Question about Garden
I've had this pump for 1 year and its worked fine.
I've had an Anjon 2500 GPH Koi Pond Pumppump for 1 year and its worked fine. Now its shorting my receptical out. We've had some heavy rain lately. Could it be that it just needs time to dry out?
    President:
  • 1,714 Answers
Yes, it's probably on a GFCI circuit and it will need to be dried out and maybe sealed up good to prevent 'current leakage'
Posted on Aug 01, 2009
How do i get rid of frogs from my koi pond
Empty the pond for a week, keep the KOI n an alternative location.
The frogs will move on for the most part.
Second add a filter and a pump to the pond, this will eliminate and Mosquitoes and other such food source from there Appeal to the pond
Third, any tall grass should also be removed.
If you can't move the fish for a week, try fencing with a mesh netting around the pond, but make sure it is dug into the ground and at least 2 feet high, 3 would be better.
Also Snake repellant keep frogs at bay as well, but keep it far away from the Koi!!!
May 27, 2014 | Hunting
I have a tetra 2500 pressure filter for my Koi pond. The barrel cracked. Can I order a new barrel rather than buy the whole filter again?
no, the name on the pump is not gonna be the company that made the barrel, and to fine that info it will never happen. sorry
Mar 24, 2011 | Garden
Tsurumi submersible pump with a bad bearing.
Mostly likely no.. These pumps have a sealed bearing that can not be serviced.
Apr 17, 2010 | Tsurumi Pump s Submersible Trash Pump -...
I have a AquaScape 4500 GPH Pump it has worked fine. Today I spent all day cleaning out my pond. All I did was lift the pump out of the pond and spray the muck off it. After completly cleaning the pond and...
Where the wire goes into the pump there is a o ring thatis probably leaking and any sort of water the motor might be getting is tripping the breaker. You probably have it plugged into a gfi and it sense very low amounts of water, and trips, You can determine by plugging it into a regular outlet and it should work. But definently fix the oring at the point of entry on the pump
Apr 17, 2010 | RTO AquaScape 4500 GPH Pump
My Pondmaster Mag 3600gph pump quit working too
welcome to pond life they rarely last more than 1 to 2 years
Jun 27, 2009 | Danner Pond Pondmaster 500 Gph Mag - Drive...
Pond pump trips circuit breaker
The circuit breaker trips because there is an electrical short in the pump itself or in the wire feeding the pump. A cause of this could be a bare wire, or a crack in a wire. Remove the pump and put it in a five gallon pail of water and test it. If it still trips the breaker you will know the problem is in the pump or the cord to the pump.
May 02, 2009 | Beckett Corporation Beckett Professional...
PUMP RUNS BUT DOES NOT **** UP WATER
I have experienced this same problem and all I needed was to prime the pump. Unless your pump cannot pump up that high.
Jan 09, 2009 | Little Giant Opwg 71 71 Gpm Out of Pond...
Filter
You can build your own little filter by placing is in a container, like yorgart, with lid, but before you do punch holes into it no more than 1/8 inch all around. the more holes the better. this way your pump does not **** something into the chamber that will stop the propeller. I have done this and it works like a charm. Also you can use pond pots, the ones that have many slits in them.
Magnetic Drive Pond pumps can be left in the pond even if it froze. These pumps are great for weather. Once water unfreezes, pump will start again.
Jan 04, 2009 | Sti Group Sti Infinity 160 Gph Magnetic...
Garden Logo
71 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
