Question about Miele Refrigerators
My miele fridge is not working. the fan has stopped and the fridge is not cooling
    Top Expert:
  • Miele Master
  • 51,506 Answers
Call a repair service locally
Posted on May 18, 2018
  • 11 Answers
SOURCE: Fridge is not 'freezing', Looks like fan stopped working
1. is the freezer cold? yes. checkto see if freezer fan is operating. open fridge and listen for a fan. if freezer is not cold listen for the compressor to see if it runs. located behind fridge on bottom left. If compressor clicks replace switch on compressor. If compressor doesnt run then the problem is in your defrost circuit.
Posted on Mar 22, 2007
fanny
  • 146 Answers
SOURCE: Kenmore side by side Refrigirator
Sounds like you have a defrost problem. The timer could be playing up and taking too long to defrost, which causes the evaporator to ice up, hence no cold air to the fridge and the water line freezes up, hence no water dispensed. When the timer does eventually defrost the fridge then everything returns to normal. This could also be caused by a faulty defrost terminator or bad connection on the defrost element.
Posted on Oct 30, 2007
  • 50 Answers
SOURCE: stopped cooling and freezing
check that the condenser fan is working and condenser is clean.. check that the evaporator fan is working may have to push switch in to make it run. if ice is visible behind rear freezerwall you do have a defrost problem find defrost timer and with a flat head screwdriver turn it until you hear a click and everthing shuts down. if yoou hear ice cracking you have a bad defrost timer(very common failure)you may have problem in the defrost heater but you might find that a little over your head and a repairman might be the cheapest way to go, because buying parts can be expensive and they are not returnable
Posted on Jan 24, 2009
JasonsGMC
  • 18 Answers
SOURCE: Fan stopped working
The bearings may have gone out in the fan. Try to find an old fridge and swap out the fans.
Posted on Oct 13, 2009
heatman101
  • 43501 Answers
SOURCE: i own a amana fridge
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Posted on Sep 16, 2010
The fan on my Miele fridge freezer is not working, how do I rectify this issue
Check first input power supply of fan if its OK then problems can possible in the fan motor . you can check pre fuse by a tester with continuity method
Jul 21, 2016 | Miele Refrigerators
How do I set the temperature for miele fridge freezer pigeon pair kfn 9753 iD?
Wait for it to cool
while it dies you will see flashing bars
wait
it will cool
Feb 24, 2015 | Miele Refrigerators
MY Frigidaire Refrigerator is 2 years old, the Refrigerator is not cold, but the freezer is working fine, what is common fix?
Most will tell you the freon is bad. but i have found in most cases the freezer works but fridge doesnt.. I have found the solution to be a bad cooling fan on the fridge it self. if the fan is not cooling the fridge will not cool. You could pull the fridge out and see if you can see the fan turn it on hi and when the fridge kicks in see if the fan or fans are working.. dust can cause them to slow or stop.
Jan 06, 2015 | Frigidaire Refrigerators
Fridge not cooling no air from bottom freezer that is working
The fan has to work. The fan makes everything, either cold or cool. The fan blows air into the fridge part, as well, as the freezer. The defrost control is what turns the fan on and off. When in defrost, the fan stops. The compressor stops as well, in most cases. Good luck.
Aug 16, 2014 | Kenmore Refrigerators
Neff fridge/freezer has stopped cooling
pull the unit from the wall, remove the bottom back panel , see if the small fan is working ,if the fan is , there's probally alot of dust back there,unplug the fridg. and vacuum the area real good,use a flash light to make sure you get it all, if the fan is not working and the compressor is running the fan is the problem ,the fan keeps the compressor and coils cool so the freon can cool down so the unit works like it should,if the freon is hot ,the air the fridg.will be blowing will be hot. this should fix your problem, and YES its worth fixing.alittle p.m.saves alot of $$$$$$$$$
Dec 03, 2013 | Neff Freezers
I have a Samsung Waltz double door fridge, i had a noise from the fan for a few days and now the noise has gone so the fan has stopped and the fridge is not cooling as normal, freezer is working ok. This...
I have a Samsung Waltz double door fridge, i had a noise from the fan for a few days and now the noise has gone so the fan has stopped and the fridge is not cooling as normal, freezer is working ok. This fan would switch off when the door was opened
Sep 14, 2010 | Samsung Refrigerators
The fridge is freezing. This happend after a hot summer and the internal fan was on almost a month. It started to freeze before the fan was put off. Thermostat is my suspect, but I can't understand that it...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
heatman101
Aug 31, 2010 | Miele K8952SDED Refrigerator
Hi, I have an LG refrigerator, the top freezer works fine but the fridge section has stopped cooling, I turned the unit off and next morning there was a large puddle of water on the floor, when I turned it...
When the fridge is not cooling that means the fan are not working or not working properly, need to replace or check if their is an ice bothering the fan to turn. ok
Feb 15, 2010 | Refrigerators
Fan stopped working
Oct 13, 2009 | Refrigerators
Refrigerators Logo
269 people viewed this question
Top Miele Refrigerators Experts
Starnley Johnwells
Starnley Johnwells
Oloyede Monsuru
Are you a Miele Refrigerator Expert? Answer questions, earn points and help others
