Question about Hoover U6630-900 WindTunnel Bagless Upright Vacuum
Hoover wind tunnel isn't suctioning but seems to be blowing out
Nothing is happening when we vacuum. It looks like a paths of dirt are being created.
    President:
  • 1,486 Answers
Belt brocken.
Posted on Aug 01, 2009
Why is my hoover wind tunnel blowing out side filter and not suctioning
Perhaps dirt or hair is stuck or the full canister needs to be emptied, remove blockage and suction should return.
Jul 15, 2014 | Vacuums
Hoover - Red Light Dirt Sensor
check to make sure the settings didn't get inadvertently switched to the hi position, move the switch back and forth from high to reg a few times, then leave it on reg.
remove and hand wash the primary filter and secondary filter, dry throughly and replace them in the vacuum.
if none of this works, you will need to have the vacuum serviced, or if it is still working, just don't pay attention to the dirt-finder. the dirt sensor on your vacuum is located in the suction tube and is generally not accessible enough to clean without taking the vacuum apart.
hope this helps,
trin
Nov 20, 2007 | Vacuums
Hoover wind tunnel the red light dirt finder stays on
There's a microphone inside the tube the dirt runs up. It listens for dirt coming up the tube. They just go bad and there's no making it better. You can either replace that entire assembly or ignore it. Fairly easy to replace. I'll include the part so you know what you're looking at.
Good luck! The Vac Dr.
http://vacuummedic.com/product.php?id=481
Jan 13, 2013 | Hoover Company Wind Tunnel U53019 Upright...
Maybe I could replace the belts and brush, but there seem to be too many places to go into to repair a suction problem. I need a repair shop for Hoover Wind Tunnel.
The belt and brush have nothing to do with the suction. The impeller on the motor creates negative pressure which results in a vacuum. ( or suction ) Many newer vacuums have as many as 4 filters. if any become completely clogged, the performance drops to nil. Start at the debris exit and work backwards. As a bagless, pulling the dirt canister out and removing the main filter is a good start. Most filters can be "tapped" clean and some are washable. after pulling out the filter, look where the passage way enters the filter chamber. Is it clogged? There is usually a secondary filter, which actually is set in a previous stage to the filter you just pulled out. Its main purpose if to catch hair, small nails, wire, and other material that could damage the more visible filter. If this filter is clogged then that will explain the loss of suction. Pull it out and clean it. An exhaust filter is located typically above the motor. Its purpose is to prevent fine particles from being blown about. It should be cleaned as well. With the filters clean and the hoses and passage ways clear, you should be good to go.
Good Luck!
Jun 10, 2011 | Vacuums
Insufficient suction in the hose apparatus of my upright
I have this same tool. Mine was found discarded by the side of the road and in obviously otherwise new condition. I took it home and cleaned the dirt path - it had a 'hair ball' inside - and it now runs like a top.
Go at it with a screw driver - clear all hoses and pipes and you will have a great running machine. You might be able to blow the clog out with a shop vac ...
Thanks for your interest in FixYa.com
Feb 15, 2010 | Hoover U5725-960 Bagless Upright Vacuum
I have a Hoover Wind Tunnel Supreme mach 3.9. It
Check the filter above the dirt tank. If you take out the dirt cup and look where in slides into the machine, there is a filter that is probably dirty. It can be cleaned or replaced
Oct 08, 2009 | Hoover Vacuums
Filter in Hoover Wind Tunnel Vacuum
Definitely not. Do not use water or any liquids to clean it. Te normal use life is 2-3 years keeping it maintained. You can clean it dry with the dust brush from your vac attachments. place in a plastic bag and tap it some folks even us an air compressor to blow out the impacted dirt. you will only want to use the Hoover brand, other generic brands dont fit as well.
Jan 17, 2009 | Hoover U6630-900 WindTunnel Bagless...
No suction on Hoover Wind Tunnel.
Greetings from GoVacuum.com,
First this is a common problem on ALL bagless vacuum cleaners. Usually it takes longer then 1 day however.
Is there no suction in the suction hose, or is it not suctioning from the floor?
Most people buy a bagless vacuum once, then return to a bagged one after their bad experience, you are not alone!
Please give me the model number to your Hoover, (found on the bottom or the back of the vacuum on a foil label).
Thanks,
Chris Jones
GoVacuum.com
1-866-468-2288
chris.jones@govacuum.com
Aug 18, 2008 | Vacuums
Poor suction-need to know how to remove & clean filter under canister of Hoover Wind Tunnel Mach 4.7 Twin Chamber System.
I assume this is a Hoover Bagless, if poor suction, the hose or dirt inlet by the brush roll may have a clog. The filter inside the dirt container may need replacement. Some had a screw to take out to remove the cover for the filter, the one under where hte dirt container sits. Alos the belt may be stretch and won't turn the brush roll under load. Having the model number would help.
Apr 19, 2008 | Vacuums
Problem with vacuum suction in upright position
Move the lever on the front of the machine to "carpet". It won't agitate on floor
Apr 11, 2007 | Hoover Company Wind Tunnel U53019 Upright...
Hoover U6630-900 WindTunnel Bagless Upright Vacuum Logo
343 people viewed this question
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
