Question about Whirlpool Ultimate Care II LSQ9564J Top Load Washer
Whirlpool ultimate 2 washer will not drain or spin- cycle works up to this point- how do I drain the water out manually till I get tech to repair it
  • 5,911 Answers
If the washer fills and doesn't do anything, or stops right after the wash cycle and then does not advance to the rinse cycle and drain, this is commonly caused by a lid switch malfunction. The lid switch is usually mounted under the washer top casing, on the right hand side on most top load models. It is activated by a plastic piece on the lid (called a "Lid Strike") through a small hole on the rim of the wash tub opening. In many cases the lid strike breaks off the lid, or the lid switch becomes loose and no longer makes contact. Inspect the lid to make sure the lid strike is still intact, and then inspect the mounting screws (adjacent to the small opening on the wash tub rim) and make sure they are snug. If you determine the switch to be defective, the following link explains how to replace one:
http://www.fixya.com/support/r385198-replacing_lid_switch
If the switch requires replacement, a new one can be purchased on line at searspartsdirect.com, pcappliancerepair.com, repairclinic.com, appliancepartspros.com. Just use your model number as your search criteria. All these sites offer competitive pricing, so shop all them for the best price.
PS There is no need to drain the washer to repair the lid switch. However, if you need to drain the washer to avoid having stagnant water in the tub, you can by-pass the lid switch. Use the steps provided to access the lid swtich. Unplug the switch and remove it from the washer. With the switch in your hand, cut the connector plug off leaving about two inches of wire. Cut the center conductor (green wire) off flush with the plug. Take the two black wires and crimp them together and insulate with some electrical tape, or use a wire lug. You now have made yourself a by-pass plug. Plug this back into the timer plug and you have now by-passed the lid switch.
NOTE: This is to only be used as a TEMPORARY means of operating the washer and not as a permanent fix. The lid switch is installed as a safety feature to stop the washer motion when the lid is opened. Without it, you will not be able to stop the washer unless you push the timer knob in. Make sure you replace the lid switch.
If you have questions, please let me know. I hope this helps you.
Posted on Aug 01, 2009
Whirlpool Ultimate Care II Model #LSQ7030KQ0 Won't Spin
Either a bad lid switch or a bad clutch/brake on the transmission.
Jun 16, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool washer stoped after the agitate cycle
If it fills with water, agitates then stops still full of water (even if you manually advance the timer), you have a bad lid switch. This is an inexpensive repair, or even a do it yourself project.
May 19, 2009 | Whirlpool Washing Machines
Washer fills but won t advance to the next setting for all cycle
Do you hear the ticking of the dial moving? if so it could be that the points aren't getting connection to cycle it threw the various cycles
Nov 22, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Excess water in clothes after spin cycle
Unblock the outflow pipe from the machine that goes into the sump under the sink. (have a pot ready for water overflow) This will help drain the water. If the spin cycle is making a screetching sort of noise then it is possible that the carbon brushes will need changing. This affects the spinning if the brushes are worn.
Nov 05, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Washer will not Spin during SPIN CYCLES
Thanks for the question If your washer sorta spins and washes ok, your problem is with the transmissionTHanks for your question THe Appliance doc
Jul 29, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool washer ultimate care
check for problem with the pump it is coupled to the motor, if it is spinning then it should also be pumping out the water
Apr 23, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Washer Whirlpool
Spin cycle pump is either obstructed or damaged. They are hard to get to and I suggest you call a local repairman.
Oct 22, 2007 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool Ultimate Care II LSQ9564J Top Load Washer Logo
377 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
