Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Car overhead remotes turn lights on & off but won't move door.
I have reprogramed both units with no improvement.
  • tnnguetz Aug 03, 2009
    I have had this garage door opener working for 3years.
    The garage door remotes built into one of our cars would not close the door. I tried the other car and it worked as did the keyless entry and the manufacturers remotes. I reprogramed the malfunctioning remote per written instructions and also per auto instructions. Now it will only turn on and off the built in light in the opener. And that is all the other car's remote will do also.
  • Don Maggard May 11, 2010
    Could you please restate your problem. I don't understand what is going on.
    President:
  • 3,197 Answers
Checking other post.
Posted on Aug 03, 2009
Craftsman overhead garage door opens at random?
There is some interference created by other wireless devices within range of your garage door. This maybe a door bell, baby motor or car immobilizer. Check to see if there are any new wireless devices, it maybe someone Cole by like a neighbor. Alternatively, you can delete the existing remotes from the unit and reprogram the remotes again, this will reprogram the emotes on a different frequency and hopefully cut out any interference. Need new garage roller doors for your Perth home Think Modern Garage...
Feb 16, 2014 | managemylife.com
Remote won't open the garage door unless it is pratically touching the garage door. Any suggestions?
This will keep you busy.
Limited range of your remote controls could be related to radio frequency interference that comes from something in your home or in the surrounding environment. Certain electrical devices can radiate interference; this could be almost anything that is plugged into an electrical outlet.
Please keep in mind that the device can be brand new, or can be an item that has been in use for quite a while. Also, the item may continue to function properly as far as you are able to tell. The only problem with the item may be that it has started to broadcast the interference, with no other symptoms noted.
Some devices are more likely to generate interference than others. This includes TV cable, cable amplifiers, surge protectors, fluorescent lights, battery charging devices (power tools, golf carts, etc.), anything that utilizes a timer (sprinkler systems, lights, alarm systems, etc.), and a myriad of others. If the problem seems sporadic, we can safely assume that the device responsible for the interference is only being operated during these times. Again, please keep in mind that the age of the device does not determine if it is capable of broadcasting unwanted interference. Any electrical device can be the source of the problem.
The first step is replacing the battery in your remote. If the range on your remote does not improve, remove the wall control wires from the overhead unit. If the range does not improve you will likely need to replace the remote control. After replacing the remote, or if you have other remotes programmed in to the opener, and the range problem still exists, please proceed to the Power Down test.
Multiple garage doors:
If you have two garage door units and one is working just fine, you will need to start by unplugging the good unit. This will help determine if the unit with no range starts to function properly. If the range comes back to the bad unit then you will need to replace the logic board on the unit that was unplugged as it is emitting an RF signal that is over powering the other garage door opener. If the range does not improve after the "good" unit has been unplugged, replace the batteries and try programming some additional remotes to determine if the existing remotes are the issue. If the extra remotes do not have any range then you would need to replace the receiver logic board in the "bad" unit.
Power Down test:
To isolate potential sources of interference, turn the circuit breaker off to the garage and plug the garage door opener into an extension cord from another room. If the range improves, then the interference is coming from a device in the garage. If no improvement is seen follow the same procedure, this time turning off the circuit breakers to your home, with the exception of the garage and test the remote controls. If improvement is noted, turn the circuit breakers back on, one by one, until the range problem resurfaces. This will allow you to narrow down what room the problem device is in. You will have to go from there to isolate it further, by unplugging and re-plugging the items in that room.
If you are unable to determine any source of interference, then the receiver logic board in the overhead unit will need to be replaced.
Aug 08, 2011 | Sears Craftsman LiftMaster Chamberlain...
I have a craftsman 315mhz 1/2 hp opener and both remotes stopped working. The light on the base unit is solid. I tried reprogramming the remotes both from the wall unit and from the opener. The overhead...
Sounds like your receiver has quit working. To program the remotes do this: Press and hold the button on the remote while you press and immediately release the smart/learn button. Do this for each remote. If this doesn't work your logic board is bad.
Jun 24, 2011 | Sears Craftsman LiftMaster Chamberlain...
I have Craftsman 139.53753 (sears) garage door opener, I replaced the battery...it's new. Garage door will not open from outside or inside UNLESS I bring the transmitter (clicker) right next to the...
Dec 10, 2010 | Sears Craftsman LiftMaster Chamberlain...
Remotes & key pad not working . Finally reprogrammed after many attempts. Now they only work within 5 feet of opener, I had to move keypad to garage frame and the remote doesn't work unless it is in...
Power Down test:
Nov 09, 2010 | Sears Craftsman LiftMaster Chamberlain...
I have a Craftsman 139.5399OD opener. It has worked fine for a year. None of the remotes will now open the door. They work fine to shut the door but will not open it. I have checked the door sensors and...
Here is some information. Some pertains and some doesn't.
If you have two garage door units and one is working just fine, you will need to start by unplugging the good unit. This will help determine if the unit with no range starts to function properly. If the range comes back to the bad unit then you will need to replace the logic board on the unit that was unplugged as it is emitting an RF signal that is over powering the other garage door opener. If the range does not improve after the “good” unit has been unplugged, replace the batteries and try programming some additional remotes to determine if the existing remotes are the issue. If the extra remotes do not have any range then you would need to replace the receiver logic board in the “bad” unit.
Power Down test:
Sep 10, 2010 | Sears Craftsman LiftMaster Chamberlain...
Both remotes worked yesterday, today have to hold them within 2 inches of opener wire. sensor lights at the door are green. The light on the opener is blinking next to the learn button. Replaced remote...
Here is some stuff to check.
If you have two garage door units and one is working just fine, you will need to start by unplugging the good unit. This will help determine if the unit with no range starts to function properly. If the range comes back to the bad unit then you will need to replace the logic board on the unit that was unplugged as it is emitting an RF signal that is over powering the other garage door opener. If the range doesn not improve after the “good” unit has been unplugged, replace the batteries and try programming some additional remotes to determine if the existing remotes are the issue. If the extra remotes do not have any range then you would need to replace the receiver logic board in the “bad” unit.
Power Down test:
Mar 14, 2010 | Sears Craftsman LiftMaster Chamberlain...
Model 139.53930DM Remotes very eratic, will not
I am going to assume you have short range with your remotes and give you some stuff to check.
LIMITED RANGE
Power Down test:
Nov 20, 2009 | Sears Craftsman LiftMaster Chamberlain...
Some remotes work others only turn lights on and off
possibly bad relay/wireless board? keyless entry uses same board?
Aug 01, 2009 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
93 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
