Question about Nokia N95 Cellular Phone
Keeps playing first few seconds of music files
This happened to my n95 last summer, but it seemed to correct itself after a while, but now its happened again!!! Its very frustrating. Cant even get to messages, or anything else for that matter - it happened 2 days ago and its stuck on that day on screen too.
If anyone has any suggestions they'd be gratefully received.
Thanks
Jules
    Sniper:
  • 83 Answers
Start by taking the battery out and reinstalling it.
If this doesn't work, and the keyboard is still responding, use the "soft reset" code - *#7370# - you will need to enter the phonecode (12345 if you have never changed it).
If that doesn't work, then use the "hard reset" code *#7870# - but be aware that this will delete all data that's stored in the phone memory - the contents of the memory card are not affected, however.
Finally, there is the phone reformat, which will also erase all the settings and data on your phone - to do this, remove the battery, reinstall it and hold down the "*", "3" and "Answer (green phone)" buttons and while holding them down press the power button. Hold the keys down until the phone starts asking the startup questions again. Having 3 hands helps for this proceedure.
If this doesn't help, then the last thing to try is to reinstall the phone firmware using the Nokia software update service - http://europe.nokia.com/get-support-and-software/download-software/device-software-update
If it still doesn't work after that, then about the only option is to take it to a Nokia service centre and get them to fix it, since it sounds like a hardware problem.
Posted on Aug 01, 2009
Itunes and Spotify crash when connected to denon reciever
Yes it sound like you have a fault on the power amp section. Perhaps a faulty transistor? It might be difficult to sought out, unless you have a bit of experience in tracking down these types of faults.
Jun 10, 2017 | Audio Players & Recorders
Audio/Music skip sounds every few seconds at random constantly
Hello my friend,what program are you using and what type of music?
First uninstall all drivers and install the latest one.Second check your CPU activity when you are playing music(from task manager ctrl+alt+del),if its too high its a problem.If you are using different music from .mp3 like .ogg or something "not common" you must install the latest codecs.I'm waiting for your reply.
Feb 04, 2010 | eMachines ET1161-07 Desktop PC
Nokia n95 won't stop playing music
May be it is some sort of software problem.Try reinstalling you phone's software or update your phone's firmware.
Jun 30, 2009 | Nokia N95 Cellular Phone
No sounds n95 nokia
try format your phone, you must back up your file first, copy all important data as contacts, images, musics, then remove your memory card from your phone.
soft format = press *#7370#
it'll ask if you want to do a -factory setting?- press yes
then try your headset and remove it again, if problem occurs, try hard format
hard format = when your handphone is switched off , press simultaneously (at the same time), # button, 3 button, green call button, and lastly press on-off switch for a long time, it'll blink few times and format itself, your data will be erased all (instead of just factory set), it'll look like brand new the first time you buy it, no data at all. then try if the problem still occur.
Last solution if after format still have that problem, you need to upgrade it via Nokia website. Use your cable, your PC suite, and upgrade it via Nokia website. Remember to have your battery full during this all process or your phone will die.. and you have to spend extra money to bring it to technician later..
Nov 14, 2008 | Nokia N95 Cellular Phone
N95 UI Gone Crazy
dear,
most probably it happens with stuck button. may be the casing is not properly fixed with the phone. check it first. sometimes, it happens, that a button seems to be ok but physically it is stucked. if problem persists, then try with removing the memory card and do a master reset, if necessary
Jul 26, 2008 | Nokia N95 Cellular Phone
Music Player Won't Play - 'muted'
I don't think that I can suggest a precise fix for your problem. I would probably go about backing up my contacts and data. I would then 'hard reset' the phone by dialing *#7780#
Feb 05, 2008 | Nokia N95 Cellular Phone
My Mp3 wont play certain songs
Sounds like you have two problems here. First my guess is your files bought from walmart are corrupted some how. just delete the ones that are giving you fits and call it a day. Second you mentioned it wont even sync music,,,, Are you saying none of your music or just the walmart ones ?
Nov 17, 2007 | SanDisk Sansa e260 MP3 Player
Corrupt Files/Other?
Good Day, Have you tried reformatiing it? Over a period of time your info can get corrupt from transering music back and forth. To format plug it in to usb. Go to my computer It shows up as a removably disc, usually drive f: Right click on drive f: (or the approriate drive) and click format. Let me know what happens, you will have reload the player, also try bypassing the software you are using to tranfer, by opening up drive f: and clicking and dragging your music into it , or you can copy and paste it into drive f: L8R
Sep 16, 2007 | Philips GOGEAR SA6045 MP3 Player
Nokia N95 Cellular Phone Logo
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
