Question about Dryers
Kenmore Gas (propane) Dryer
My Problem is this -
Our dryer was drying one load, then the next load was still wet. I checked the vent for obstructions and found none. The igniter would not glow, so I changed it. I have cleaned every inch of the dryer and still nothing. I checked wiring, looked for power and found everything working, getting power all the way to the coils on the gas valve. The igniter still does not glow and the gas valve will not open. I am thinking it is probably the coils, but, I wanted to check with you guys first. I just didn't want to throw good money after bad. Can you give me some advice or some ideas as to what it might be? Also, what type of voltage values should be coming down to the valve or coils?
  • 213 Answers
Theres a black box eithr on the left or right of the tube that the flame comes on it. its a flame sensor. when the sensor is bad the ignitor cant come on
Posted on Nov 25, 2007
Kenmore model 90 dryer electric will dry the clothes takes a long time. Leaves the floor surrounding the dryer damp actually wet just not puddled
Are the clothes wet AND hot? If so - check the exhaust / vent hose for kinks or obstructions. That includes the cap / flap on the outside of the house.
If the clothes are wet AND cold, then the electric heating element isn't heating likely due to a broken or poor electrical connection, burned out heating element, defective thermostat, etc..
Jul 14, 2015 | Kenmore Dryers
Converted a kemore from gas to propane now it doesnt get very hot and takes forever to dry
Normally natural gas appliances have a different nozzle size than the propane units. i would check with your propane/gas dealer to make sure.
Mar 02, 2014 | Kenmore Elite HE3 Steam 8674 Dryer
Have a Kenmore 90 series gas dryer model 110. 72922188 that won't come up to heat and dry the clothes...Popped the front, cleaned all the lint areas, checked the cycle knobs for proper setting, tub/ motor...
aslong as the ignitor is glowing red then a click frome the flame switch and lights the burner tube and continues to repeat this over then dryer is ok ...... take venting off back of dryer and do a test load .... that will solve if it's a venting problem... if dryer dryes clothes with venting off back of dryer then it is a venting problem ..... from vent tube to out side exhaust... if dryer dosent dry clothes with vent off then u need to replace the gas coils black cylinders on top of gas valve... cost around $30.00 and very easy to installl 2 phillips screws in bracket cap on top of the coils slide off and replace one at a time there is a large coil and small coil and they both come in same kit and need to go back in the same spot they came off in ....part numbers..# 306106 306105 or recheck your model number off dryer data plate and order off
Jan 28, 2011 | Kenmore Dryers
It takes 2 cycles to get load to dry. What should I do?
Check for proper venting. If the lint filter or exhaust vent is clogged the clothes will be hot but still wet if there is a blockage in either the lint filter or the exhaust vent.
Mar 29, 2010 | Kenmore 73952 Gas Dryer
I have a Kenmore 90 series dryer.The only number
the door should have a sticker where it closes against with model and serial numbers as for the second part ck terminal connection to elements to make sure they are tight next shoot continuity of the elements limit switches thermal fuse elements will be between 9 and 13 ohms others should read 0
Jan 28, 2010 | Kenmore Dryers
Clothes get warm but stay wet and do not fully
You need to check the venting. Take the vent hose off the back of the dryer and try drying a load with it off and see if it will fully dry. If so, clean the vent hose.
Nov 16, 2009 | Whirlpool GGQ8831L Gas Dryer
Gas dryer not drying clothes
Hi, Dryers are simple machines to fix yourself so the main reasons dryers do not dry cloths is listed below.
1. Make sure the vent is clear from obstruction of lint built up by taking off vent and make sure the vent flap is opening when dryer is on, beware most house fires are caused by neglect of dryer vent!
2. People allot of times overload machine which causes cloths not to dry.
3. Electrical Repair Needed: one of the thermostats in the dryer are defective
May 02, 2009 | Dryers
Kenmore Gas dryer (110.76742500) will not dry properly.
if the vent is clear then the problem is in the gas valve. Youneed to replace the coil set part number 279834.
Apr 06, 2009 | Dryers
Dryer takes hours to dry ever since I converted to propane.
check for obstuction such as lint build up in the exhaust tube all the way out the house. Sounds like poor air flow
Mar 01, 2009 | LG DLG7188 Gas Dryer
Maytag gas dryer runs, doesn't dry
Check in the hole where the screen goes for blockage. Many times debries falls in there when removing screen. It cant make it out of the vent so it builds up and clogs the vent.
Dec 01, 2008 | Maytag Neptune MCG8000AW Gas Dryer
Dryers Logo
779 people viewed this question
Top Dryers Experts
