Question about Canon Speedlite 540EZ TTL Flash
The flash attachment fades out photos on my Canon Rebel digital
I used to use this flash with my 35mm film camera but then bought a Canon Rebel Xsi 300 digital camera and all of the photos look washed out when I use the flash attachment. Even when I put the attached filter on the flash all the photos are washed out and white, underdeveloped. Can I still use this flash with a digital SLR?
  • 149 Answers
Set the flash in A mode if not set camera aperture close
Posted on Sep 09, 2009
Canon EOS Rebel T2 - film loaded, but then wouldn't take a picture, the frame count was flashing on screen. What is the problem?
Hi. Open the camera back and pull the film further over towards the pick up spool, close the back and try again to take a photo, i had the same problem with an eos 650 and it always worked.Good luck.
Apr 15, 2014 | Canon EOS Rebel T2 with 28-90 lens 35mm...
What kind of film does an slr canon rebel take?
That depends .... canon made an slr named rebel back in the old 35mm days, then proceeded with the name right through to digital.
If your camera has
1) A back that opens (button on the left hand side - as you look through to take photo) revealing a sprocket wheel and takeup spool.
2) A small window on the back - allowing you to see the film cassette inside.
... then its probably a 35mm camera.
If your camera has
1) No back that opens, but a small cover / flap over a digital media slot.
2) A screen on the back.
.... then its probably digital, in which case it takes Compact Flash type cards.
If you can't identify it from this, please leave a comment with the model number and I can say definitively from that.
Hope this helps
Mar 12, 2010 | Canon Photography
Quantaray QTB-9500A with Canon Xsi not working properly
This is probably way too late for the original asker, but the previous answer is incorrect.
The Quantaray QTB-9500A is in reality a ProMaster FTD-5700 and was designed for use with later model electronic 35mm AF models (using the correct dedication module).
As such, the trigger voltage is no higher than 5v making it safe for use on later digital SLR's.
The original answerer is clearly aware that high trigger voltages on flashes designed for earlier, mostly mechanical, 35mm film cameras are often harmful to later models, but you need not worry about your model.
Please take a moment to rate my answer.
Aug 30, 2009 | Quantaray QTB-9500A TTL Flash
Black line across top of all my developed pictures
You have light leak somewhere to the film.
Usually from the bad film door seal.
Mar 29, 2009 | Canon EOS Rebel GII with 35-80 lens 35mm...
Taking Pictures of a Sunrise or Sunset
I would say that the iPhone is definitely the best device that we can use to buy an iPhone. The latest version of these phones provide excess;; lent picture clarity as well. So I would definitely recommend you to try it out to capture the most beautiful moments of sunrise and sunset in this phone. I believe that both the sunrise an sunset are beautiful to see, and are two wonders that keep happening everyday as well.
Jan 05, 2009 | Canon EOS Rebel XSi Digital Camera
My Cannon Rebel EOS 35mm film Camera is producing blank Film
If you are getting some photos where only part of the image is visible, then I suspect that they were photos where you used a flash.
Cameras have a specified maximum shutter speed for use with a flash, this is called its 'sync speed'. This is the fastest speed that the camera will need to open the lead shutter and close the trailing shutter in order to expose the entire surface area of the image and have it evenly lit by the flash unit. If you shoot too fast of a speed, then the shutter will only be partly completed its exposure and you'll get a photo with only part of the image showing. The faster the speed past the sync speed, the less the resulting area of the image. Most cameras will have a sync speed of 1/250 or less. I think a lot of the Rebel models are 1/90 - consult your manual.
Nov 23, 2008 | Canon EOS Rebel G 35mm SLR Camera
Flash on a canon rebel 2000 eso
Just push the flash back and it locks ,...... thats flash off
Oct 14, 2008 | Canon EOS Rebel 2000 with 28-80 lens 35mm...
Low battery warning
What type of batteries did you buy?
For digital cameras, you want to use batteries with high milliamp hour (mah) rating: "2500 mah" if they are rechargeable.
If you bought regular batteries, you want to use good quality. Look for the "e2" or "better for digital equipment" type.
Does the camera have a DC power plug option? Try taking pictures with it plugged in if it does. If it still malfunctions with power right from the wall, then you bought a bad camera.
May 10, 2008 | Canon EOS Rebel T2 with 28-90 lens 35mm...
Open Questions:
Canon Speedlite 540EZ TTL Flash Logo
160 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
