Question about Emerson LC320EM9 32 in. LCD HDTV
When i hook up my computer to my emerson lc32oem9 tv using hdmi i have no display on the tv acer computer said i have to download driver from emerson
  • 1 more comment
  • chillybil364 Aug 01, 2009
    sorry.... i did go into display it dont give that option and i hit fn and f5 keys and only shows one monitor display my computer is a acer 5810tz acer support said i had to download a driver for the tv.all i want to do is display pictures on the tv
    well ive been looking for it if you can find one i will download it sure didnt find one at emerson website. thank you
  • andymn87 May 11, 2010
    normally you would go into the display properties and select another viewing source. have you selected the hdmi socket on the tv?
    Problem Solver:
  • 5 Answers
So download the driver.
Posted on Aug 01, 2009
I have a 50" Emerson and I want to hook up the Wii system. The problem is that our local cable company is using all the a/v cables available.
You can always get a switcher and select what device goes to the tv without ever changing any cables again.
If you need further help, reach me via phone at https://www.6ya.com/expert/steven_a67ead41eb5fc62a
Jan 04, 2015 | Nintendo Wii Video Game Consoles & Games
Emerson hdmi not working
Double check to see if your TV can support the resolution that your laptop is using. You can try reducing the resolution on your laptop to one supported by your TV.
If the laptop is configured to use the HDMI port as a second (in Windows 7, you can configure multi-monitor support in the display preferences) you will need to adjust the resolution for that monitor.
Failing that, try rebooting your laptop with the TV plugged in - I have found in some cases that this helps the system to propery detect a new display.
Dec 16, 2013 | Televison & Video
Need to connect a laptop to an emerson lcd color tv model #LC320EM8. Which cord to I need?
HDMI cable will work great just plug the HDMI into the laptop and into the TV then select the HDMI for the input and you should be good to go
Dec 30, 2012 | Emerson LC320EM8 32 in. LCD TV
HOW DO I HOOK UP AS A COMPUTER MONITOR EMERSON LC320EM1F
The Emerson LC320EM1F has an HDMI connector (HDMI 1) that can be connected to a computer with an HDMI out or a DVI out. With a DVI connection, you will need a ferrite core on the HDMI cable. You can use a DVI to HDMI cable or a DVI to HDMI adapter with the appropriate cable. You will also need a 3.5 mm to RCA (M/M) audio cable (or the adapters and cables) if you want to use the TV speakers. If you have only a VGA output on the computer, you will need an analog to digital converter (like this: http://www.startech.com/AV/Converters/Video/VGA-HD-with-Audio-to-HDMI-Format-Converter~VGAHD2HDMI ).
You can find the manual for this TV including the connections here: http://www.emersonaudiovideo.com/support/download.php . Enter your model number and then the list of manuals will appear. The connection to computer diagrams is on page 13.
Once you have your cables (you will get the best prices from an online shop), turn off both the computer and the TV. Connect the cables then turn on the TV and set it the HDMI 1 input. (Use the Source button on the remote. You can also press CH Up repeatedly.) Then turn on the computer. If your computer has a recent version of Windows, it should see the TV automatically if the port is active on the computer. For a laptop, you will need to change the display settings to use the TV monitor. Right click on the desktop (anywhere there are no icons or programs), find the Display properties option. Set the monitor option to use the second screen (extended or monitor only). Click Apply and confirm the setting on the pop-up. (These are Win7 directions; other OS versions will be similar.) For a desktop, you may need to go to the Screen Resolution option after right-clicking. (This is a shortcut to the Control Panel Display settings window. Thus you can also click Start > Control Panel > Display to get to the right area.)
Some machines may need the port enabled in the BIOS first. This applies more often to older laptops or those with a power-saving option that turned off unused ports. You will need to enable the port with a different monitor active before connecting to the TV. Accessing the BIOS varies but usually involves pressing Esc, F1, F2 or F10 repeatedly after you turn on the computer. I often miss the timing; just turn off the computer and try again if the OS loads or the log-in screen appears.
If you get an unknown mode message on the TV, the previous monitor may have used a refresh rate and resolution that the TV can't understand or the TV was turned on after the computer was turned on. If it's the second case, press CTRL-ALT-DEL twice or turn off the computer (you will see a warning that Windows was improperly shut down). Then turn on the computer. If you have the first issue, go to the previous monitor and use the Screen Resolution directions above. Set the refresh rate to 60 Hz. Set the resolution to 640 x 480, 800 x 600, 1024 x 768, 1280 x 768 or 1380 x 768. (The options will be limited to those that are compatible with this monitor.)
I hope this helps.
(Note only HDMI 1 supports a computer signal; the other ports will not understand the computer's video output.)
Jul 16, 2012 | Emerson Lc320em1 TV
How to hook up a computer that has no hdmi to a hdmi tv
you can buy a graphic card for your computer which has hdmi port. Through that you can connect tv with your computer.
Jul 14, 2012 | Emerson Televison & Video
Trouble with HDMI output on Acer Aspire D257 Netbook.
VGA Driver? Does your tv have a VGA Connection? Have you selected PC or HDMI as your input source on the TV? Have you hit the FN Function Key on the laptop + the corresponding F1 thru F12 key that displays the image on the TV?
Press and Hold the FN key then hit the correct F1 thru F12 key that displays on the tv. The correct F1 thru F12 key will probably have LCD/CRT on it or it might have the icon of a display.
For Drivers: They won't be called VGA but either (Display, Video or Graphics Drivers)
Get onlineand got to www.google.com In the google search box type: "AcerSupport" (without the quotes). Look for downloads and drivers. Enter your model number and operating system when requested. Download andinstall the drivers.
Apr 01, 2012 | Acer Aspire One Netbook
Hi I've bought myself a new computer but can not get sound out of tv. When I'm in the real tek software i can only choose analog output. What can I do? Acer aspire 7551g. I use hdmi cabel
Here are two suggestions:
The simplest method
1. turn off tv and laptop
2. hook up hdmi cable from laptop and then to hdtv
3. turn on laptop and once the laptop has booted fully,
4. turn on tv and select the source....
If the above doesn't work, then try
1. hdmi cable is connected from laptop to hdtv
2. on the laptop go to Control Panel
3. select sounds
4. change default from speakers to hdmi
Feb 10, 2011 | Acer Computers & Internet
How to connect aspire to emerson tv dvd combo. iconnected vga to aspire and one to emerson but still no picture and sound
Sound? You not going to get but picture you will get.
You need to lower the resolution in your display properties then try again.
if you hooking it up via hdmi make sure the resolution is set for the low first then you can adjust it later.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Aug 14, 2010 | Acer Aspire One PC Notebook
LC32OEM9 says Not Supported Format on HDMI Input. It worked when we first hooked up the TV. Then it started working sporadically now it very very rarely works and when it does it only works for maybe 15...
I'm thinking the Comcast DVR box maybe putting out weird HDMI signals and the TV can't translate it. I would call the Comcast people on this one.
In the meantime, I would try finding another source the uses a HDMI cable to rule out the TV as the problem. Basically, testing the TV to see if the problem still happens when you use something else than the Comcast box. Try a Blueray player, Playstation 3, or Xbox. Just something that uses a HDMI cable.
Apr 30, 2009 | Emerson LC320EM9 32 in. LCD HDTV
Emerson LC320EM9 32 in. LCD HDTV Logo
1,724 people viewed this question
Top Emerson Televison & Video Experts
matt martin
matt martin
 Grubhead
Grubhead
Are you an Emerson Televison and Video Expert? Answer questions, earn points and help others
