Question about Toshiba TN61X81 61" Rear Projection Television
My TN55X81 is showing the same problem.
It started as a convergence problem 3 months ago. I replaced the two convergence IC's (STK392-110) with Sanyo STK394-160. That fixed the convergence problem. After that, I saw this problem of blinking power light a couple of times and got it powered up after unplugging/replugging the power supply.
Then this problem appeared again a few days ago, and unplugging/replugging of power won't work any more (left power disconnected for hours before replugging). I did this test that seems to indicate a problem with the convergence board: unplugged all connectors (seven for my TN55X81) from the convergence board (PB8923) and turned on power. The TV would then turn on, with convergence way off (which is expected as PB8923 was disconnected).
This test ruled out fuses. I checked PB8923 and saw no open resistors. I don't know if the convergnece IC's have gone bad again and even if they did, if that could have caused the blinking power light problem. Some web postings suggested the TV shuts down power right after it attempts to turn on the TV (hence two clicks instead of one after the power was turned on), and decribed this as the TV getting to some protected mode when it detects some problem such as shorting somewhere.
I am debating whether I should try replacing convergence IC's again, and if I do, whether I try STK392-110 or STK394-160. Some postings suggested STK394-160 as a better replacement for STK392-110.
  • jhu01 Aug 04, 2009
    Sparko1, thanks for the suggestion. Your suggeston directed my attention to the IC's, and I double-checked and saw one of the pin's disconnected at the soldered point from the board. I resoldered it and that fixed the problem.
    This was probably what happened: when I first relaced the IC's, this pin was not firmly soldered, and its tension along with heat forced a disconnection, and initially shutting down and letting it cool down allowed the metal to contract and the soldered point to reconnect. Then it happened again and again until the soldered point would not get reconnected after cooling down.
  • 167 Answers
Replace the IC's with STK 392-110T.
Toshiba has a Service Bulletin on this problem.
Posted on Aug 02, 2009
My tv is a magnavox and we bought it about 3 years ago and it is now showing like a double picture the color is hazy and pinkish looking the model is 51MP392H/17
The problem of your unit is the convergence. Try to adjust it using the original remote control in the setting menu, then goto the convergence section adjust the red and blue convergence, you should move red and blue UP, DOWN and LEFT or RIGHT, if you cannot move them far enough the convergence IC is defective, replacing this IC will restore the original setting of your tv. This convergence IC is attach to a large aluminum plate it is the heat sink this IC has a marking of STK-#### followed by numbers, remember be careful when replacing this IC you may accidentally tampered or damage the PCB and cause much damage to your unit. Or you can contact a technician to do it for you and save you from stress good day and best regards. Try to check this link for the convergence http://www.google.com.ph/search?q=convergence+ic&hl=tl&sa=X&tbm=isch&prmd=ivns&bav=on.2,or.r_gc.r_pw.&biw=798&bih=472&ech=1&psi=JZdtTvDCPIe4iAe72sTABA.1315804977740.3&emsg=NCSR&noj=1&ei=MpdtTpa4OKKSiQfBpcjGBA
Sep 12, 2011 | Philips Magnavox 51MP392H Rear Projection...
I am having convergence problems and need to know if there is really a difference with Sanyo and Sanken STK IC convergence chips?
Just the name, Sanyo quit making the STK series several years ago Sanken, Toshiba and Mitsubishi all have good versions of the STK series.
Aug 25, 2010 | Zenith R50W46 50" Rear Projection...
How to reset convergence? on mitsubishi ws 55511, has a shadow colored blue or yellow
There is an option in the user menu on the tv. Using either the remote or control panel on the front of the tv, press MENU then select SETUP. After you choose SETUP go to the 3rd column with the 3 icons. Here you can adjust the red or blue color or reset the convergence back to factory default.
After a few years the set will begin to show increasing problems with the convergence settings. When you can no longer adjust either red or blue horizontally or vertically an IC replacement will be needed. Your set uses (1) SANYO stk393-110 and you want to make sure it's SANYO and not a knock off brand as those usually fail prematurely.
Jan 23, 2010 | Mitsubishi WS-55511 55" Rear Projection...
Picture flickers in and out rapidly,gets blurry for about 5sec then looks like new for about 5sec then back again
Did you replaced 2 IC convergence as well or just 2 resitors 3.9 ohms ? if you did replaced 2 IC then you might have probelm in convergence drive it is1 of the PCB mount vertical on the left side from the rear view under part BP95-00415C you need to readjust the convergence by using your remote control just follow in the servive manual
Nov 22, 2008 | Samsung HC-P4752W 47" Rear Projection...
All screen is red
IF THE SCREEN IS ALL RED WITH VIDEO VISIBLE AND RETRACE LINES. ADJUST SCREEN CONTROL IN THE FRONT FOR THE RED TUBE ONLY. TURN CONTROL COUNTER CLOCKWISE. IF THAT DOESNT DO IT THE TUBE CAN BE REJUVINATED.
Nov 19, 2008 | Samsung HCL4715W 47" Rear Projection...
Blue convergence
They should be STK392-110 ICs you can get replacement ICs at the following link with free instalation instructions
http://servicemanuals.vstore.ca/
Jun 04, 2008 | Toshiba TN55X81 55" Rear Projection...
Toshiba TN55X81
Blue Convergence IC is bad = change both for reliable repair..
located on largest heatsink on chassis.............T.
Feb 02, 2008 | Toshiba TN55X81 55" Rear Projection...
Blue Convergence
Blue convergence IC is bad, but change both as red wont be far behind they are cheap about 10.00 ea at the following link.
http://electronix.com/
Jan 14, 2008 | Toshiba TN55X81 55" Rear Projection...
Sanyo TV
it is not a problem you must have replaced system control ic or remote ic which might be having this program you remove it by reprogramming thanks
Sep 09, 2007 | Televison & Video
Bent image
Excelent description,whats happening is your set starts to show a blue convergence problem and is only correctable by replacing the blue convergence amplifier IC,the set has 3,one for each color,not all of them develope problems but they all develope loose conections,after the IC has been replaced there are adjustments to do.If you are familiar with tv service this information will give a place to start but if you are not too familar be safe and call a servicer to help you.Lets US know how it goes.
Oct 13, 2006 | Panasonic PT-53WX42 53" Rear Projection...
Open Questions:
Toshiba TN61X81 61" Rear Projection Television Logo
404 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
