Question about Electrolux EWDW6505GS Fully Integrated Dishwasher with 9 Wash Cycles, Nylon Racks, Wave-Touch Contro... 24 in. Built-in Dishwasher
My elecrolux dishwasher gives me error code 11. What do I do? I have the manual, which says that it timed out before it could establish a drain... but there is no info on how to fix it. The dishwasher is new, but it has run 6 or 7 times with no problems.
4 Suggested Answers
SOURCE: error code 01 on elecrolux dishwasher EIDW6305GSI
Usually the error code 01 means you backed up water in the unit. First be sure that the drain is clear.  Run the garbage disposal and be sure your sinks are draining.
I got lucky on a EIDW6105 unit by trying this.
All the lights are flashing and it shows error code 01.
Push down on two of the buttons and hold (I pushed on the Favorite and Heavy buttons), until the flashing stops (about 8 seconds).
The machine now showed and error code 08.  Then hit the start button.  My washer then cleared and runs normally.
Hope this helps, better than a sevice call to clear the code.
Posted on Dec 28, 2008
kel1guy2002
  • 3740 Answers
SOURCE: I need an owner manual
Go to this site and choose enter: <br /> <br /> <a href="http://www.electrolux-ui.com/UM/master.nsf/HomePage">http://www.electrolux-ui.com/UM/master.nsf/HomePage</a><br /> <br /> First menu choose: Electrolux <br /> Second menu: enter your model number DX30302SB01<br /> Third Menu: enter your product code (It will be on your model number label) <br /> Fourth menu: Choose EN <br /> <br /> That should bring up your User Instructions. <br /> <br /> Thanks for choosing FixYa<br /> <br /> Kelly <br />
Posted on Aug 30, 2010
  • 330 Answers
SOURCE: We have an electrolux EIDW6305
Your drain pump has failed & needs to be replaced.
Posted on Feb 22, 2011
How do I reset my sanyo dishwasher after it had a 04 error. I have drained it now need to reset.
try cutting power supply for 10 minutes, then re-establish supply. Consult your users manual if that fails to reset
Dec 04, 2017 | Dishwashers
What additional parts may fix error code 11 on electrolux EDW7505HPS0A
Good Afternoon Friend, thank you for your post!
If you are receiving an error code E11 on your Electrolux dishwasher (EDW7505HPS0A), it usually means that you are experiencing a problem with the drain valve. If you have already replaced the vale and pump, at this point, I would recommend reaching out to a professional or alternatively, visit the manufacturer website for a comprehensive listing of appliance techs in your area that can ensure the wiring between the main control and the drain valve was correctly installed. Best regards! - Z
May 20, 2014 | Electrolux Frigidaire Professional Series...
Dishwasher error codes
For some reason I can't find my manual for my Kenmore dishwasher, but I woke up this morning to find my that it didn't drain and an E25 error code. The last rinse didn't drain.
Jan 01, 2014 | Dishwashers
Electrolux dishwasher error code 11
You are experiencing a drain valve issue. Main Control Board timedout before receiving status of drain valve. Check wiring between Main ControlBoard and drain valve. If correct, replace drain valve. If error still exist,replace Main Control Board.
Jul 21, 2012 | Electrolux Dishwashers
I had a black out and the dishwasher was running at the time. The dishwasher emptied out all over the floor. when the power came back on the dishwasher was flashing an error code 4. I rang Whirlpool for...
The trouble looks to be little confusing. Whenever the power fails
during mid cycle this happens. Try running the balance cycle.
Since you say the water is fully drained, try adding water manually to
the wash chamber to certain level ( not to over flow ). Give a try!
There should be a master reset for which, you are requested to check
the user manual
Sep 03, 2010 | Whirlpool Dishwashers
I need an owner manual for elecrolux dishwasher model DX302SB*01
Aug 30, 2010 | Dishwashers
Error code 01 on elecrolux dishwasher EIDW6305GSI
Nov 22, 2008 | Electrolux 24 in. EDW5505EPS Stainless...
Error code 2H
The control panel needs to be replaced (indicated by the "2H" error code displayed at the start of the cycle).
BTW - The number 1 displayed at the end of the cycle indicates the cycle has timed out (i.e., it doesn't mean 1 minute remaining). Hence the continued running of the unit. Until you replace the control panel, you'll have to manually cancel the cycle at this point.
Oct 08, 2008 | Bosch 24 in. SHU53 Built-in Dishwasher
Electrolux EWDW6505GS Fully Integrated Dishwasher with 9 Wash Cycles, Nylon Racks, Wave-Touch Contro... 24 in. Built-in Dishwasher Logo
460 people viewed this question
Top Electrolux Dishwashers Experts
Mike
Starnley Johnwells
Starnley Johnwells
Are you an Electrolux Dishwasher Expert? Answer questions, earn points and help others
