Question about Refrigerators
I have a Maytag MZD2766GEW Side by Side and am trying to remove the yoke part 63052-2 from the shaft that drives the crusher in the ice bin.Is it a reverse thread? There appears to be a washer (possibly a lock washer) in back of the yoke. Any ideas? Thanks
  • Anonymous Mar 18, 2014
    I cannot the yoke in ice bin that turn the ice
It hada reverse thread and with a vise grip and a few taps of the hammer I got it off the shaft and completed the repair.
Posted on Aug 02, 2009
What causes ice maker malfunction?
you could try cleaning the ice bin first of all the accumulated ice cubes that are all sticking together at the discharge side of the bin. thanks.
Mar 04, 2016 | Kenmore Refrigerators
Ice maker only makes crushed ice and I want cubes only
You could have a bad augar motor. It will turn one way for crush and the other way cube. that is the moldel with ice bin on door. If you have ice bin in the freezer not on the door. you could have the ice crusher lever jammed. that is the wire lever on the bottom of ice bin. Or the selnoid the moves the lever up thus opening the door and allowing the ice to pass the crushers. hope this helps.
Aug 20, 2011 | Kenmore 53502 / 53504 Side by Side...
Maytag model MZD2766GEW. The water tube supplying
The water inlet valve on the back of unit opens when the ice maker needs water. If the valve doesn't seal good because of sediment or wear it will continue to drip and when the water reaches the ice maker supply tube it will freeze blocking the fill tube.. You can take the water line off the valve and watch to see if it drips.
Jun 28, 2011 | Maytag MZD2667HE Side by Side Refrigerator
MODEL FFS26ZRG THE ICE CRUSHER CHURUSHES THE ICE
there might be something in between the door and the ice crusher. If you could check what it is, would be good otherwise call in a repairman to work on this problem.
Jun 11, 2010 | Frigidaire FRS3R5EMB Side by Side...
Ice crusher does not turn
KSCS25FKSS is the model you posted under is this the correct model number.If so the motor should be behind the panel directly behind the ice bin inside the freezer.
Sep 24, 2009 | KitchenAid KSCS25FKSS Side by Side...
Ice maker chute becomes jammed with snow and cubes are being crushed even if the cube option is selected
You need to remove the ice bin , remove ( save ) the ice , and defrost the bin opening with hot water . It sounds like a piece of ice got caught behind the bin flap , keeping the flap from opening fully , so cubes will go thru . When cubes cannot go thru , the crusher will crush anything that tries . Now this is the ice container only .
Sep 09, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerator Maytag MSD2454GRQ - Ice Dispenser Yoke
I think this manual should be relevant to your fridge. Page 61 I think will give what you are looking for much better than I may be able to describe, let me know if it is still being a problem as I suspect the pressure that keeps the yoke on is what you are having problems with.
http://www.servicematters.com/maytag_library/docs/16010154.pdf
Nov 06, 2008 | Maytag MSD2454G Side by Side Refrigerator
Changingthe ice enclosure
Hello, Msalloum:
I have the same Maytag refrigerator that you have and I faced the same problem with the ice enclosure. I have now replaced it. As to the problem of separating the yoke from the motor, you'll have to turn the yoke clockwise in order to liberate it. In my case, after holding the motor shaft with a pair of pliers, I had to tap the yoke with a hammer once or twice on a clockwise direction before the yoke became free.
In view that more than 2 months have elapsed since you posted the question, you probably have solved the problem long time ago. If you haven't, I hope you find this tip helpful.
lopezfra
Sep 01, 2008 | Maytag MSD2454G Side by Side Refrigerator
Ice maker
There is something called a crusher control rod located on your icemaker bin. If you pull the bin out, you'll see it protruding from the backside of the bin. That rod inserts into the solenoid, which looks like a hole usually when looking in the freezer with the ice bin removed, it's toward the left side behind the bin.
This solenoid and rod work together to give you either crushed or cubed ice. See if the solenoid is stuck or iced up. You should be able to remove the ice and push it up and down to break it free.
Mar 26, 2008 | Maytag MSD2454G Side by Side Refrigerator
Refrigerators Logo
88 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
