Pro heat carpet cleaner will not pump solution to either cleaner head...sometimes, at first, pump will work for about 1 minute or so...tried re-seating the tank, but no good...what should I check?
The very best thing to do is to fill the dispenser tank with hot water....just plain hot water. Take it outside on concrete, so you can see what you're doing, and operate the cleaner heads. Alternate back and forth. What's happened is that the machine has set with solution residue in it, and it is stopping it up. The hot water will eventually dissolve the goo, and the machine will start working properly. It may take more than one tankful of hot water, but one will probably do the trick. To keep this from happening again, run another tank of hot water after you've finished. I do it on my carpet after shampooing, and it has the added bonus of vleaning the pickup side as well!
Best regards, --W/D-- please feel free to rate this solution....thanx!
Just bought a new brush, ame part number for bissell 7901, I can't get the brush to go back into...
(More)
Just bought a new brush, ame part number for bissell 7901, I can't get the brush to go back into cleaner.
I am having problems with my Bissel 7901-1. It isn't working at all. If I remember right it didn't...
(More)
I am having problems with my Bissel 7901-1. It isn't working at all. If I remember right it didn't work well the last time, but I tried to use it yesterday and it wouldn't work at all. The flow sensor doesn't spin,the water doesn't come out and neither does the soap. I have checked the flow spinner for clogging and I checked the red rectangle filter that is visible. What else can I do to get it working again?
I want to clean fluff from underneath the transparent front panel of my Bissell 11 7901. I have...
(More)
I want to clean fluff from underneath the transparent front panel of my Bissell 11 7901. I have removed the screws from the bottom of the panel, but it remains firmly in place. I do not want to apply apply forceful leverage in case there is something else that needs to be done before the panel will come off. Any suggestions, please? Peter
Add the things you own to your My Products collection and get product information, solutions to problems, manuals & guides, tips and how-to's, reviews & ratings and local repair service - all in one easy place.
