Question about Samsung ML-2510 Laser Printer
Samsung ML 2510 printer won't feed paper
AFter removing paper after a paper jam yesterday, the printer worked fine for a while then paper wouldn't feed and machine emitts a very loud noise.
I've taken the ink cartridge out, and the other plastic internal piece to check for any paper left, and there appears to be no paper anywhere stuck inside it. I can't get the printer to work, when I replace toner cartridge and plastic inner tray, shut the door, add paper, put plastic outter cover back on and try to print the loud buzzing should starts and nothing happens. I've looked at the trouble shooting guide, done all that it suggested...but there is no paper to extract. This printer is only 4 months old. Any ideas?
  • printer04 Nov 27, 2007
    I have the exact same problem; I spent almost 2 hours fixing the jam in the printer and clearing paper remains, but noticed at the time that the paper wheel seemed stuck. Chalked it up as a loss, but any fix ideas would be appreciated.
I have experienced the same problem . . . a little earlier this evening. I took all the inner components out, took apart the toner cartridge, I thought that the gearing was very hard to turn on it and on the inside of printer, paper feeding etc... and that is wear the loud noise is coming from. Out of desparation, I shook it to hear if anything internally was loose and there was and still is, I would not say its the best solution or by any means a permanent but you may be able to dislodge the debris from the gearing and be able to print. After it was dislodged from my printers gearing it has worked again. Though I believe it's temporary. I am looking for a guide or how-to on opening the printer casing to physically remove the debris. If you know of a guide let me know and I am sure it would help you too.
Posted on Nov 30, 2007
Location of Solenoid samsung ML-2510 printer
Pick-up SOLENOID needs replacing.
See this link.
Part is JC33-00015B SOLENOID-MP_R2;-,SCX-4720F,DC24V
Fairly involved strip down but there are a Cpl of you tube videos out there showing something similar.
Looking to undertake this task myself and will You Tube it.
Jan 10, 2013 | Samsung ML Office Equipment & Supplies
My Samsung laser printer ML-2510 keep wont stop running (two lights are blinking same time) until I manually turn off the switch.
After removing the pickup rubber (and not removing the rubber band from it's plastic drum) I cut a thick piece of card stock paper the width of the rubber band and slid it under the rubber. I thought it would make it contact the paper with more force and it worked great.
Dec 04, 2011 | Samsung ML-2510 Laser Printer
My printer is stuck and it is a ML-2510 the paper is jammed how i get it out?
Do you know where the paper is jammed? After you have removed it, you need to open the front panel and close it again to reset the printer and allow your document to print.
Nov 13, 2009 | Samsung ML-2510 Laser Printer
The paper does not feed into the printer
Sounds like you have a jam!
The jam always hides good!
Look carefully and get back with me!
Jul 16, 2009 | Samsung ML-2510 Laser Printer
Samsung ML-2510 Laser Printer Jams
printer only supports up 120gsm,anything thicker will jam.
Jun 08, 2009 | Samsung ML-2510 Laser Printer
Printer does not feed paper
Dear sir; That's very difficult to tell you detail how to take apart the parts, but I can teach you a easy way and tricky way, this cause you problem is paper pick-up roller, right above the paper tray. therefor you have move out the tray , remove the toner ctg. flip machine over (bottom up) then you will see the roller very clear, clean up with rubber rejuvenator, try it out, and please let me know how does it work, good luck! HAVE A HAPPY HOLIDAY !!!
Dec 18, 2008 | Samsung ML-2510 Laser Printer
Samsung ML-2510 printer paper jam
This happened to me after I had cleared a paper jam. I finally had to take off the back and cover to discover that there was, indeed, a small piece of paper invisible otherwise (torn off of the paper I removed). I removed the piece with tweezers and now it's working fine. Remove all other moveable parts inside. The top front is held on with two plastic posts + screws, the back by four deep-set Phillips screws. Might work best to remove back screws, then front, then top. The top feels fixed, but it snaps out (sounds loud!) with some pressure, and snaps back in on reverse. Harder to replace than take off.. Be sure the light color on the top on either side of the fuser opening slides under the darker color part of the back (about an inch?) before snapping or screwing it all back. Good luck!
Aug 03, 2008 | Samsung ML-2510 Laser Printer
Constant paper jam
How do you put the paper in?It must either be the paper or the paper feed system.
Apr 27, 2008 | Samsung ML-2510 Laser Printer
Debris in Gearing
check google for service-manual icq 475653626
Nov 30, 2007 | Samsung ML-2510 Laser Printer
Samsung ML-2510 Laser Printer Logo
906 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
