Question about Garden
Honda GX340 ran great, now it won't start
I borrowed this from a friend and it was running great for my father, he shut it off by closing the choke. Later on I used it and shut it off using the on/off switch and now it will not restart. It does not seem to be getting spark. Any suggestions?
  • 83 Answers
SOURCE: I have a 13 HP Honda that won`t run unless choke
You most likely need to set your valve clearances. If it is hard to pull over or the recoil snaps back after starting your valves need to be set for sure. This may not be the entire problem but it is a good start. Also change the spark plug, a bad plug will cause odd problems and is too cheap not to eliminate as a source. In addition check your fuel, pour a little out into a white container (I like spray paint can caps for this) and look at the color. If it is yellow to orange it is bad. You can pour it into you car, the car electronic sensors will compinsate for it quality but a small engine can't. Use a NGK BP6ES or BPR6ES plug.
You need:
Feeler gages
10mm open end wrench
14mm open end wrench
1 long shaft screw driver or rod
1 spark plug socket and ratchet
Remove the spark plug and the valve cover. Pull the recoil over slowly until the intake valve opens (intake is closes to the carb and it will go down when it opens). Now put your long screwdrive down the spark plug hole. Slow pull the engine over until the screwdriver handle is at it highest point, this is top dead center. It may take a few attempts. Now check your valve clearance between the rockers and the top of the valve. The intake should be .006 and the exhaust .008, both can be +/- .001. To adjust: hold the large nut with the 14mm then loosen the small one with the 10mm. Lefty loosey. Now turn your large nut until you get the correct setting and then tighten the small one the lock it in. It may take a few attempts and alway reverify your setting after you lock it down. Once done, find top dead center again and reverify. Now your valves are set.
Posted on Mar 31, 2009
  • 4 Answers
SOURCE: Can't start the Honda GX160 5.5 HP Electric motor
Is there an oil sensor unit if it is going bad it tells the engine the oil low and engine wont start. I had same problem with my pressure washer, i just unplugged the sensor unit and it started fine ever since
Posted on Apr 27, 2009
  • 174 Answers
SOURCE: Honda GX340 11 Hp ..Runs fine until it gets hot , Cuts off and
FIRST...check the engine oil level. Some Honda engines have an oil sensor that shuts off the spark if the oil is low. This would also explain it shutting down when it get hot. Check the manual to see how to tell if the oil level is correct. Also, the oil should be brown and transparent, not black. It may need changing. Post again if this doesn't help :-)
Posted on Jun 16, 2009
  • 174 Answers
Have you checked the oil level?
Posted on Jun 28, 2009
  • 3 Answers
SOURCE: Karcher pressure washer with Honda GC160 engine only runs on chok
You need to remove the carb bowl, then with a small flat screwdriver remove the jet. ( on the side, at the bottom of stem.) take a small wire or toothpick and clean the gunk out of the jet, reassemble and open fuel valve, start, and pat yourself on your back.
Posted on Aug 04, 2009
Have honda gx340 11hp pressure washer and gas keeps going into oil?
Excessive fuel entering the inlet manifold, carby needle and seat not shutting of fuel flow , remove and clean fit new gaskets and needle and seat if worn.
Jul 02, 2015 | Honda Gx340 Gas Engine 11hp Motor Pressure...
Why does Honda GX340 die immediately despite fresh gas, cleaned carb, and new plug?
Perhaps you haven't adjusted the carburetor correctly.The fuel supply orifice could be still plugged . Recheck the carb.
Aug 27, 2014 | Honda Gx340 Gas Engine 11hp Motor Pressure...
My Husqvarna 150BT leafblower was running great then started to loose power like when I run out of gas, I shut it off check fuel level which was fine, cleaned the air filter, added more fuel and pulled the...
Pull the muffler and look for scoring on the piston. I think you cooked it my friend. You may have a bad coil or fuel cap, but it's more likely you ran the mix too lean.
Nov 04, 2013 | Husqvarna 150Bt Leaf Blowers
I HAVE A HONDA 2005 HONDA SHADOW AERO. RAN FINE YESTER DAY. WENT TO START IT THIS MORNING AND FORGOT TO PULL OUT CHOKE IT STARTED THEN DIED. PULLED THE CHOKE STARTED UP AND RAN FOR 45 SECONDS AND THEN...
You have 2 solutions : take out the spark plugs and dry them with cloth, put them back in and start the bike.
Or, leave the bike over the night and the excess fuel on spark plugs will evaporate.
If the engine is hot and you have this problem, just leave the bike for half an hour and start it.
Sep 29, 2013 | Honda VT 750 Shadow Aero Motorcycles
Engine starts but won't continue to run. Choke doesn't stay closed after starting. will stay running only if I hold choke closed manually.
let it warm up with choke closed manually after it starts to stall with choke closed open it and dont let it stall u can learn to play with the choke a little to get it to run right GOOD LUCK!
Aug 14, 2011 | Toro Lawnmower 20099 Mower Mowers Lawn
I have a Honda XR250 that I am having trouble getting started. I think it is a '96, but honestly I am unsure. It's an MD30 frame bought secondhand in Africa. The frame actually also says Honda XR250S,...
i had the same pronlem this year cleaned the carb emtied the gas changed the oil and it would run but when i got on it it would cough and not produce power so i took the sparkplug outn filed it down and put some gas on it it fired right up n ran great for about 20 min so i replaced the sparkplug n it runs great now
Mar 15, 2010 | 1992 Honda XR 250 R
Could I please have the basic start procudure for the poulan 2375 Borrowed from a friend. won't completely turn over
1) Have fuel tank full of a mixture of 50:1 gasoline and 2 cylce oil.
2) Have bar chain oil tank full.
3) Push down choke to full
4) Pull over engine 2 times.
5) Push choke off
6) Pull over engine. If it does not start you may have flooded engine ect.
Please let me know.
Feb 26, 2010 | Poulan Wild Thing 2375 18" Gas Chain Saw...
2004 Honda Shadow Aero stalls
sounds like bad fuel try adding some fuel stabilizer.
Jul 19, 2009 | 2004 Honda VT 750 Shadow Aero
Garden Logo
138 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
