Question about Cobra GPS
Cobra GPSM 4000 The background color is white on all map magnifications and the streets disappear at any magnification above 10. Help! Mike lowemw@comcast.net
  • lowemw Aug 02, 2009
    Mr. Smith,
    The 1st solution, following, didn't work. The background is still white in the city (should be a yellowish-orange color). The streets disappear from the display above the #10 magnification level also. This may be a hard one to solve, may have to call Cobra, about 185 miles North of here.
    Mike (lowemw@comcast.net)
    Hi
    Thanks for using FixYa. Turn off the Auto Zoom option from the menu, go to MAP- > more -> map options. Geographic area may not be fully mapped, drive to a main road. If the map shows the road, the system is working properly, but the area is not fully mapped.
    If this doesn't help try and reset the GPS device by Menu -> Settings-> User Preferences -> Reset Factory Defaults.
    Please do accept the solution if the issue is resolved or else revert for further assistance.
    Thanks
    Rylee
    President:
  • 1,734 Answers
Make sure the unit is not in a location that is being blocked. The best place to have it is mounted on the windshield.
Go to the page that says GPS INFO. If you dont have any green bars then your unit is not connecting to any satelites. If this is the case just move the unit to the windshield until it connects.
If the weather is terrible it may not connect for a while.
Posted on Aug 02, 2009
    Brigadier General:
  • 8,619 Answers
Hi
Thanks
Rylee
Posted on Aug 01, 2009
How to use a spotting scope for shooting?
A Spotting Scope is an essential element for hunters and shooters. This small device is technically a special type of telescope used for hunting, magnifying and watching an image or object more clearly. The methods use a shooting spotting scope does not involve much difficulty.
Here is the method:
Comfortable position
For a perfect shooting experience, you need a comfortable position. If your comfortable position is unable to help you fix the targeted area, you are likely to miss the hit or glance.
Attachment of the spotting scope with the tripod
Having an accurate view of the targeted area is important. Due to this reason, shooters need to position the spotting scope with a tripod so that they can see the targeted area very clearly and accurately.
Adjustment of the magnification level
The lens and magnification level should be adjusted so that you can get the appropriate view of the targeted area.
View of the targeted area
After fixing the targeted area, you have to adjust the magnification level with the lens to view the targeted area. At the time of using scopes, you will find some problems that magnification will present. If you fix the magnification and focus firstly, you may not find the target. You have to first view the target, and you have to adjust magnification level as required. Here, you should bear in mind you will have to go with the slow magnification process because the fast magnification process cannot give the accurate target.
Adjustment of the focus
You have to know how to reset the focus because you will need to do it again and again. It may sometimes harm your eyes with the magnification level being set to high.
Focusing on target is important for shooting and the spotting scope is also important for this purpose. For acquiring a specific target, it is important to use magnification level with the spotting scope.
You should follow all the methods of using explained above. There is no alternative way to learning how to use a spotting scope for shooting except these methods.
Apr 05, 2018 | Optics
I have a Celestron powerseeker 127 Eq telescope viewing issues
With the setup you have, you are attempting a magnification of x 750, which is way beyond the capabilities of your scope. A realistic limit to usable magnification is x 250, or about what you will get if you take the barlow off and just use the 4mm lens.The 127mm aperture on that scope does not gather enough light to do more.
Even that depends on good seeing, that is, clear air and no light pollution. It is a great shame that scopes are marketed with outlandish claims as to magnification. You certainly will see a magnification of x 750 in daylight, when there is lots of light, but they don't tell you that trick.
I have a 200 mm scope, with a practical limiting magnification of x 400, and I find that almost impossible to use. The viewing object is hard to find and keep centred in the eyepiece, it wobbles around, it soon disappears due to the rotation of the heavens, and is dim and blurry. I keep to magnifications of about x 250 max.
Oct 27, 2016 | Celestron Optics
Where can I purchase an update cable for a Cobra GPS 4000?
http://www.e-topshopping.com/replacement-for-cobra-5-pin-gpsm-4000-4500-gps-usb-cable-p-1881.html
Jul 29, 2014 | Cobra 4000 GPS Receiver
Map update for cobra GPSM 7700 pro
Their software HomeBase is compatible with all Cobra truck navigation models EXCEPT the model 7700. If you have a 7700 then do not use HomeBase, otherwise you will render your unit inoperable. If you own a 7700 then please call Customer Service at 773-889-3087 for update options.
Apr 06, 2014 | Cobra GPSM 7700 Car GPS Receiver
Upgrade to cobra gpsm7700
Did you get any software shipped to you with this unit?
Nov 12, 2013 | Cobra GPSM 7700 Car GPS Receiver
The only proble is that I have lost my users
http://www.devicemanuals.com/guide/GPS/Cobra/Cobra-GPSM-4000-Product-Manual-T1RnME1EST.html
Aug 23, 2009 | GPS
Hello. i have a cobra 2950 gpsm and i need to upgrade my maps. what do i need? and how much will it cost?
There are no updated maps or software available for that model. So, I need to upgrade to the 5000 gpsm for just a little over $200.00, plus I need to send in the old one. Will receive the new one in the mail 8-10 days.
Dec 10, 2008 | GPS
GPS Logo
22 people viewed this question
Top Cobra GPS Experts
Steve
ray gallant
Are you a Cobra GPS Expert? Answer questions, earn points and help others
