrate mode.
1. Press Menu > Settings/Tools > Settings > Sounds > Ringer Type > Voice Calls. 2. Select Caller IDor No Caller ID. (A list of ring type categories will be displayed.) 3. Select a category, and then use your navigation key to scroll through the available ringers. A sample ringer will sound as you highlight each option. 4. Press OK to assign a ringer.
b. Make sure your speaker works. Turn On your speaker phone while talking to someone and see whether you can hear or not.
c.Make sure the increase the volume using keys on side of your phone.
Mar 14, 2011 | LG RUMOR Cellular Phone
I have the ATT 973 2-line speakerphone. If line 1 is in use and a call comes in on line 2, there is no ringer sound. The reverse is also true: If line 2 is in use and a call comes in on line 1, it does...
I use the 974 4 line version in my office so the buttons may not be exactly the same but press ENTER then toggle to PHONE SETTINGS & press ENTER. Toggle to RINGER ON/OFF & press ENTER. You should see L1 in the window and the ringer may be set OFF, toggle to ON then press ENTER. Toggle to L2 and repeat the process.
You have to do this on each phone.
Mar 20, 2010 | AT&T 972 Two-Line Memory phone
Can't hear phone ringing
Adjusting the Ringer Volume (From the Uniden manual)
  1. With the phone in standby, press ArrowUp or Arrow Down on the handset or VOLUME + or VOLUME - on the base. The handset or base sounds the ringer at that level.
  2. Use Arrow Up on the handset or VOLUME + on the base to make the ringer volume louder.
  3. Use Arrow Down on the handset or VOLUME - on the base to make it softer or turn it completely off.
  4. When you hear the ringer volume level you want to use, stop pressing keys.
  5. The handset or base will use the new ringer volume starting with the next incoming call.
  6. If you set the ringer volume to Off, the handset or base won’t ring.
  7. Other handsets or base will ring according to their individual settings.
Jan 03, 2010 | Uniden DECT 6.0 Cordless Telephone...
Cannot Hear the Ringer
could be set to "no ring" on the system, if so it will never ring, sounds like you need to talk to your helpfull sys admin!! ;-)
Dec 09, 2008 | Mitel 5220 IP Phone
Panasonic cordless phone,
press menu,scroll down to ringer settings,hit select,scroll to ringer volume and hit select then press up the round button in the middle until you hear it make a "ring" sound. adjust your preferred volume and hit save.
Oct 16, 2008 | Panasonic KX-TG5632 Phone
Turn off ringer
here's what my instructions say about turning off the ringer:
Ringer high/low/off Shortcut
Apart from the setting in the main menu, there is a shortcut to set the ringer. Make sure the phone is OFF (not in talk mode).
1. Press the #RINGER/PAUSE button to go to the RINGER VOLUME menu. RINGER 1HIGH shows in the display. 1HIGH is the default.
2. Use the cid/vol (- or +) button or the touch-tone pad on the handset to scroll to 1HIGH, 2LOW, or 3OFF.
3. Press the #RINGER/PAUSE button to save your selection. You will hear a confirmation tone.
Jan 21, 2008 | GE 25951EE2 Phone
Ringer off
The VT-9118 can use one of 4 different ring tones, and can be turned off.
To reset your ring tone:
  1. Remove the handset from the base.
  2. Press PROG. You should hear a single short beep.
  3. Press #.  You should hear a single short beep.
  4. Press a number 1 through 4. You should hear a long "ring" tone (it might be startling!). You can try other numbers from 1 to 4 to hear them all.
  5. Press MEM to confirm your ring. You will hear a medium beep.
To turn the ringer off, follow the same instructions, but choose number 5.
Hope this helps you. If you need for information, you can download the user manual from http://www.vtechphones.com/docMgt/public/art/313/vt9118.pdf
Jan 17, 2008 | Vtech VT-9118 Cordless Phone
Uniden Cordless Phone Logo
207 people viewed this question
Top Uniden Lands Phones Experts
k24674
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
