Question about Dometic Rooftop RV Air Conditioner
The unit only blows warm air. it just stopped kicking on the condenser/compressor to make that radiator cold and blow cold air. any help?
  • 158 Answers
The compressor is not starting either because:
1. The compressor has gone bad
2. The system is low or out of refridgerant. There may be a slow leak, when there is no refridgerant in the system the compressor will not start.
Fix:
Re-charge the system with appropriate refridgerant, if the system has a charge already or holds a charge when you charge it then the compressor should start.
If not the compressor could be bad, sometimes you can get a hard start kit instead of replacing compressor. If the system does not hold a charge then you have to find and repair the leak before anything else...
Good luck. Please give good rating, it meens a lot to me....Feel free to contact me again...
Posted on Aug 01, 2009
Blows cool air only , compressor runs and it condenses down the side of unit,have changed freeeze control sensor ,no difference. It is under extended warranty.. HELP.....
    President:
  • 1,273 Answers
You probably are low on refrigerant. Since it holds R-22, you will need to have it serviced. The good news is that it has service ports and that it will not take much freon to charge it. The bad news is, you probably have a small leak, and will need to have it repaired before you add the refrigerant charge.
Best regards, and happy motoring! --W/D-- please feel free to rate this solution..thanx!
Why does my ac not blow cold air?
You have to try resetting the system. First turn the breaker off for the condenser and wait about 20 seconds After you turn it back on the system should reset. If you need any other assistance check us out online at Boca AC Service we are always happy to lend a helping hand
May 26, 2016 | Heating & Cooling
Why does it just blow cool air?
Check outside condensing unit. Should feel warm to hot air blowing out of the top. If cool to outside air temperature blowing off you likely have a refrigerant problem
Apr 02, 2016 | Heating & Cooling
How do i get my newair af 1200e portable air conditioner to stop blowing cold and warm air.
that is normal operation when thermostat setting is reached it will cycle off compressor.
Sep 09, 2015 | NewAir Heating & Cooling
In cold weather heater will not blow warm air unless at idle stopped. when at highway speed blows cold air
check and make sure the radiator is full of antifreeze take off the radiator cap and top off the radiator then take your hand and cover the hole where the cap goes and squeeze the top radiator hose a few times to help it go down that way if there is a air pocket somewhere it will help push it out when you thank your done top off again and replace the cap and try
Jan 27, 2014 | 2003 Ford Focus
It blows cold air for 5 min. and the it blows cool air for 15 min. the room warms up . Why does it stops blowing cold air continuasly???? The thermostat was disconectet on purpose so it coul clow cold air...
See if you can reposition the thermister on the facing of the evaporator coils. That could be it or the thermister might be bad. They don't use copper/mercury sensing bulbs these days. They use these cheap thermisters.
May 22, 2010 | LG Heat cool Window Air Conditioner
Compressor will not stay on.
very good possibility that it is low on freon. If indoor unit is blowing ambient air, not cooling is happening. If this is the case and you are sure the compressor is running and then shutting off, the compressor could be overheating and the internal overload is taking out the compressor. If outdoor fan runs and compressor runs, probably cause. If capacitor is bad, unit would most likely not run that long. While unit is running, feel the large line at the condensing unit. If it is cold, and stays cold, could be something else going on. If stays warm, most likely low on freon.
Apr 19, 2010 | Intertherm P3RA-030K Air Conditioner
PART # 7330B730 SERIAL # 109734610 1997-TIMBERCREEK R.V.
most of the time the condenser coil is dirty and needs to be washed out. with it dirty the pressures are elevated and causes compressor to kick out on overload. try washing cond. coil first
Sep 12, 2009 | Dometic Rooftop RV Air Conditioner
My air conditioning unit is fully serviced but only blows warm air. The low pressure side hose does not get cold and there isn't any condensation dripping from the system. I have the same problem. The...
Is the system full? Jeeps have a long history of bad evaporators. Even if the system was serviced, you could have lost the freon overnight. Compressor cycling can be because of not enough freon also.
Sep 07, 2008 | 1999 Jeep Grand Cherokee
Will not cool properly.
You have either a faulty thermostat, dirty condenser and evaporator or a faulty run capacitor. Need to service soon before the compressor is damaged. Sea Breeze
Jul 31, 2008 | Kenmore 75101 Wall/Window Air Conditioner
Dometic Rooftop RV Air Conditioner Logo
345 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
Donni Steen
mike cooper
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
