Question about Brother DCP-7020 All-In-One Laser Printer
Location of toner cartridge where is the cartridge located on DCP 7020 ?
    New Friend:
  • 116 Answers
Remove the drum unit. inside drum unit u can find the toner TN 2025
Posted on Aug 02, 2009
BROTHER DCP-7065DN HOW TO REPAIR LEFT SIDE VERY LIGHT PRINTING
When this occurs it usually means that the toner cartridge is running out of toner on that side. The left is most common since most printing is on that side. Remove the toner cartridge, and shake it vigorously from side to side for a few second, then replace and try again..
Apr 14, 2015 | Brother DCP-7020 All-In-One Laser Printer
Brother DCP-9020CDW - How can I reset the toner life?
Hi there
You can reset the brother dcp 9020cdw toner cartridges using the printer menu. Its simple. see video on the link
http://www.zinetic.co.uk/Blog/resetting_the_brother_dcp_9020_cdw_toner_cartridges-blog.aspx
Nov 18, 2013 | Brother DCP-7020 All-In-One Laser Printer
Where is the toner sensor on the toner holder in the DCP-7020 it keeps telling me toner is empty and toner should not be empty yet.
If you look at your toner cartridge you should be able to see a clear plastic circle. That's part of the toner level mechanism. I've gotten a few more prints out of my cartridges by putting a piece of tape over the clear plastic and coloring it black with a sharpie. However, there are other mechanisms used to gauge toner levels, and this will not be a permanent fix.
I've also gotten a little more life out of it by simply shaking the toner cartridge for about 15 minutes. It helps coat the inside and might break up chunks inside the cartridge itself.
Jun 16, 2011 | Brother DCP-7020 All-In-One Laser Printer
Where is the drum located in the printer?
The drum unit is attached to the toner cartridge for the DCP-7020. If you open the front cover (flips down) of the printer, you need to simply pull the drum and toner unit straight out from the printer. You should place the unit on a large drop cloth or piece of paper to ensure that the toner doesn't spill. See chapter 6, page 12 (page 52) of the User's manual for the image of the drum unit. Page 6-19 has the removal procedure. You separate the toner unit from the drum by pressing and holding a lever on the left side of the unit. Then pull the toner cartridge straight out from the drum unit. The User's manual is available from Brother's product support page. The direct link to the manual is http://download.brother.com/welcome/doc000367/DCP-7020_UsaEngUsr_B.pdf .
I hope this helps.
Dec 12, 2010 | Brother DCP-7020 All-In-One Laser Printer
I am getting several black lines in scanned and copied documents of my DCP 7020 Thanks
Check the print document to see if the ink rub of easily,if so this mean the fuser cartridge need to be change.Turn off the printer and wait until it is cool before changing the fuser cartridge because the fuser get very hot when ever the printer is in use.
Open the fuser cartridge door. On most printers this door will be either on the left-hand side of the printer or in the back. Consult your owner's manual for the exact location. Flip down the clips that hold the cartridge in place, then grasp the handle and pull it out of the printer.
Push the new fuser cartridge in until it snaps into place, then flip the clips up to lock it in place. Close the fuser cover door.
Open the toner cartridge door and remove the toner cartridge. On most laser printers the toner cartridge is located either in the front of the printer or on the right-hand side.
Vacuum underneath the toner cartridge to remove all paper dust and toner residue. This debris has a tendency to build up and cause streaks and stains on the paper.
Wipe the interior of the printer with a soft cloth to remove any remaining debris that could cause problems with print quality. Continue cleaning the printer until all debris is removed.
Purchase a set of laser printer cleaning sheets, and load one or two in the paper tray. Print to those sheets of paper to clean the paper path. These sheets are slightly sticky, and they are designed to remove dirt and debris from the paper path.
You should also clean the print drum and the corona wires.
Aug 30, 2010 | Brother DCP-7020 All-In-One Laser Printer
How do I reset the drum counter for my Brother DCP 7020 - I just installed a remanufactured drum, and the 'replace drum soon' warning still comes up
Look at your toner cartridge. There is a white stud that is attached to a gear. On a brand new cartridge, this white stud is in the opposite position of the one you currently have. Its been awhile since i've had my hands on one of these - just find a way to manipulate it so that it is in the opposite position again and toner count will reset.
Dec 16, 2009 | Brother DCP-7020 All-In-One Laser Printer
Brother DCP 7020 Keeps giving me the "Drum Error" Message
Dear sir you see properly drum unite has a drum image sensor its demage so you change your copier drum unite, thanks.
Nov 17, 2009 | Brother DCP-7020 All-In-One Laser Printer
Back Door Open on Brother DCP-7020 printer
I opened the back panel and yanked out the piece of paper that was apparently halfway through the machine. Message dissapeared, printer warmed up and I could print again. This would appear to be a poorly designed error messaging system that wasn't properly tested.
Oct 23, 2008 | Brother DCP-7020 All-In-One Laser Printer
DCP 7020 cartridge
wrong cart or did not remove packing, make sure u use oem product
Dec 29, 2007 | Brother DCP-7020 All-In-One Laser Printer
Brother dcp 7020 says toner end life
unplug plug it back in, did you remove the protective cover and clean coria wire?
http://welcome.solutions.brother.com/BSC/public/us/us/en/faq/faq/000000/000000/000065/faq000065_018.html?reg=us&c=us&lang=en&prod=dcp7020_us
Dec 20, 2007 | Brother DCP-7020 All-In-One Laser Printer
Brother DCP-7020 All-In-One Laser Printer Logo
109 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
