Question about Dryers
How do open the dryer to see the thermalfuse?
    Brigadier General:
  • 4,088 Answers
Usually the dryer must be disassembled to the point that the drum can be removed. The heating element(s) and fuse are behind the drum.
Posted on Aug 01, 2009
Maytag century gas dryer will not turn on
Probably the thermalfuse.
Apr 14, 2014 | Dryers
Power on display but no power at motor
Without model number i can't be specific each model wired different had same problem last check for an open thermalfuse
Jan 21, 2014 | Maytag Dryers
Thermalfuse
It's A circuit breaker located on the out side of the burner at the 7 o'clock position. You need to remove the front panel to get to it. Unplug the dryer before doing this.
Dec 08, 2011 | LG DLG0452W Gas Dryer
Where is the thermal fuse or switch
Hi bigblockant...
Remove the backpanel from your dryer, look for the wires going to a plastic switch, oval switch,etc.
Take the two wires off of the thermal fuse/thermistor/thermostat,etc and put them together one fuse/thermistor/thermalfuse at a time, if the machine runs...replace the fuse.
Please take time to rate me thumbs up
Sep 12, 2011 | Kenmore Dryers
The location of the thermalfuse
Hello, Thank You for using FixYa. I will be helping you today. It is number 59 in this diagram .. If you remove the front bottom cover it is on the top of the metal blower housing right in front.
Thank You and please rate my answer if it was helpful..
Jun 22, 2011 | Whirlpool GEW9250 Electric Dryer
Fan not operating
pls..check the fan motor maybe the problem was in there. check the thermalfuse f they have maybe it OPEN reading at your multitester. f does change that thermalfuse. or maybe the capacitor of that fan installed in there. sometimes its GOOD when you test them, but they did not work when applied a load circuit.
Jun 09, 2011 | Heating & Cooling
Thermalfuse in whirlpool duet electric dryer blows every few months - what is causing this? Had servive 4 times inlast 10 months - keep replacing the thermalfuse and also shortened the vent hose for better...
Hi miralou
Check for lint buildup and clean if necessary your vent hose.
If you vent hose "seems" to be clean then,try running the dryer with the vent hose off and see if the dryer is blowing out a good stream of air.
If you are running too hot you are not moving enough air thru the system and it will normally blow the thermostat/thermistor.
Check to see:
It could be that the fan blade is plugged up.
The problem could be a large lint ball build up in the center of the fan or a sock,thin pants,a pen,etc. that has gotten into the fan by falling down the hole where the lint screen is normally inserted impeading the air flow.
You have to find the air restriction to solve the problem.
It also can be a loose or worn out blower wheel/fan.
Free Answer...Please take time to rate me.
May 26, 2011 | Dryers
Have a Kenmore model # 97591240. Dryer is not
Hi, if the igniter is not glowing then the problem will be with the thermal fuse. I'm going to assume this is a whirlpool made Kenmore since you did not provide the full model number so please remember this when rating. If you remove the back from the dryer and look down and to the left you will see the thermal fuse it looks like this:
http://www.applianceblog.com/mainforums/attachments/whirlpool-kitchenaid/415d1159395986-dryer-timer-wiring-thermalfuse.jpg
Pull the wires off and test it with your ohms meter. If as I suspect it reads open replace it. If you have any other questions please feel free to comment. Mike
Jan 02, 2010 | Kenmore Dryers
Model mde3000aya, runs but no heat. was wondering about tests to perform to figure out exact problem.
you need chek:
1-thermalfuse
2-heater element.
3-hi-limit sw.
4- temp sw.
5-electronic control.
6-cycling th'st.
Oct 05, 2009 | Dryers
Kenmore elite gas dryer
Does the ignition glow when you start the dryer? if so you have power to gas valve and ignition system. if not you may have an open thermostat or thermalfuse.
If the ignitor just sits there and glows all day, you have other problems, It could be a gas valve, or ignitor sensor.
Jun 04, 2008 | Kenmore Elite HE4 Electric Dryer
Dryers Logo
60 people viewed this question
Top Dryers Experts
