Question about Domotec Vacuums
Handle will not come back up.
HI. I have an electronic steam press and the handle is sticking and I cannot get the top plate to come back up again when I press it down on clothes etc. How do I get this problem solved? Thanks.
Thanks for your reply. However, I have telephoned around and found an engineer who is willing to try and fix it (if possible).
Thanks again.
S Hinchey
Posted on Aug 04, 2009
Handle is to hot to hold and steam is comming out of the top of the handle
i believe your hot water/steam hose/tube runs through the middle of
the handle down to the floor(where it sprays hot water/steam. it ether came apart on the inside or you have a hole in it.
Sep 02, 2013 | Polti Vaporetto 2400 Canister Steam Vacuum
Kirby Generation 3: Having trouble putting plate back on where electrical cord attaches. Ever since the shop put a new cord on for me, I have trouble using release lever for dropping the handle when I...
There are 2 tabs on the bottom front edge of the switch plate which slide under the metal top cover. Make sure these tabs have not gotten bent upward so they will not slide under the top cover. If they are bent, simply pry them open. Also, note that the handle pivot has a sliding latch on it to allow the handle to be fully lowered. To lower the handle flat, push the little knob inward.
May 03, 2011 | Vacuums
The plastic housing the handle locks into has cracked. The handle comes out when pulled back with little force.
Sorry but there a very few parts for these...
Here is a tip that I wrote about the Euro-Pro Shark Steam Mop and why it maynot be getting steam to the head...
Euro-Pro Shark Steam Mop Problem
Here also is a link to get any of the Shark Manuals that you need.
heatman101
Aug 25, 2010 | Euro-Pro Shark Steam Mop - Gray/ Purple...
I have a Hoover steam vacuum carpet cleaner Model
the lever on the handle should be pressed when you want to apply solution to the carpet
Dec 29, 2009 | Vacuums
My Shark 3501 has a broken handle above the resevoir. Called Euro pro and stayed on hold for 25 min with no answer. I am looking for a handle from top down to tank. Can you help?
No, you need to call them... check the manuals link...
heatman101
Nov 06, 2009 | Euro-Pro Shark Steam Mop - Gray/ Purple...
No steam coming from domena steam press . When i depress the handle no steam appears and it sounds diffeent to normal
My wife has the same problem with her press. I will have a look at it in the next couple of days and, all being well, will post a solution here.
Paul
Oct 12, 2009 | Domena Vacuums
I broke the handle part of the shark steamer #53101. I don't have the book to try to tell you the parts I need. Can you send me a picture or a copy of the steamer. It is purple. The above number may not be...
Ann there are very few parts for these...
heatman101
Sep 24, 2009 | Euro-Pro Shark Steam Mop - Gray/ Purple...
BISSELPRO HEAT CARPET CLEANER
With the top part of the handle off, lay the handle back and at the top in the middle, there is a catch, just push it in to release it and the front of the handle will come off.
Jul 21, 2008 | Bissell 1699 ProHeat Clear View Upright...
Heats up and produces steam but the release button does not open the flow of steam.
To remedy this, I did the following:
1) Removed screws from: a) Lower area of handle (1 screw), b) Top of steamer, under round rubber flap around fill hole (2 screws), c) Front of steamer where nozzles attach (2 screws)
2) Removed back of handle, top of steamer, front of steamer where nozzles attach
3) Once all parts are removed, you can see a brass button that is pushed by the trigger
4) Using a needle-nose pliers, grasp and rotate the button several times in both directions (you may hear it cranking against the interior spring). Do this until it turns fairly easily with the pliers.
5) Once this is done, you fill find that the brass button can be very slightly depressed with a bit of force. You may also need/want to unfold a large paper clip to push into the nozzle hole to help unsticking the brass button (not sure if that helped in my case, but it was something I tried along the way). When the brass button moves in and out (again, it won't move much), the steam release mechanism is unstuck!
6) Reassemble all parts (everything snaps back neatly into place).
This worked for my unit!
Nov 11, 2007 | Scunci 52067 Handheld Steam Vacuum
Electrolux contour 1100 flexihead. Z1436
You need to unscrew the screw at the back / base of the handle. The whole handle section will need to be slid backwards. Best way is to unscrew the screw on the rear approx 5 turns and then bump the end of the screwdriver. A few more turns then bump the end of the screwdriver again. The whole handle will eventually slide backwards and fall off. Then unscrew the two screws at the front (near switch) and the front switch cover plate will lift up (hinging at the top). This reveals the incoming wires etc.
Jun 18, 2007 | Electrolux Cleaner Lux 6000 Vacuum
Vacuums Logo
82 people viewed this question
Top Domotec Vacuums Experts
JoeVacs
Are you a Domotec Vacuum Expert? Answer questions, earn points and help others
